0 Members and 49 Guests are viewing this topic.
sparks
Quote from: verpies on September 23, 2012, 03:37:45 AM
No, this process merely converts the electrical potential energy into the kinetic energy of mass. (mv2)
  A spacecraft slingshotting it's way through the solar system uses the gravitational field of various planets.  Does the spacecraft convert the gravitational potential energy of the planet into kinetic energy?  If that is the case then gravity becomes a scource of energy and not a force.  The antiquated laws of conservation of energy have been broken consistently for at least 80 years.  There is no conversion from potential energy to kinetic energy there is only conservation of inertia.  An automobile takes a portion of it's mass/velocity and creates photons in the engine.  The photons are then radiated by various methods and the inertia of the vehicle is changed simultaneously with the photon radiation.  The fuels rest mass is converted into energy.  The vehicles motion relative to the Earth is simply because it no longer has the same inertial state as the Earth.  The same for a rocket launch.  Pounds and pounds of fuel are amassed within the vehicle.  The mass of the fuel is changed and accompanied by this change (energy creation) the rocket alters it's inertial state relative to the Earth's inertial state and motion is detected between the two forms of matter.  This strange dark matter energy etc the establishment is dishing out is bullshit.  The Universe was set into motion by the creator and will not come to rest until she decides it to.  UFO's are always accompanied by strange lights.  These strange lights appear to be coherent light.  The photons created on board need to be radiated otherwise no motion.  Our jets intake molecules in the upperatmosphere with certain inertial states.  They are suspended up there because they are not in the same rest inertial frame as the ones deeper in the gravity well near the surface.  The molecules restmass conjoins with the vehicle frame.  The rest mass of this acquired propellant is converted into energy which we barbarians dump out the vehicle exhaust.  The UFO exhausts the photons by radiating coherent light and not the mess we are dumping out exhaust pipes all over creation.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
sparks
Quote from: forest on September 23, 2012, 04:08:34 AM
Good questions.I assume that in power station they have a load adjustment device, but I have no knowledge how it work. Maybe just excess energy goes to ground ? I'm perfectly convinced that even 50Hz power grid is oscillating LCR system and if they really wanted they could add stationary waves to recover most of energy not used in our homes back into the grid. Just like Tesla envisioned his wireless system. And if so then it's just a matter of initial energy 'kick' and a small looses compensation to get what TK has. Yes ,it's just 0.0000000001% or something like that.
Think this way , you are asking important questions. I would add equal ranked questions :
1. What is that nature of Lenz law ?
2. Why electrons do not move with light speed in wires but in vacuum tubes they can ?
3. If you want more amps do you need more electrons in wire or more speed of current or any of this ?
  Tesla moved on Westinghouse did not.  Tesla invented motionless dc generators using ac input.   This would have allowed ac in Westinghouses power plants to power edison's existing dc distribution systems.  Westinghouse submitting to his testosterone levels came into conflict with Tesla on that one.  Tesla's diodes are way more efficient than the semiconductor messes we use today.  Tesla moved  up and down the emspectrum in his inventions while the rest of the dimwits stayed stuck at 60hz.  He moved up to millions of volts at ultraviolet and beyond while dimwits hooked up locomotive steam engines to alternators producing 60hertz.   Tesla moved on into beta accelerators while Westinghouse fed billions into the steel and carbon commodity traders producing the junk we have today-which to the laymen is as mysterious as the core structure of a blackhole.  Tesla proposed impulse energy to excite local electrical lc circuits to transmit power from scource to load  (always including a generation system to pitch it to the existing power structure)  Westinghouse and GE continued to dickswing in the battle of the currents.  Powerplant operators realizing the amount of losses accompanied by ac transmission lines finally drew a truce with GE tech and now use dc between substations.  Of course they don't use Tesla motionless dc generators but waste enormous amounts of input in heat sunk semiconductors which are barely worth running at all unless the line impedance is huge.  The power companies in their greed have allowed the entire grid substructure to decay to the point that a major solar event that alters the permeability of the transformer core metals (which act as 60hz choke coils)  could collapse the whole system beyond the ability of the monopoly to repair it.  Why do power companies transmit high high voltages.  To reduce unmetered current losses in their conductors.  The voltage appears across a high impedance coil.  The magnetising current is the only energy they expend yet they charge you for the secondary currents.  The thing they fuck you with is the powerfactor.  This is when voltage and current is in phase.  If you take the voltage and current out of phase their wattmeters don't spin.  They frown on this and regularly charge facilities known to derive their power this way with surcharges.  Need I go on to show how people chasing gold care little about who they trample upon in their pursuit of the elusive golden ring suspended from a fishing rod shoved up their ass and caused to appear just beyond their grasp.  The faster they go the faster the ring goes meanwhile get the fuck out of my way can't you see I'm chasing this here golden ring. :o
Think Legacy
Spread the Love
jbignes5
 The thing that gets me is Tesla discovered that bessemer steel was the best soft steel ever for magnetic interactions. He even gave this to westinghouse and for a time westinghouse made the best transformers in the world. Now if that was the case why did they drop it? Their investment was not to become the best manufacturer of transformers it was to become the best manufacturers of power generation equipment and increase the profitability coming in from that power generation equipment. Hence the reason for dropping the bessemer steel in their transformer products and keeping such an inefficient power system for well over 100 years now.
We could have better systems but then it decreases the income they get now so why would they change it?
Here is an excerpt from eric dollard explaining what I showed in the book link.
http://www.youtube.com/watch?v=64yKW9FSsBY&feature=related
http://www.youtube.com/watch?v=f5ZWrjcrPl4&feature=relmfu
This is very important.
http://www.youtube.com/watch?v=6lqMiZPO9TM&feature=relmfu
http://www.youtube.com/watch?v=XsrbaCJo3Qw&feature=relmfu
http://www.youtube.com/watch?v=vwu8rspxQWE&feature=relmfu
This seems to answer a lot of questions as well. Plus check out the sparking part and how the camera doesn't pick up the spark sometimes.
http://www.youtube.com/watch?v=2kOQr7hZA70&feature=related
sparks
Quote from: jbignes5 on September 23, 2012, 03:25:53 PM
Power companies use aluminum as a core material in the stepdowns all around town.   The generating plants struggle economically while the grid owners reap the profit.  Voltage regulation due to load changes is barely addressed in the local grid while all sorts of voltage regulation schemes are used at the generating plants.  The reason ac flourished is not because of the bullshit people say about dc losses over distance it is because of the expense motor generator sets cost to bring down the high voltage dc to less dangerous levels to occupants of the electrified structure.  The amount of disinfo about electricity is astounding.  The egyptians had electicity.  The Iranians.   King Solomon not only had electricity he regularly transmutated elements into gold using neuclear transmutation of silicon salts.  One fucking lie after another for centuries. Neuclear weapons were used on the cities of Sodom and Gamora.  The Gods of old are fucking high tech ancient civilizations controlling their slaves doing majic shows for them.  Take a man put a bunch of Gold draped all over him and set him on top of a pyramid in the blazing sun of the desert.  The fuckng guy lights up like a torch.  Then hustle this actor away in some box and stash the demigod in an isolation cell.  Then fire up the pyramid into a laser show and you better believe any dimwits are going to do the Pharohs bidding in earnest including bringing his newborn children down to the priests so the pediaphiles can have their way with it.  They had the Myan Indians running around killing thousands of people a year including ripping the hearts out of newborns and feeding them to the PRIESTS in appeasement for such things as the Sun stopping to burn due to solar eclipses and crop failures due to draught brought on by solar flare activity every 11 years.  Every ll years the Mississippi river dries up and we get all this paranoia dumped on us about something that has been going on forever.  The farmers know it the barge operators know it but the sheeple get mindfucked everytime it happens.  Theres a bunch of micronesian people who believe a cigarette lighter is a holy object.  The Myans worship contrails left by ancient jet aircraft upon which their Gods come and go.   They got their pyramids all worked out so  serpent shadows appear to be coming from the pyramid pinnacle to commemorate the day some ancient aviator the priesthood calls God arrived. This ancient teacher educated them instead of killing them and stealing their gold.  The priests got educated and quickly turned this knowlege into increased political assaults upon their own tribe.   Bacon was a genius that rivaled Rembrandt.  In resistance to the priesthood he gave us the scientific method-shakespeare-the English langauge-.  This he had to do in secret because the priests who have always coveted knowlege stop at no length to retain their power over the uneducated.  What God was using a light show to tell Moses how to get a little food and water for the slaves he had led to their death of starvation and dehydration in a desert.  According to the learned priests of Zion Moses had to turn his tribes and their descendants into tools of evil to install the burning bush God in full control of the entire planet.  Fullfilment of a burning bush agenda?  How stupid can a zionist be?  The descendants of this tribe still controlled by various priest's bullshit are now allied with the Egyptian church of England's bullshit artists and the Roman church bullshit artists  working on WWIII because WWII didn't reduce the slave population to the manageble levels they anticipated.   Muslims-Buddhists-Christiens-Jews-on and on all fucking with other people's minds instead of freeing their own.  Truly pathetic creatures lacking any degree of self-awareness and esteem.
Think Legacy
Spread the Love
Magluvin
Quote from: sparks on September 23, 2012, 07:30:37 PM
Can you provide any links to this info you are quoting?  The 'grid owners' are cheating the power companies? Like, down the line would there not be any required use comparisons?
Crazy post Sparks. ;]
Mags
