0 Members and 347 Guests are viewing this topic.
Zeitmaschine
Quote from: wattsup on September 21, 2012, 12:37:25 AM
I still have not been able to find a way to download that video
This works for me: http://www.youtubedownloadersite.com/
So now were are left with a great quandary. A major piss-off because we have have vested so much time with sparks and all the builds on youtube and all the R&D.
The (phony?) TK coil consists of: One orange cable (to lamps) going in and out, one white cable (bifilar?) connected to ground going in and out, surrounded by a helical coil in series with a spark gap. Maybe there is ferrite or metal of some sort hidden in the core or even not. The point is, this coil is basically a very simple construction. Why then was nobody able to replicate it successfully in years? Because this coil has actually nothing to do with the creation of energy?
Everyone looking at the TK setup thinks the prominent eye-catching coil creates the energy by some (unknown) Tesla (spark) effect and the 50Hz transformer in the background is only there to provide a few volts for the spark generator. In actual fact the 50Hz transformer is responsible for the production of the free energy whereas the whole purpose of the big coil and the spark is to cover up the plain truth.
Now something feasible in terms of physics is needed to get 25 amps to the lamps. Hence first the question: Is grounding needed or is it not?? I don't see a ground connection in the image below. But then why is a ground connection on aquarium II required? Just another distraction? And then why is there a 23 amps reading on the ground cable in the green box video if ground is not needed?
Second the question: What is alternated current? More or less electrons moving quickly forward and backward in a wire? So these electrons come from nowhere and go to nowhere. There is just an oscillation of the already existing electrons in the wire. But then, why do electric AC circuits usually only work when the circuit is closed? A capacitor (although the plates are insulated from each other) can close an AC circuit. Question: Is it possible to close an AC circuit by means of a magnetic field?
The thick orange cable carries a current of 25 amps. This cable comes out of the tin can. But I can't see any thick wire suitable for 25 amps that goes into the tin can (coming from the transformer). This could only mean that the 25 amps are created somewhere in the tin can. What is suitable to provide a lot of amps? Maybe a capacitor? But how to run a capacitor with less amps in than out?
Seems plenty to investigate ...
jbignes5
You are talking about two different devices here.
Stay on one subject. You keep swapping back and forth trying to compare two different device. The grounding in this instance is on top of the device. They are antennas or virtual grounds. Gah man where have you been. This was discussed over 20-30 pages ago....
When we were discussing this subject we thought that the big blue coil is in fact a coil wound on top of a very big capacitor. This was the experiment that I had Itsu do for me with energizing a capacitor from the outside with the black part of the blue wire covered cap. Simply the cap is agitated into providing the current by the crude Tesla coil wound over this cap.
The yellow covered device is an inverter and the black box could be anything.. Even a battery, as the inverter would need the battery to operate. Just like in his earlier device.
I really don't think this device is very good representation of Kapanadze method. There is too many variables in this. Is there a video for this and why is the light attached to the wall??? Seems to me that there is a lot missing from this picture..
sparks
  A capacitor is a spark gap that hasn't sparked.   When electrons are added to one plate and taken from another an electric field is established between the two electrodes seperated by an insulator.  If the dielectric breaks down and electrons are acclerated from cathode to anode the resulting radiation emitted by the accelerated or deaccelerated mass of the electron results in ionizing radiation being absorbed by the dielectric.  The dielectric usually carbonises and a massive transfer of electrons from cathode to anode insues.  Often this current oscillates between the two electrodes as the electron inertia causes an overshoot.  This results in a very high frequency oscillation of current between the capacitor plates and can easily be seen on an oscilliscope as the spark gap rings down.  A spark gap can also be used to couple an ac signal to a circuit.  Electrons extracted from one electrode causes it to become anodic.  Electrons move from the core of the second electrode towards the skin and a current in the coupled circuit ensues until the secondary electrode fills up to capacity.  When the anode extraction potential is relaxed the amassed electrons on the cathode flyback into the coupled circuit towards the scource of the free electrons which is relatively positive compared to the charge accumulated on the cathode.  The anode also draws current back through the primary circuit.   Capacitors aka unshorted spark gaps need not be charged in a closed circuit as long as electrons are moving into and out of one spot in space the rest of space recognises this abnormal charge distribution and will respond.  How much simpler can it get.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
a.king21
Re amp measurements in the 2004 video:
It is impossible for these meters to read correctly. Please do not be misled. Most European meters are calibrated to 220 volts (more or less) and 50 Hz.  Any device which  produces a high voltage will automatically skew any meter.
I would even be suspicious about a true rms meter, because high voltage messes everything up. Think about it: How many meters have you destroyed? I've destroyed more meters and inverters than I dare think about.
That is one reason I asked for a 2 kw load running for over 4 hours in the aquarium 2. We don't need meters to know it worked. Everyone there could feel the heat. You can fool people with lights and lightbulbs. You cannot fool people with heat. Heat is where real power measurement is.
For the second time, we wanted meters to disprove cheating. We wanted to look into the possibility of HV coming in from the ground. My only question was and still is," Is the Kapanadze device free energy, or is he transmitting power through the ground wire?"
My personal opinion is that the chances are that it is  95% genuine and 5% fraud.
My money is on the transformer as the source and the coil pack as a step down transformer to do at least two jobs.
1 Power the load
2 Provide a feedback loop.
Oh, and the spark gap? As in his patent: an overload protector.
We should look at the wiring in this light, in my opinion.
Zeitmaschine
Quote from: jbignes5 on September 21, 2012, 10:58:45 AM
Different in what way? Different in disguising the real thing?
Not connectors for the start-up battery?
And? Any success with Free Energy?
Quote from: sparks on September 21, 2012, 11:29:02 AM
Not simple enough, otherwise we would already have a working replica of the Kapanadze device. ::)
Quote from: a.king21 on September 21, 2012, 11:44:11 AM
On the other hand the guy in the yellow tent presentation does obviously nothing have to complain about. Maybe because he knows there is no high voltage / high frequency involved at all in this presentation?
