0 Members and 119 Guests are viewing this topic.
xenomorphlabs
Quote from: pix on October 09, 2012, 09:10:15 AM
@ Zeitsmachine
Quote:"The green box has two switches and it does not need the auxiliary plug to start. Why?"
Two frequency generators.That is my opinion.I remember on the very first paper describing TK device it was  mentioned event that happened between power grid in Ukraine and USSR.For some reason power grid frequency in Ukraine was lower than in USSR and because of this a lot of electric power had flown from the russian side to Ukraine grid. Steven Mark also did mention" study strange factors of out-ofthe phase transformers". The thing is- Steven Mark TPU didn't have any ground connection.
In the paper describing Kapanadze device, there was a symbol of the transformer, with connection between primary and secondary, marked by box with "delta f" sign.Clearly there is something on with frequency difference.
I think that secondary is a few turn big air coil in resonance,very high Q, a lot of kVARs oscillating- this is a "open side to enviroment". Primary is tuned for lower frequency- then we have effect of "sucking" this "enviroment resonance energy" from the secondary to the "energy sink" on the primary. So on the one side we have a resonating enviroment together with one coil , and as "energy sink" other coil tuned for lower frequency.
On the other hand, Tesla did stated that he know a method for releasing all energy of longer wave into shorter wave upon interference. As I remember, this was even laboratory tested by Corums as "ball lightning".
Sorry for a bit chaotic text.Please see attached.
Regards,
Pix
While the theory is interesting, with a few turn air core coil, you would need an insane capacitance to get that to resonant state
anywhere below radio frequency, since the self-resonant frequency of the air core coil alone would be in the high MHz range.
How would you go ahead and arrange that the primary's impedance doesn't just damp the secondaries high frequency signal, but
on top of it power factor correct it into a clean phase relationship to the primary signal that would be usable by a typical 50 Hz AC load?
jbignes5
Quote from: br549 on October 09, 2012, 10:28:45 AM
Quote: form aking21
I am becoming more convinced that the ground has high voltage in it; sent out by the device and reflected back.
He definitely needs a very wet ground. That's a common denominator.
He definitely works with high voltage. That's a common feature. His coils are bifilar. They are either a step up transformer, or a step down transformer or BOTH!
Here's a hint. I asked about a 500 kw device. He said the secret part would not be much bigger than the 2 kw version.
It is possible that he sends out pulsed DC and mixes it with conventional AC. - That's what I'm working on. It would also explain the diodes.
aking21
I am interested in your experiment  (mixing pulsed DC with conventional AC). I have done several experiments (note below attachment)
and was wondering if you have a method of circuit to synchronize and adjust the timing of the HV pulses on the sign wave.
Think about an isolation transformer. That would be enough to sync with the ac signal and fed into a bridge rectifier to give whatever pulses you wanted to synchronize with by tapping the diodes where you wanted to pick off the pulses from the diode bridge.The transistors could be connected to the full dc on the input to create pulses with the exact timing on the output. The dc could also be looped after the isolation transformer and diode bridge. The output of the transistors could then be placed across the spark gap for fine tuning and then into the ground after winding around the load coil.  The ground plane inside of the load coil is the sink.
If you design the isolation transformer in Malichenko design you get even more energy to use. If he was correct then 150% gain could be had on the input alone and if you use bifilar coils in that design I bet you could get way more out of it and not even have to use the ground at all. This would explain the aquarium versions.
I have been also thinking about the open bifilar coil and if you attach a battery to the open ends it would charge up the capacitance of the open bifilar ends and start an oscillation. Disconnecting the batter from the ends would allow for the fields that get formed around the wires to connect and keep that oscillation going all by itself. This is why the aquariums have the long antenna like battery connections. The battery becomes the environment and also suck in environmental energy or free charges, if you will.
Zeitmaschine
jbignes5
Quote from: Zeitmaschine on October 09, 2012, 11:00:24 AM
Something to think about. :)
But not sure yet what to think. :(
The Electrostatic Charge of a Capacitor
The Bearden's Free Energy Generator principle
Charging By Induction
Now combine them all.
Excerpt from Tesla patent # 512,340    http://www.teslauniverse.com/nikola-tesla-patents-512,340-coil-for-electro-magnets
"Let A, Fig. 1, designate any given coil the spires or convolutions of which are wound upon and insulated from each other. Let it be assumed that the terminals of this coil show a potential difference of one hundred volts, and that there are one thousand convolutions; then considering any two contiguous points on adjacent convolutions let it be assumed that there will exist between them a potential difference of one-tenth of a volt. If now, as shown in Fig. 2, a conductor B be wound parallel with the conductor A and insulated from it, and the end of A be connected with the starting point of B, the aggregate length of the two conductors being such that the assumed number of convolutions or turns is the same, viz., one thousand, then the potential difference between any two adjacent points in A and B will be fifty volts, and as the capacity effect is proportionate to the square of this difference, the energy stored in the coil as a whole will now be two hundred and fifty thousand as great. Following out this principle, I may wind any given coil either in whole or in part, not only in the specific manner herein illustrated, but in a great variety of ways, well-known in the art, so as to secure between adjacent convolutions such potential difference as will give the proper capacity to neutralize the self-induction for any given current that may be employed. Capacity secured in this particular way possesses an additional advantage in that it is evenly distributed, a consideration of the greatest importance in many cases, and the results, both as to efficiency and economy, are the more readily and easily obtained as the size of the coils, the potential difference, or frequency of the currents are increased."
"My present invention has for its object to avoid the employment of condensers which are expensive, cumbersome and difficult to maintain in perfect condition, and to so construct the coils themselves as to accomplish the same ultimate object."
It's a coil to replace capacitors.
Does this mean the bifilar if properly designed and used it auto adjusts the capacitance based on both the amplitude of the potential difference and the frequency of the current? ???
wings
@ Zeitsmachine
Regards,
Pix
Nice comments
see also :
Otto simple experiment
and
"The Application of Single Wire Phase Retardation Effect in Power Source"
or
"The Measurement of Retarded Phase In Single Wire Power Transmission"
"Discussion
When the current is phase inverted relative to the voltage, the effective resistance of load
resistor is negative. In this case, the current acts like to charge the source. This is the first
time to achieve negative resistance. It is anticipated that this technology can be used to
generate electric power."
http://vixra.org/pdf/1109.0043v1.pdf
http://vixra.org/pdf/1108.0010v1.pdf
http://vixra.org/pdf/1110.0004v1.pdf
from viXra.org
An alternative archive of 3553 e-prints in Science and Mathematics serving the whole scientific community
.... and
http://vixra.org/pdf/1104.0052v1.pdf
