0 Members and 163 Guests are viewing this topic.
xenomorphlabs
Quote from: d3x0r on October 05, 2012, 09:16:09 AM
I don't think there's anything that really indicates the output is AC.  The Dally variant uses a PC ATX power supply... plugs into AC, right?  but, the first thing that happens is the AC goes through a rectifier, so DC would be just as good.... heaters, lamps, etc, all would work just as well DC...
Here are two indicators :
- An AC clampmeter
- A frequency meter
@Wattsup: DC has no frequency really. It does not change (alternate) the amplitude periodically according to it's definition.
Even though i kind of like Hector's theory that DC is really AC with a suuuper low frequency like 10 ^-x Hz.
But you certainly referred to pulsed DC.
Pulsed DC-like waveforms could occur when he uses a (cheap) inverter (circuit) that creates rectangular waveforms, which would work with lamps
as load, but motors,TVs etc. would not like it. Not sure though if the clampmeter would be able to measure it correctly because of the harmonics.
The issue you point out with the connection of the ground wire is something to think about. Assuming the circuit is not closed, Tesla did also experiment with one-wire circuits.
semenihin-77
Ð'ыл у меня инÑ,ересный опыÑ,, я Ñ,огда его не осознал в полной мере.
Ð'оÑ, он http://www.youtube.com/watch?v=mFn4nMRZoEg
СуÑ,ÑŒ в следующем: качер, рабоÑ,аеÑ, в авÑ,орезонансе, внуÑ,ри него медная Ñ,рубка с разрезом. К эÑ,ой Ñ,рубке подключалось через лампочку заземление. Самое инÑ,ересное чÑ,о при эÑ,ом загоралась лампочка, и гораздо ярче вспыÑ...ивал Ñ,,иÑ,он качера!
Ð'оÑ, и возникла мысль: Ð'зяÑ,ÑŒ 2 конÑ,ура, они рабоÑ,аюÑ, в резонансе, и добавиÑ,ÑŒ Ñ,реÑ,ий, он будеÑ, Ñ,януÑ,ÑŒ энергию с земли. ЭÑ,у энергию использоваÑ,ÑŒ как прибавку к накачке конÑ,уров. Ð' иÑ,оге мы должны получиÑ,ÑŒ саморазгон каÑ,ушек. Ð'се чÑ,о нам осÑ,аеÑ,ся, эÑ,о снимаÑ,ÑŒ сливки и не даÑ,ÑŒ взорваÑ,ься конÑ,урам, для эÑ,ого и нужен защиÑ,ный разрядник.
Мне кажеÑ,ся эÑ,о будеÑ, ближе к Капанадзе чем всякие наноимпульсы.
I had an interesting experience, I did not realize it fully.
Here he http://www.youtube.com/watch?v=mFn4nMRZoEg
The thing is: Kacher, works autoresonance, inside a copper tube with a slit. This tube connects via bulb grounding. The most interesting thing that this light comes on, and a much brighter flashed Fitton Kacher!
That's the idea: Take 2 circuit, they are working at resonance, and add a third, it will pull the energy from the earth. This energy is used as a supplement to the pumping circuit. As a result, we have to get acceleration coils. All that's left is to skim and not let explode contours, and the need for this protection gap.
I think it will be closer to than any nanoimpulsy Kapanadze.
jbignes5
 This is as close to the real process as you guys have gotten as of late. Congrats.
Think of the ground system he uses as a super large capacitor. It has tons of charges in between the plates to move and use that inertia after it moves. He is borrowing the mass of charges between the plates of the ground loop capacitor. This can also be replaced with antennas. Or a very large capacitor with an inductive coil wrapped around it. Yes you can use a electrolytic cap and broadcast the energizing field into the cap. An open bifilar cap can also be substituted for the cap but it should have an oil dielectric to make it go very very high above it's normal capacity.
If we look at the bifilar wind even on a multi-layered solenoid if we always keep the alternating wires like this we will be able to get even more amplification of the input.
x=(- conductor)
y=(+ conductor)
xyxyxyxyxyxyxy
yxyxyxyxyxyxyx
xyxyxyxyxyxyxy
xyxyxyxyxyxyxy
yxyxyxyxyxyxyx
xyxyxyxyxyxyxy
We will need to twist the wires once after each change in direction. This is to keep the separation of each wire fully from the other strand. This should also increase the polarization of the solenoid and increase the strength as well.
Just remember that the input to the coil will never be in a state of conduction. Only static induction will be involved(capacitance). this Bifilar must be around the drive or load coil. In order to contain the load better it should have a ferrite core or very soft Iron rod core. As small as the rods could be and the better the reaction from the iron rods. Maybe iron wire could be used here. The smaller the better. They should be in the same oil as the whole unit is in. I suggest making it a two stepped coil. Meaning a thicker coil within the bifilar connected to a less thicker coil to raise the voltage to whatever you need.
--------------|(--Input a)
.................|(--Open b, antenna or ground)
....Bifilar.....||......................|(--Output)
--------------||....Voltage......|
...Current......(Solenoid).....|
====Ferrite===========
..Current.......(Solenoid).....|
.....Bifilar....||......................|(--Output)
.................|(--Open a ,Antenna or ground)
--------------|(--Input b)
The current version of the Solenoid is heavy gauge wire and the Voltage version is made of finer wire multi-layer.
The open a and b are the unconnected ends of the capacitance bifilar winds. They can be connected to a capacitor matrix. This matrix is just a parallel capacitor that is center connected or grounded via a strap to each other.
(--Open b-------| |-----|
..................................|--------Not connected or Antenna or large mass of metal
(--Open a-------| |-----|
Each version Not Connected, Antenna or Large Mass has it's output limits. There is also a version in dual power mode. But that is the ground connectors to replace the ends of open a and open b. Using the ground will always yield more power in the end because of the massive inertia that goes along with the mass of the ground. Remember this is just a sloshing barrel style energy generator. Once the capacitance is charged it takes little push to get it to vibrate and because the mass is very high in the ground that sloshing moves a lot of charge back and forth through the load and the resistance of the ground can get quite high. This resistance to the sloshing is what the inertia is about and where the current comes from in this type of system.
In an air system like using antennas the resistance is supremely higher. This resistance can be measured by the breakdown of the air into conduction via a spark gap. The voltage (electric) field is a very different beast then a current (magnetic) field. The voltage field has an infinite range with time being the only limiter.
If there was a way to amplify this voltage field signal to incomparable levels this is the way. The open ended bifilar shows all of the classic signs of being a OU device. You are separating the source totally from the load except for the signal end.
My idea is to use a joule thief to oscillate for cheap and use that for the signal source. With enough voltage in the field to super excite the load coil into a heavy current situation then loop it with the isolation and diode bridge to recharge the source. This isn't gonna be The typical style transformer here.
My capacitor setup has not been tried yet so I can't say with accuracy what it will do. We might just have to connect the cap directly to the open a and b connections.
This is the cap/coil I was talking about earlier in my posts. A capacitor with inductive principles.
xenomorphlabs
Quote from: jbignes5 on October 05, 2012, 11:51:53 AM
Suppose the earth responds with sloshing, how do you prevent that huge DC offset ?
The clampmeter would not display a correct measurement with such a huge offset.
jbignes5
Quote from: xenomorphlabs on October 05, 2012, 12:17:57 PM
  I would suggest using a transformer like setup. This way the dc which is direct current gets stripped away or blocked.
And to tell you the truth the amp meters were acting funny because of the high electric field. It had little to do with the current. This is a well established reason when using high rf like fields. Although this is not an rf field it does share some of the rules that go with it. Just think though this field can not be blocked. It permeates everything. Tesla talked about the effect on man in this field and if it is of sufficient cycles that it can enhance the human in that field. He talked about working for days on end in a 20 kilocycle field and not even realizing it. Wasn't tired, felt very good and energized. But he said there was also a down side. After the three days he fell asleep while in the field and woke up the next day feeling very refreshed and ready to go. He thought that this could be very addicting and thought it needed more investigation. The electrotherapy devices were spurred on by Tesla in this direction.
