stivep
Please concentrate on electrostatic resonance
http://www.youtube.com/watch?v=MIMa1knlrfA&feature=player_embedded#!
look  at this video first than read the rest
primary question;
is electrostatics dimensional and  how many dimensional it represents?
ONE SIMPLE CONCLUSION FROM ALL THAT IS BELOW
If the electrostatics is able to create mechanical motion That means that molecules of the body and individual atoms of the  body is to be shaken ( moved) I was once saying about hammering effect in the spark gap.
Plasma is hammering spark gap contact and inertia is part of that. I was trying to envision or say picture that mechanism at  last 2 minutes of  video
http://www.youtube.com/watch?v=HKVyeQkW8j0
Well molecules of air are being shaken as well.
But where is interaction creating  FE.
How about if we have vertically placed  capacitor with two  horizontal plates
Lower plate is fixed but upper plate is suspended on the spring..
Would  that  upper  plate jump up down due to electrostatic charge?
And if it would and as second step we make that plate  not to move than what moves?
Something must move?
What the article I brought to your attention says, about monopolar and bipolar  voltages?
And using software to control repulsion ?
The wafer is holding  the  disc , even after charge is removed and there is a need to apply waveform to eliminate the holding force (free the wafer)-  Johnsen-Rahbek  method
And why is that?
Recent change to  article( morning Saturday 9:35 Am EST. )
QuoteWhen, while heaving two  plates of capacitor, one plate is suspended on the spring, than at no electrostatic
charge, dielectric constant of dielectric between plates is Er
But when electrostatic charge deflects upper plate of its position than dielectric constant of the dielectric between plates will change. Er +/-
That will make  capacitance change, and components of series and parallel equivalent circuit including stray capacitance to change..
QuoteNow you play with magnetic field if you wish.
But aren't we than talking about electrostatic resonance?
http://adsabs.harvard.edu/abs/2003PhRvL..91y3902F
QuoteThe Smithsonian/NASA Astrophysics Data SystemResonant Behavior of Dielectric Objects (Electrostatic Resonances)
Fredkin, D. R.; Mayergoyz, I. D.
Physical Review Letters, vol. 91, Issue 25, id. 253902 Resonant behavior of dielectric objects occurs at certain frequencies for which the object permittivity is negative and the free-space wavelength is large in comparison with the object dimensions. Unique physical features of these resonances are studied and a novel technique for the calculation of resonance values of permittivity, and hence resonance frequencies, is proposed. Scale invariance of resonance frequencies, unusually strong orthogonality properties of resonance modes, and a two-dimensional phenomenon of “twin” spectra are reported. The paper concludes with brief discussions of optical controllability of these resonances in semiconductor nanoparticles and a plausible, electrostatic resonance based, mechanism for nucleation and formation of ball lightning.
Electrostatic (plasmon) resonances in nanoparticles
Isaak D. Mayergoyz
Department of Electrical and Computer Engineering, Institute for Advanced Computer Studies, University of Maryland,
College Park, Maryland 20742, USA
http://physics.ucsd.edu/~drf/pub/PRB05.pdf
A surface integral eigenvalue based technique for the direct calculation of resonance values of the permittivity of nanoparticles, and hence resonance frequencies, is discussed. General physical properties of electrostatic plasmon resonances are presented. Strong orthogonality properties of resonance modes, a two dimensional phenomenon of “twin” spectrum and explicit estimates of resonance frequencies in terms of
geometrical characteristics of convex nanoparticles are reported. Second-order corrections for resonance values
of the dielectric permittivity are derived. Tunability and optical controllability of plasmon resonances in
semiconductor nanoparticles are discussed and, as a digression, a plausible plasmon resonance mechanism for
nucleation and formation of ball lightning is outlined. An efficient numerical algorithm for the calculation of
resonance frequencies is developed and illustrated by extensive computational results that are compared with
theoretical results and available experimental data.
It is known that nanoscale particles can exhibit resonance
behavior at certain frequencies for which the particle permittivity is negative and the free-space wavelength is large in
comparison with particle dimensions. The latter condition
clearly suggests that these resonances are electrostatic in nature. They appear at specific negative values of the dielectric
permittivity for which source-free electrostatic fields may exist. This is, in essence, the physical mechanism of these resonances
Electrostatic Resonance Oscillations of a Nonuniform Hot Plasma in an External Field
http://prola.aps.org/abstract/PR/v139/i2A/pA394_1
Stanford Research Institute, Menlo Park, California[size=0.75em]Received 8 January 1965; revised 8 March 1965; published in the issue dated July 1965
The frequency spectrum of a hydrodynamic model of a finite, warm, nonuniform plasma in an arbitrary external electric or magnetic field is considered. We find that the spectrum is real and the system stable, for an arbitrary configuration. A variational principle is given for estimating the eigenfrequencies. First-order perturbation theory is applied to a cylindrical plasma, and formulas are obtained for the first-order correction to the eigenfrequencies (resonances) for the case of an applied magnetic field or transverse electric field, arbitrary electron density n00(r), and arbitrary angular dependence e[size=0.88em]iμθ (μ=0, ±1, ±2, ⋯), the effect of the applied fields on the zero-order electron density being included. We find that for μ≠0, the modes have a two fold degeneracy, and that a uniform axial magnetic field splits the resonances in two. The first-order correction to the resonances is found to vanish for a uniform transverse electric or magnetic field. These results are discussed relative to other models and to experiment, and appear to be in agreement with the available experimental data for the behavior of the main dipole resonance in both transverse and axial magnetic fields.
Relative permittivity :
http://en.wikipedia.org/wiki/Relative_permittivity
QuoteThe relative permittivity of a material for a frequency of zero is known as its static relative permittivity or as its dielectric constan. Other terms used for the zero frequency relative permittivity include relative dielectric constant and static dielectric constant]
well frequency  zero: is frequency selected at time period chosen  by you from any frequency graph.
As electrostatic is immediate response to change than
We can take any part of waveform, and for that waveform  look for its electrostatic frequency zero
as long as this part has steady form of properties for given  delta t
... say upper horizontal  part of square  signal (length of say 10ns)
As long as you  on it it is for you just amplitude at no frequency for the given  10ns
Temperature dependence of the relative static permittivity of waterThe relative permittivity of a material under given conditions reflects the extent to which it concentrates electrostatic lines of flux.
In technical terms, it is the ratio of the amount of electrical energy stored in a material by an applied voltage, relative to that stored in a vacuum. Likewise, it is also the ratio of the capacitance of a capacitor using that material as a dielectric, compared to a similar capacitor that has a vacuum as its dielectric.
Trek’s video demonstrates two applications of Trek’s electrostatic clamping technology.
Please note that the wafer detection indicator appears in the upper right corner of the display on the front panel:
     WC = wafer present and clamped
     WP = wafer present but not clamped
     NW = wafer not present
look at that  video:
http://www.trekinc.com/apps/app_e-chuck.asp
ElectrostaticCommonly used for holding silicon wafers during lithography processes, an electrostatic chuck comprises a metal base-plate and a thin dielectric layer; the metal base-plate is maintained at a high-voltage relative to the wafer, and so an electrostatic force clamps the wafer to it. Electrostatic chucks may have pins, or mesas, the height of which is included in the reported dielectric thickness; a design by Sandia National Laboratory uses a patterned silicon-dioxide dielectric to form the pins.[10]
http://en.wikipedia.org/wiki/Chuck_(engineering)#Electrostatic
Coulomb Force
(http://scienceworld.wolfram.com/images/tealtab_topright.gif)
(http://scienceworld.wolfram.com/images/gradient-teal.gif)
(http://scienceworld.wolfram.com/images/spacer.gif)
Portions of this entry contributed by Leonardo Motta
QuoteThe Coulomb force between two or more charged bodies is the force between them due to Coulomb's law.
If the particles are both positively or negatively charged, the force is repulsive; if they are of opposite charge, it is attractive.
By the middle of eighteenth century, only the qualitative aspects of the electric force were known.
QuoteScientists started to speculate about the quantitative aspect of the force and the idea that the electric force could be similarly to the gravitational force, i.e., proportional to the inverse of the square of the distance.
In 1777-1785, Charles Augustine Coulomb (http://scienceworld.wolfram.com/images/crossrefs/biography.gif) proved experimentally that indeed the electric force was proportional to the inverse of the square of the distance.
Coulomb stated that the force that acts in two electrically charged bodies is proportional to the product of the module of their charges divided by the square of the distance d between them,
(http://scienceworld.wolfram.com/physics/cimg337.gif)
http://scienceworld.wolfram.com/physics/CoulombForce.html
Dechuck Operation of Coulomb Type and Johnsen-Rahbek Type of
Electrostatic Chuck Used in Plasma Processing
Gyu Il SHIM and Hideo SUGAI
1)
Department of Electrical Engineering and Computer Science, Nagoya University, Nagoya 464-8603, Japan
1)
Department of Electronics and Information Engineering, Chubu University, Kasugai 487-8501, Japan
(Received 17 June 2008 / Accepted 24 July 2008)
Coulombic or Johnson-
Rahbek Operation
Comparative study on Coulomb type and Johnsen-Rahbek type of electrostatic chuck used for holding a
silicon wafer in plasma processing is presented. The remarkable differences between the two types are found in
dechuck operation
where a high voltage applied to the chuck electrode is turned off to release the wafer from
the chuck stage. In case of the Coulomb type, an instantaneous large short-circuit current ï¬,ows exponentially
decreasing with a short time constant (Ï,, = 0.14 ms). In case of the J-R type, a non-exponentially decaying small
current is sustained for much longer time (∼1000 ms),
thus giving rise to the considerable delay of wafer dechuck.
The mechanism of such decay is explained by a microscopic bi-layer model where the interfacial layer is divided
into three distinct regions having their own capacitance and surface resistance.
https://www.jstage.jst.go.jp/article/pfr/3/0/3_0_051/_pdf
Model 646
Electrostatic Chuck Supply
http://www.trekinc.com/pdf/646sales.pdf
Below is picture of electrostatic chuck
Question: Aren't we dealing with primary mechanism of electrostatic chucking in TK device or OU devices in general?
Chucking is temporary energy storage is not?
And play with uni polar and bipolar charge as they do in commercial wafer eaching.
Is plasma controlled by electrostatic chucking?
Wesley
stivep
Quote from: jbignes5 on September 21, 2012, 04:51:15 PM
A: did you read the book or not?
B: The book is not about free energy it is about waves and how they can and will influence a biased wire. Just go to this link and go to the page I mentioned with the chapter Header: Lecture X
http://ia700402.us.archive.org//load_djvu_applet.php?file=4/items/ElectricDischargesWavesAndImpulses/ElectricDischargesWavesAndImpulses.djvu
The whole book is a treatise on what the power companies learned over the years about switching the gens on and off from the power lines. What effects shorts to ground have on the lines and the transformers on each end. The resulting waves of both damped and undamped waves are talked about in the book. I would suggest reading the whole book but I guess no one wants to educate themselves. Instead you would rather sit and postulate about subjects you have no clue about.
You know how I know you have no clue about them? Because it says no one has really delved into the transients and what effects they have. We know little about this stuff because the transients were always shunted to ground. Which is the only high capacity they could shunt into. Read and learn what the professionals who works on those systems learned by trial and error.
The system that TK devised is on par with a Tesla system.
The reference that I made to the short clip was about the NEWSPAPER he was holding. Not the coil. Ever heard of the Tesla Death Ray? It could be very well that the can is empty and is only the target of this Ray gun. It is after all on the one end of the coil. Who knows at this point.
worth reading
Wesley
T-1000
Zeitmaschine
Quote from: stivep on September 22, 2012, 03:04:18 AM
Since I'm usually a little bit slow on the uptake, has this something to do with the bank of capacitors seen in the yellow tent presentation?
Below the first image shows a bank of high voltage (one-phase) capacitors connected to some 50Hz microwave oven transformers. Allegedly the result is, that the consumed current of those transformers goes down from 180 to 100 amps, as stated in the video.
The second image shows a bank of three-phase capacitors connected to a Kapanadze device running a huge three-phase motor.
Now the question arises: Are these capacitors in the TK tent presentation necessary in order to compensate the induction of the huge three-phase motor? If so, then why they are obviously still/already connected in this video without the motor (third image)?
TK takes measurements on the heating elements hence the device is running without motor (and without the slightest noise due to HV and/or HF), but I can't spot any difference in the wiring concerning the bank of capacitors (they are fixed wired without any plugs or switches).
Hence if the conclusion should be that these capacitors are not necessary in order to run the motor, then the only remaining conclusion can be that they are necessary in order to run the device. Got you TK. :D
So (since the huge coils are phony anyway) any ideas how to connect a capacitor of some sort to a 50Hz transformer of some sort in a way that the transformer provides more energy than it consumes?
jbignes5
Quote from: stivep on September 22, 2012, 04:06:42 AM
worth reading
Wesley
Yes it is. And finally you are putting two and two together Stivep. When Tesla said this new form of electricity was static like he meant it was a mixture of both electricity with static properties. If you look at the field of a Rounded conductor you can see that the magnetic field is Circular and only the electric or dielectric field is open ended. This allows free charges to enter the rounded conductor from the environment and is the gateway to free energy.
The TK device seems to be just that. The large copper coil is an energizer that is connected to ground. The high voltage pulses discharge into ground but before they propagate down the coil they induce or energize the inner coil into a pulsating AC style agitation by the intermittent shorts the spark gap provides. The spark gap does a great many things and the spark is not really what we should be focusing on.
What I suspect is that TK read about Tesla's wireless system and saw a way to creat a capacitor of very large capacity. This is the two ground connections of the 2004 device. He then hooks a coil between them forming a LRC circuit. And the spark gap is but a Tesla concept of increasing the power. Again I reference this:  http://www.tfcbooks.com/tesla/1919-05-00.htm
If you goto figure 12 you will see TK's device on the lower right. Now in order to get it working you just need to add figure 19 to strengthen the pulsations of the coupled two systems. It even talks about watering around the grounds like TK did to get it to work even better. This is to increase the capacitor plate size of the two grounds.
Now how TK did the other examples I don't know but the 2004 video is completely explainable.
That book opened my eyes to the facts about waves and how they propagate in straight conductors. If they have coils things change a bit. Lets say you have a gun like apparatus. And it fires not solid bullets but electric bullets. Firing the gun normally in a straight like means that dissipation of the speed of the bullet is normal. But when you add a coil things change a bit. The coil will change the bullets speed and resulting force and also induce a voltage as well. The path to ground also has it's attractive force on the bullet. It's like a vacuum to the bullet, sucking it into it's capacity via the conductor connected to ground. You also have BEMF resulting from the shot fired and this is where the AC portion is fulfilled. The only thing you need to do is figure out how to hook the load on and I believe that is pretty easy to tell how he did it. One to each ground. Since there is a coil each end of the coil will be at a different potential then the other. This gives direction and flow of AC current will naturally be formed.
