0 Members and 291 Guests are viewing this topic.
jbignes5
Quote from: sparks on September 19, 2012, 12:37:05 PM
  TK obviously cannibalized a television set.  I believe Stivep did also.  TK buries a copper radiator and pours water all around it.  Tesla at Colorado springs buried metal and watered it in seeking to establish a lightning rod.  Tesla invented particle accelerators before vacuum tubes were available.  Tesla also claimed that radiation burns from his devices were ozone burns.  UV radiation ionizes oxygen to O3.  Uv is generated in an accelerator upon acceleration and deacceleration of electrons.  In an electron cascade event the electromagnetic energy produced is thousands of times that of the beta radiation that initiates the cascade.  The accelerated electrons have inertia and will continue on and deaccelrate upon striking the anode.  The accelerating field has come and gone in nanoseconds while the current pulse experienced at the anode continues on at intensities and duration far in access of the energy needed to charge the gap.  This procedure say picksup 1000 electron volts/fire.  As  the frequency of pulses is increased we see that so isn't the gain.  If we are operating at 10k pulses per second you can see how a gain of millions of electron volts is possible.  The higher the frequency of pulses the more gain.  The larger the accelerator the more gain.  The mt. in wardenclyffe was the largest electrode I have yet to see.  The few times Tesla tested it locals could see the glow zone all around it making energy out of thick air's electronic inertia.
Well the buried radiator was indeed a grounding source. If you take into account the second grounding at thw water pipe you will see they run the water there also. This is to make plates of a capacitor. A humongous capacitor. Hooked to either side of the drive coil and it becomes a very large current pump tank circuit. Now to drive that current pump you would need to induce a signal into the tank circuit. Hence the large copper coil around the drive coil. The transistors are the signal source to induce into the tank circuit. Ok so lets look at the capability of this very large tank circuit. Since I have already talked about ground loops and how powerful they can become that might give you an idea of the capability of this tank circuit to resists and load from stopping it. With light bulbs the resistance would be very small.
The spark gap is also very important as you point out as well. Not for the spark but for what happens as it is not in conduction mode. The build up of the electric field can become quite powerful and the subsequent release of that build up would be very very powerful as I have stated many many times. Much like a gun shot but way more efficient if higher voltages are used. This is also a timing device and diode like device all in one.
I agree with you about your statements of inertia with this energy. Tesla spoke many times of it and it makes absolute sense if we understand the difference between a low voltage heavy current and a very high voltage light current. The lighter the current the less it has to loose and the less it will be hindered as it travels. This concept he used in his wireless energy patents, theories and subsequent experiments.
leo48
But I was referring to the use for which it was built these transformers is the only way
to know the electrical characteristics.
As far as we have understood it this transformer may also be unnecessary and put
them to confuse an observer.
http://www.overunity.com/7679/selfrunning-free-energy-devices-up-to-5-kw-from-tariel-kapanadze/dlattach/attach/113837/image//
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
jbignes5
one thing that might help to understand this process is what other scientists are starting to realize. This is of the electric nature of the sun that I posted previously and here is a small clip of another related document talking about where the real power of the sun comes from.
"Qualitatively, at least, it would appear that the physical characteristics and the behavior of photospheric granules are responsive to explanation in terms of the anode-tuft hypothesis. The photosphere as a whole seems to add up to yet another strong indication that the Sun draws its energy not from within itself but from its cosmic environment, and that the delivery mechanism is an electric discharge embracing the entire solar system."
This one statement says it all if we are to understand the method nature uses to power itself. This electric discharge is not unlike what Tesla and TK used. The instantaneous network that gets provided by the electric discharge is the highway from free charges to be draw into the sun to be used and recycled back into radiative energy. It sets up a cycle and anything in the way will get charged and held into orbit if it's mass is sufficient in solar space. This charging creates a great many effects and is solely responsible for gravity like interactions in that space. If the mass is not sufficient to hold that energizing radiations then it re re-radiates it back into the environment and most likely gets sucked back into the sun.
I know this is about a device but the similarities of the processes is much closer then the appear when comparing the two objects(TK device/Sun). Just different amounts of masses and magnitudes.
leo48
In this photo you can see the front panel of this power where it was
used transformer green top in Cyrillic says 12.6 volts 2 amps and
other information on adjustments.
Leo48
FreeEnergyInfo
DALLY ...
МасÑ,ер Ð"али Ñ,.е. Edward Lee - email ...
lee13edward@gmail.com
