27Bubba
I often asking myself a following question, why TK has gone to all of the effort to create a thincan container? The only answer I can come up with is because it must contains fluid inside (transformer oil) and it operates in above room temperature..  For any other setups he could easily use some plastic container or build a wooden box.. and call it good. I don't think he build the thincan because he was concerned with any Rf interference or such and want it contained..
So, what is inside that must be submerged in oil and generate juice?.. The only thing I can think of is some exotic capacitor, transformer, or..?.  I'm just a rookie in this I'm sure scientific minds chime in ;).. Good luck.  8)
@Zeitmaschine
Thanks for detailed info, I'm sure your efforts are appreciated by many here, me included. Keep up the good work.. :D ;D
xenomorphlabs
Quote from: Zeitmaschine on October 01, 2012, 02:10:08 PM
So, what does this all mean? Do I get additional power from thin air due to the resonance?
To understand what you are doing, you might wanna familiarize yourself with the concept of reactive power or AC power in general.
Every time inductances and capacitance occur together in an electric circuit you will have a reactive component introduced by the phase angle phi.
Inn addition to the real component you have an imaginary component with the real power vector representing the real part and the reactive power vector representing the imaginary part of the complex number of apparent power.
S = P + jQ
Measuring AC power is not straight forward.
This video might help understand : http://www.youtube.com/watch?v=JrDMT6lSeEo
jbignes5
Quote from: 27Bubba on October 01, 2012, 03:41:48 PM
So, what is inside that must be submerged in oil and generate juice?.. The only thing I can think of is some exotic capacitor, transformer, or..?.  I'm just a rookie in this I'm sure scientific minds chime in ;) .. Good luck.  8)
@Zeitmaschine
[size=78%]Let A, Fig. 1, designate any given coil the spires or convolutions of which are wound upon and insulated from each other. Let it be assumed that the terminals of this coil show a potential difference of one hundred volts, and that there are one thousand convolutions; then considering any two contiguous points on adjacent convolutions let it be assumed that there will exist between them a potential difference of one-tenth of a volt. If now, as shown in Fig. 2, a conductor B be wound parallel with the conductor A and insulated from it, and the end of A be connected with the starting point of B, the aggregate length of the two conductors being such that the assumed number of convolutions or turns is the same, viz., one thousand, then the potential difference between any two adjacent points in A and B will be fifty volts, and as the capacity effect is proportionate to the square of this difference, the energy stored in the coil as a whole will now be two hundred and fifty thousand as great. Following out this principle, I may wind any given coil either in whole or in part, not only in the specific manner herein illustrated, but in a great variety of ways, well-known in the art, so as to secure between adjacent convolutions such potential difference as will give the proper capacity to neutralize the self-induction for any given current that may be employed. Capacity secured in this particular way possesses an additional advantage in that it is evenly distributed, a consideration of the greatest importance in many cases, and the results, both as to efficiency and economy, are the more readily and easily obtained as the size of the coils, the potential difference, or frequency of the currents are increased.[/size]
balphom
zeitmaschine, tk is not drawing the big current from the tin can he is doing it from the ground look at the green box video they are measuring the counter current from the ground
