0 Members and 70 Guests are viewing this topic.
gyulasun
verpies,
This what I think:
He means when there is no permanent magnet included in the coil the LED is not lit by the "static electricity" brought near to the coil.  And when there is a magnet in the coil then "something" initiates induction in the coil when "static electricity" is applied again.  "Static electricity"  (applied between the top and the bottom of the coil)  seems to come from a line output transformer.
I assume the line output transformer includes the HV rectifier diodes to make the static field.
EDIT  well, he already explained some more while I was answering.
bass
I do not know you have discussed here Mustafa007 scheme earlier this year. This man claimed that he had solved the secret of Kapanadze and drew a rough diagram. I personally talked to the man and he told me how he got through the current transformer 3000 W while consuming 400 watts.
This scheme is just the principle of the series resonance and the principle of amplitude modulation. The scheme must be working  as
principle.
Output only not shown demodulation
bass
I think it is no trouble to assemble a simplified diagram to determine operability
gyulasun
Quote from: semenihin-77 on October 03, 2012, 06:16:35 AM
Neodymium magnet in a coil and static electrofield, induces a current in the coil is connected to the LED.
Floor without coil neodymium magnet does not light the LED in the electrostatic field.
Hi Semenihin-77,
Have you already checked the waveform induced in the coil by an oscilloscope? if it is possible?  Just use say a 1 kOhm load resistor across the coil and watch the voltage across it by the scope.
Thanks,
Gyula
