forest
Power sent from electric grid via thin wire is highly improbable. If we take aquarium 1 video there are two banks of bulbs there and switching them on/off does not make any visual dimming effect on the few bulbs hanging among trees. Device works from max power level down , opposite to the normal inverters or generators. With power sent from ordinary source it would require imho a bank of large capacitors to emulate such behaviour or balancing load faster then eye can recognize the effect. This is important clue I think....where is the rest of power when he switched off 4.5kW rated bank of bulbs ?
pix
@ Zeitsmachine
Quote:"The green box has two switches and it does not need the auxiliary plug to start. Why?"
Two frequency generators.That is my opinion.I remember on the very first paper describing TK device it was  mentioned event that happened between power grid in Ukraine and USSR.For some reason power grid frequency in Ukraine was lower than in USSR and because of this a lot of electric power had flown from the russian side to Ukraine grid. Steven Mark also did mention" study strange factors of out-ofthe phase transformers". The thing is- Steven Mark TPU didn't have any ground connection.
In the paper describing Kapanadze device, there was a symbol of the transformer, with connection between primary and secondary, marked by box with "delta f" sign.Clearly there is something on with frequency difference.
I think that secondary is a few turn big air coil in resonance,very high Q, a lot of kVARs oscillating- this is a "open side to enviroment". Primary is tuned for lower frequency- then we have effect of "sucking" this "enviroment resonance energy" from the secondary to the "energy sink" on the primary. So on the one side we have a resonating enviroment together with one coil , and as "energy sink" other coil tuned for lower frequency.
On the other hand, Tesla did stated that he know a method for releasing all energy of longer wave into shorter wave upon interference. As I remember, this was even laboratory tested by Corums as "ball lightning".
Sorry for a bit chaotic text.Please see attached.
Regards,
Pix
jbignes5
Quote from: forest on October 09, 2012, 04:07:40 AM
Auto resonance is the clue. The mystery coil is an auto resonance tuner for the load coil. This gives the load whatever it needs on demand up to the max of the drive(primary) and load(secondary) coils that he does show. He told us in the video I showed that there are in fact two coils in the shown coils and a mystery coil inside that auto resonates the primary to the secondary of the drive/load coil(shown).
As for the house version I think what he did was to show that he could use AC or DC to start the process. That is what the plugging into the inverter did. It was just a bypass to supply Normal AC to kick start the process and then it continues to work as normal. The hum was because it was ground looped in that attempt. I don't think he expected it to be so loud. The ground loop was not intended in my opinion since all he needs is one ground connection as per Tesla's teachings.
There is no doubt that He used Tesla's teachings to rediscover free conversion of environmental energy into usable power.
Now back to the Auto resonant transformer. We know that we can change or adjust resonance by changing the frequency of the signal. When a load runs on a system it will change the frequency of the power supplied to that circuit. Somehow he adjusts the frequency on the fly (transistor+parallel ac line) to make up for any load on the secondary(load) coil. Probably by the Transistor input of the rectified ac signal. We know that the transformer and diode bridge is only used for the looping of the inverter. This shifts the primary or source current from the accumulator(battery) to the transformer/diode bridge.
Now the problem is to figure out what helps in auto resonating the coils. Bifilar coils don't react to false currents right? False currents are counter emf or BEMF. If you remove BEMF from the forward emf then it could be considered as an auto resonant coil? Meaning it ignores BEMF which would take a coil out of resonance. But what happens to the BEMF then? Maybe a transformer made with bifilar coils like the Melanchenko transformer might strip the BEMF and allow for more extraction of the energy from the environment via the apex of the two fields. Tesla tells us this is the best coil to use for polarized Magnetic fields. This would give a much cleaner separation of the counter forces in the coils. You could think of it like a regular magnet. Much stronger or steady in it's field generation. It seems entirely possible that by using the steadier field produces more energy sucking at the ferrite gap. Think about it here. TK learned about this guy and thought he could enhance the extraction by using the best coil for electromagnets ever engineered. Using bifilar winds on the Melanchenko transformer allowed for much better energy extraction from the environment. But what happens then? You need a sink for this pure energy pump. Walla the ground wire. So there is tons of energy going from the environment to the ground wire. Now what? Well we do have devices that sense current even from one wire. It's called a coil over wire method. Or clamp meter is another name for it. All we would be doing is taking a sink (The ground) and letting it attract or suck charges after the pump collects the free energy from the environment by the Melanchenko transformer, through this he gets a supply of energy that is very fond of the ground. It dives trough the wires twords the ground accelerating and gaining inertia. Then it has to go through a coil where it can be drawn from for the load through the normal induction process.
When I saw the back yard presentation and the guy was trying to look under the box it dawned on me that he saw a wire going into the box from the big coils. we have 2 switches. One for main power of the coupling and another to switch on the load coil. We have a high voltage line running to the spark gap. If we look at tesla's designs you will see the spark gap is used in between the ground and air capacitance. This is to build a better pulsing pressure. This should increase the output of the secondary as well. This might also be used to let the secondary pull more by the buildup of the magnetic field by slowing the release(spark).
Also let me be very clear. The Turkey device now looks to be of the same system.
If you look at the two videos you will see the differences in the equipment shown. The melanchenko transformer is displayed in the in house video but not in the backyard video. Well it was but it was enclosed in a shielded box (shown in the backyard video) along with the diode bridge. Remember the talk in the video about the field effecting the meters. These fields are coming from the exposed wires to the loads. It would be better if you has Tesla static shielding on those wires to better contain the massive frequencies flowing from the load wires.
I had some time to think about the coil setup and it seems to me that we might be compressing a broadband emission from that heavy copper into the load coil because it is surrounding the load coil. This would amplify the short to ground through compression of the broadband emissions. I don't know I'm just musing here. Let me see if I can draw it up.
br549
Quote: form aking21
I am becoming more convinced that the ground has high voltage in it; sent out by the device and reflected back.
He definitely needs a very wet ground. That's a common denominator.
He definitely works with high voltage. That's a common feature. His coils are bifilar. They are either a step up transformer, or a step down transformer or BOTH!
Here's a hint. I asked about a 500 kw device. He said the secret part would not be much bigger than the 2 kw version.
It is possible that he sends out pulsed DC and mixes it with conventional AC. - That's what I'm working on. It would also explain the diodes.
aking21
I am interested in your experiment  (mixing pulsed DC with conventional AC). I have done several experiments (note below attachment)
and was wondering if you have a method of circuit to synchronize and adjust the timing of the HV pulses on the sign wave.
