0 Members and 170 Guests are viewing this topic.
wattsup
@Zeitmaschine
First about the long version of the 2004.
I still have not been able to find a way to download that video to see on my VirtualDubMod so I am pissed off for that. I have all the other videos but not this one. I think I need the url to the original post of that video or if someone has it and can put it on a server for me to download.
Looking at the youtube version at....
17:31 When he momentarily plugged the leads that went to the back of the inverter into the mains socket (back plug), yes we see the spark as you say and the amp reads as you say. The set-up is battery - inverter - device.
When he turns on the bulb load, from then on it is impossible to see the spark given the brightness of the bulbs. So it is difficult to say if it is still on or not, but from what I could see the spark went off while the bulbs were lit and you can sense Tariel is trying to distract from that when he starts talking right away. Right there, it is not a good omen for the spark.
Then they connect the looping transformer (LT) to the bulb load and to the battery.
Then when he plugs the back plug into the mains socket to start the spark, they are stunned to see no spark and even try to convince the others that there is a spark when there is no spark. That whole part should be translated verbatim as it is key. You can feel their uneasiness even though you do not understand the language. It could be that the diode plate was not touching well enough the 6 turn coil. Or it could be that the diode plate was touching the 6 turn coil and this is why there was no spark. Either way there was no spark when the bulbs were lit.
So now were are left with a great quandary. A major piss-off because we have all vested so much time with sparks and all the builds on youtube and all the R&D.
This does not render Tariel a fake but will actually reinforce the fact that he may have something so simple and so stupid once we know it, that he is going to great pains to mask it in so many distractions.
The fact still remains that regardless of any distracting features, I have still never seen a Wire X since I always look for both ways. How it could work and how it could be faked. The fact that the spark may be a dud distraction, does not take away from the actual fact that he ran the device without a battery, with that back plug start up, at that time the spark came on (who cares right) and the bulbs were just as lit while looping back. That is an incredible task but now, if we can remove the spark gap as a side design, this now changes the theory and puts it smack dab on that transformer, the two heat sinks, something in the tin can and a possible effect in the TKc.
We know the spark gap was connected by two wires leading into the tin can so we could easily say the tin can contains a small flyback transformer used to create the spark-illusion and the diode plate intermittently touching the spark gap 6 turn coil may have rendered the spark useless. The device was started and ran without a spark. That we cannot deny.
Two switches usually started the device. Switch one is to start the spark illusion and create the distraction. Switch two is turn on the secret and hope no one sees it. hehehe
Oh yeh, I almost forgot. About the 2004 drive transformer.
It looks like a step down. He is connecting the higher resistance side to the inverter so he is using low consumption amps (0.6) at 220v. Then the secondary is step down to probably 220/4 or 55 volts.
The secondary has three terminals. The left one is connected to the wire going to the top of the diode copper shunt plate. The center tap is not used. The right terminal is going to the chassis of the transformer that also holds the diode plate.
Why do I think it is a factor of 4. He showed 6 amps off the battery and 24 amps on the load. That's a factor of four.
But how is he increasing the voltage from 55 volts. With those two heat sinked two wire components and the capacitor. What can you do with two zenors and a cap?
The wires from the 6 turn go inside the tin can. The tin can also receives 220v directly from the inverter (off the transformer primary pins) plus the secondary rectified higher amps of 55 volts. So what happens when you light bulbs with 220volts at .6 amps that is then spiked with 55 volts at 24 amps or a pulsed 55 volts at 24 amps. Maybe some more Havoc. Ahhhhhhhh.
Tariel lives in an area that probably has power failures galore. So people there will have batteries and inverters to make their lights go on. Could be one day he had a transformer connected and something shorted out but he notice the bulbs lit much brighter. With that type of simple effect, and if he wanted to protect such a simple thing, the level of his "Hmmmmm" again an SM type paranoia level was made more and more evident in his ever increasingly glamorous builds.
More fluff,
more pzazz,
more distraction,
will keep the little big secret,
as safe as can be.
Hmmmmm. Maybe for now I can leave the spark and put both flybacks on the coax.
Tomorrow.
I need the rest of the night off to come to grips with this realizing we may have been wasting a shit load of time. I had to use the s word in the last sentence for personal reasons. lol
wattsup
PS; What's harder, increasing voltage or increasing amps. Maybe the secret is you produce the amps and increase the voltage creates nice havoc soup.
penno64
Hi Wattsup,
Wonder if you can spare 5 minutes and have a look at -
http://www.energeticforum.com/renewable-energy/11855-eric-dollard-6.html#post209103
Don't know why, or maybe because of the Dally stuff, but I see Kapanaze
Penno
havuhung
Hi All,
I have a question everyone please help
One bridge destroyed when the footsteps of every person on the bridge every step count one, two!!!
Correlated to the electrical resonant coil how we do that?
Thank a lot
Havuhung
Magluvin
Quote from: havuhung on September 21, 2012, 02:13:02 AM
Hi All,
Thank a lot
Havuhung
That would be like say a coil of many turns(bridge) and a bunch of small(human compared to bridge)charged capacitors, one for each winding of the coil, and discharge all the caps at the same time, one across each turn of the coil. Bang!!!  ;]
MaGs
jbignes5
Ok at 16:06 you can clearly see that the wires with the plug in it are going to the transformer. We are getting confused here over this one point.
At 20:19 the battery is still in the equation but it seems to me that this is used for a bias of the ground connections and power the inverter. This is to keep a steady connection for the ground loop that he is about to create with the inverter that he plugs into the wall socket. That part you are correct on an for some reason I got wrong.
Yes they were concerned with it sparking less but it was sparking. If you look at the timing of him plugin the inverter in to the wall outlet it takes time for it to charge up and once it is going then he unplugs the inverter and the lights are switched on.
One reason he might have had to plug the inverter in is to add the already existing 50 hz to the inverter's output to synchronize it in a way to the bulbs normal input frequency. I am betting this plug in wires is a modification of the inverter that he had to make to allow syncing with the regular power system. But I'm guessing there.
I use real player that has a capture video function from youtube or any other source. It is compatible with flv files and I have used it on more then one occasion to copy videos from youtube.
