0 Members and 477 Guests are viewing this topic.
a.king21
Zeitmaschine: If you look at Tesla's experiments - he found that the higher the voltage and frequency, the less resistance.
So he was able to transmit energy through the ground much better at HV. I have found difficulty with 3 kw through the ground, only maxing out at about 800 watts at 230 volts 50 Hz. So I base my conclusions on my experiments and reading Tesla's experiments. Oh and of course Kapanadze's builds.
Ganzha
Quote from: a.king21 on October 08, 2012, 07:19:05 PM
Wattsup:  Some pointers.
I am becoming more convinced that the ground has high voltage in it; sent out by the device and reflected back.
He definitely needs a very wet ground. That's a common denominator.
He definitely works with high voltage. That's a common feature. His coils are bifilar. They are either a step up transformer, or a step down transformer or BOTH!
Here's a hint. I asked about a 500 kw device. He said the secret part would not be much bigger than the 2 kw version.
It is possible that he sends out pulsed DC and mixes it with conventional AC. - That's what I'm working on. It would also explain the diodes.
Why high voltage? How else can you get  kwatts with such a light build? And remember the epoxy resin and high voltage wire and braid. All indicative of HV in the build. If anyone knows how to get Kwatts with a light build without using HV then I'm all ears.
I found an unexplained high voltage component when mixing pulsed DC with AC. Maybe you should try it.
Good luck.
Right!
You are absolutely right!
here is prove http://youtu.be/FS3Pdt4hTKk
TK may send  energy via very thin one string wire that could be hidden between ground "camouflage" wires
It means it is a trick
in Aquaruim is a step down transormer or it is some kinda special device that invert "Tesla one wire energy" into 2 wires normal electricity
240 v 50-60 hz
One another prove of that idea is in island the Hotel was out of power it time of TK demonstration. He just thifs enegry from Hotel
sorry my thinking thaty way!
elementSix
In the full length 2004 video,  in the first few minutes of looking at the coil.  The video guy pans over to the work table and on the table are a few round black discs.  They look like compressed iron powder and look like the same diameter as the round can along side the coil.  Anyone think they could be used inside of the can with coils wrapped in between a few layers of them???  Just throwing that out there..
elementSix
Ganzha
You sound right on track.  That  would be why they always use light bulbs for FE devices with tesla type coils.  They send the one wire power thru them a lot easier and don't need a converter right...?
xenomorphlabs
Quote from: Zeitmaschine on October 08, 2012, 08:45:30 PM
Question: At which level of voltage starts the generation/collection of Free Energy? Why should 2000V collect energy (from the ether/environment) but 220V not?
But audio amplifiers do not create Free Energy, do they?
When a 50Hz hum looks almost like a 100Hz wave on the plot what could this mean? Does this mean these are actually two 50Hz waves which are out of phase by 180 (90) degrees perhaps? Interesting!
The inverter runs with 50Hz and something else runs also with 50Hz, but out of phase till synchronization is established?
Another interesting fact: The lamps never go on instantaneously when the inverter is switched on. The lamps are switched on separately. Why?
The green box has two switches and it does not need the auxiliary plug to start. Why?
It is again the 2 time parameters that i referenced before in action, when you switch LC circuits ON AND off. Capacitors must be charged first. Nothing unusual about it.
100 Hz is just a harmonic of the 50Hz (caused by the core).
HV is used to create higher VARS. You must always think about what actually is the non-linear factor that miraculously establishes
the power gain in your system. It's not the tooth fairy or will simply happen by just connecting an earth ground. Electric trains e.g. would run for free then ...
