0 Members and 67 Guests are viewing this topic.
xenomorphlabs
Quote from: bass on October 03, 2012, 07:02:20 AM
I do not know you have discussed here Mustafa007 scheme earlier this year. This man claimed that he had solved the secret of Kapanadze and drew a rough diagram. I personally talked to the man and he told me how he got through the current transformer 3000 W while consuming 400 watts.
This scheme is just the principle of the series resonance and the principle of amplitude modulation. The scheme must be working  as
principle.
Output only not shown demodulation
At a first glance there is components that don't make sense.
On the right side he has an output of 220V then from there  on the bottom he goes through something that is labelled "12/220" which feeds the input rails labelled 220V ?
Did he mention to you how he handles resonant extraction without killing resonance?
No capacitance and inductance values are given, so this could not be replicated at all.
EDIT: He feeds a battery charger with the 220V and the 12/220 thing is an inverter then probably. So the battery charger/battery are his load, 3000W, hmmm...
verpies
Quote from: semenihin-77 on October 03, 2012, 06:06:57 AM
What is the source of static electricity?------ http://youtu.be/6un4xmF6FOk
That is not static electricity. That is a high voltage pulsating DC electricity between two electrodes.
bass
Quote from: xenomorphlabs on October 03, 2012, 07:46:09 AM
Sorry. I had to immediately translate.
This scheme is simply made ​​up by the video of the tin can and the green box.
Capacitance and inductance is taken such it is. Resonance frequency is adjusted by generator.
Power 3000 Watts was obtained on the principle of the second scheme, which, without the battery.
see here
http://realstrannik.ru/forum/39-kapanadze/47235-rabochaya-sxema-generatora-kapanadze.html
Zeitmaschine
Quote from: xenomorphlabs on October 01, 2012, 04:56:42 PM
Every time inductances and capacitance occur together in an electric circuit you will have a reactive component introduced by the phase angle phi.
Yes, and TK seems to care about this phase angle, so we can see a bank of 12 three-phase capacitors in the tent presentation.
Quote from: sparks on October 02, 2012, 05:46:45 AM
Tesla would never have wasted the current flow charging the capacitor. He would have used the current to charge the capacitor to drive a load by installaing a current transformer on each leg of the capacitor leads. Then he would have flipped the capacitor over and shorted it back into the battery again using the reverse current to drive a load.
Instead of flipping the capacitor flip the current, say 50 times a second. Wouldn't that be much simpler?
Talking about capacitors: These capacitors on the image below are neither there because of the motor nor they are there just for the fun of it (because they are rather expensive). Hence my best guess is, these capacitors are neccessary to run the device.
Quote from: bass on October 03, 2012, 03:04:10 AM
In the video of the 2004 Kapanadze not measure frequency. So we can not say that there is 50 Hz.
The inverter provides 50Hz, the ammeter shows the amps correctly, so there is no reason not to believe it is 50Hz.
A transformer that runs with high frequency (in order to reduce size) would mean to convert the 50Hz to DC then chop up the DC by means of a second inverter (capable of doing 5KW?) to high frequency (like in a switching power supply) and then somehow modulate (not convert) this high frequency back to 50Hz (so the ammeter can measure correctly). And this all in a small tin can. That is way to bizarre.
My inner voice tells me that the TK device neither makes use of high voltage nor of high frequency (except for showcase). You don't need three-phase capacitors for high voltage or high frequency. They are not suitable for that. They are rated at 400V/50Hz.
Thus I think capacitors, coils and transformers at 50Hz are the secret of Kapanadze. Only remaining thing to do is to connect them in the right way. :)
xenomorphlabs
Quote from: bass on October 03, 2012, 08:23:34 AM
see here
Thank you.
Well, a resonant circuits that is connected to a load will loose resonance if the energy is not cleverly extracted.
I don't see this being taken into account in that circuit. I have myself made dozens of experiments where
exactly that happenend, that the resonance condition cannot be sustained with a load connected.
The load has to be arranged non-reflective to the source. But this is not meant to discourage anyone who wants to replicate it ...
Quote from: Zeitmaschine on October 03, 2012, 08:35:09 AM
Well, the phase angle always occurs when L and C are involved, whether he cares or not. :D
But since TK is smart he utilizes power factor correction capacitor banks to tweak the PF, standard EE procedure.
My initial point was to hint you to how the reactive power component and voltage rise at resonance are introduced.
