0 Members and 167 Guests are viewing this topic.
verpies
Quote from: FreeEnergyInfo on September 19, 2012, 03:30:32 PM
DALLY ...
I think you meant "Dally Fake.jpg".
Yes, it is possible to smuggle wires inside the braid and even use the strands of the braid itself to smuggle power via high voltage.
I would be glad to discuss it further in the in the Dally thread. Just click here...   Let's not pollute this Kapanadze thread with the Dally device (even if they are cousins).
jbignes5
Lets now look at the waves and impulses and how they work with both fields.
Here is an excellent book that might shed some light on the subject:
http://archive.org/details/ElectricDischargesWavesAndImpulses
Frederic2k1
Quote from: jbignes5 on September 19, 2012, 02:20:34 PM
one thing that might help to understand this process is what other scientists are starting to realize. This is of the electric nature of the sun that I posted previously and here is a small clip of another related document talking about where the real power of the sun comes from.
"Qualitatively, at least, it would appear that the physical characteristics and the behavior of photospheric granules are responsive to explanation in terms of the anode-tuft hypothesis. The photosphere as a whole seems to add up to yet another strong indication that the Sun draws its energy not from within itself but from its cosmic environment, and that the delivery mechanism is an electric discharge embracing the entire solar system."
This one statement says it all if we are to understand the method nature uses to power itself. This electric discharge is not unlike what Tesla and TK used. The instantaneous network that gets provided by the electric discharge is the highway from free charges to be draw into the sun to be used and recycled back into radiative energy. It sets up a cycle and anything in the way will get charged and held into orbit if it's mass is sufficient in solar space. This charging creates a great many effects and is solely responsible for gravity like interactions in that space. If the mass is not sufficient to hold that energizing radiations then it re re-radiates it back into the environment and most likely gets sucked back into the sun.
I know this is about a device but the similarities of the processes is much closer then the appear when comparing the two objects(TK device/Sun). Just different amounts of masses and magnitudes.
OMG... you just stated something I saw a few days ago in a 3 hour movie. Sadly this movie is only in german language available. You can look it here: [size=78%]http://www.viaveto.de/plasmaverse.html[/size]
The describtion of a electric selfsustaining universe is far more convincing then any other theory about dark matter, invisible matter, black holes and mathematic modells which nobody understands. Nature works simple not complicated.  :P
But governments and science fight with full force against this theory. Of course they do, if people would realize the implications of this nobody would need any power companies or oil criminals.
Zeitmaschine
Quote from: leo48 on September 19, 2012, 01:47:51 PM
But I was referring to the use for which it was built these transformers is the only way
to know the electrical characteristics.
The same question about the characteristics regarding the 2004 transformer:
Assumed that this transformer was build-out from an apparatus that was switchable between 110V and 220V input. What could that mean?
Could that mean the transformer in the 2004 video operates in reversed mode? The primary coil (right side) was originally the input from grid (110V or 220V), therefore all three wires are heavily insulated (hot side), and the secondary coil (left side) was in fact the 220V output (cold side)? Hence the diode bridge seems to be for high voltage and the capacitor is most likely also a high voltage type (around 300 to 400V)? In aquarium II the one visible transistor is a KD502 for max. 60V, but in the 2004 and the green box video there is no way (to the best of my knowledge) to tell what transistors are actually on the heat sinks. They could be high voltage output stage types for TV flyback (like BU208, 700V).
Now if the transformer has no low voltage output (e.g. 12 to 24V etc.) then there can't be any sophisticated electronics like a LM566 (Voltage Controlled Oscillator) in the tin can (there is no room for a second 50Hz transformer along with a second diode bridge along with a second filter capacitor along with a VCO circuit right next to high voltage) in order to generate any high frequency (thus one thing less to worry about). This means the high frequency is generated by the high voltage generator (flyback?) itself. If the high voltage fails (as seen) the high frequency fails (and the current consumption goes down). If there is neither high voltage nor high frequency but 220V/50Hz only then there is no way the coil (comprising a few turns) can have any effect at all in terms of 50Hz current manipulation (current creation).
So is there really no chance to squeeze 25 amps out of this 50Hz transformer, or is it?
Think we are close - either to complete success or to complete failure ... :) :(
