0 Members and 113 Guests are viewing this topic.
starcruiser
So, when the transmission line (wire) gets connected the first thing to appear is the electrostatic field, then the magnetic, is this Electrostatic one the one that Tesla experienced that would kill when he switched the generators online?
My thinking here is that the absence of the magnetic or reduction of would increase current production initially then reduce when the magnetic field establishes, just my thought on this if we are currently looking at electrical theory wrong.
Regards,
Carl
jbignes5
That is exactly what I think. It was the establishment of the electric field that Tesla was seeing and how powerful that impulse can be when it is at very low rates of impulses. It is this field Tesla was investigating and how intensity of these impulses have a greater power then the magnetic field. The instantaneous on and off is another effect that Tesla was investigating and hence why he was coming to the conclusion that this field has a higher capacity of speed in it's formation. Ie faster then light. This is never more apparent then watching High voltage corona emissions and intensified electric field emissions that go with the corona (lightning like intensity).
I have to look for the pictures of the emissions again. I'll edit it once I find them.
Besides the tuft on the end of the rod you can see the intensifies lines all along the rod.
Frederic2k1
Quote from: Neo-X on September 24, 2012, 06:33:14 PM
@Frederic2k1
I dont the get the point why the government keep using oil if they can use free energy as a source of money? For example they build a free energy machine then connect it to the transmition line to power the residential home and charge them?  They can also charge electric car user by establishing a battery charging stations. Government earn money from us and we can have a very cheap electric bill.
the government wouldn't earn money with free energy, the government don't own the electric power company, they only earn from taxes. So with this in mind in the oil there lies the money, because when you drive to the gas station the government will receive taxes from you buying gas for your car.
The government are only greedy criminals when they hide free energy technology from the people.
I don't know where this will end, hopefully not in some very pessimistic peak oil scenario.
starcruiser
I see that on my 24" tesla coil when it is radiating into the air
So we need HV impulses into a transmission line (open or shorted) to generate the standing waves and setup the electrostatic field and need to time the impulses to the resonant frequency or a harmonic of it.
Couldn't we use a transformer (core type uncertain here) to create a bucking config on the primary and a single coil on the secondary, we could then drive the primary with a couple of transistors and reap the im[pulses from the secondary output.
itsu showed this in his video for the dally project, I bring this up since his experiment showed impulses out. I would like to know the voltage and the pulse width nsec
this might explain nicely with what TK was doing with those commercial transformers.
Regards,
Carl
jbignes5
I guess my point is that if we use the old tesla patent for the electric dynamo machine the way it was meant to be used you could generate very heavy currents in the rotor coil from a very high voltage field coil and get no associated kickback like in regular dynamos of our age. It is a dynamic transformer  that will generate a heavy current for little current input.
I think TK did this partially with his design but because it is not dynamic or revolving the generation of current is limited whereas Tesla's design was not limited in any way because it was a revolving generator. This changes things if this in fact is true. One of the very experiments that Tesla did was show the effect on metals of all sorts and densities of those metals. Most were explosive if the density of the metal was not sufficient to hold itself together. On the other hand if the metals were stout enough they held together and a huge current could be motivated from the metals. All from this energizing electric field.
Again let me show the patent and see if you see what I see now knowing what I have shown.
http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
Remember the exciter is High voltage and not a low voltage generator. The field coils are wound around a round or oval core and the wires go all the way around the core much like a toroid is wound. The patent shows two views of the rotor core. Don't get confused about that. All of the components can be used all on one shaft and the field coils are supposed to be used in the opposite direction of the rotor spin to increase the efficiency at starting speeds. The prime mover for the generator must be designed  exactly as shown per Tesla's instruction. Any magnetic field created in the rotor core that leak out will go to the field core and coincidentally cut the field windings generating more High voltage.
I suspect the field coils have a textured electric field due to the copper windings orientation and wind. With the rotor spinning trough this field it super excites the rotor coils into huge currents. This is the motor/generator he designed and had Westinghouse Make for him in 1932.
He went back to this design after WardenCliff was demolished because no one wanted that wireless system.
Tk's design also mixed in the wireless receiver portion to stimulate two separate ground connection into a heavy AC current flow.
As I said before this link shows in figure 12 how that was accomplished: [size=78%]http://www.tfcbooks.com/tesla/1919-05-00.htm[/size]
In Tesla's dynamo version you don't need the grounds although virtual grounds would be better because of the mobility of the vehicle. There is missing control circuitry to the patent I believe but it should be crudely workable the way the patent shows.
