0 Members and 173 Guests are viewing this topic.
jbignes5
Quote from: wings on October 09, 2012, 11:28:09 AM
Nice comments
see also :
Otto simple experiment
and
"The Application of Single Wire Phase Retardation Effect in Power Source"
or
"The Measurement of Retarded Phase In Single Wire Power Transmission"
"Discussion
When the current is phase inverted relative to the voltage, the effective resistance of load
resistor is negative. In this case, the current acts like to charge the source. This is the first
time to achieve negative resistance. It is anticipated that this technology can be used to
generate electric power."
http://vixra.org/pdf/1109.0043v1.pdf
http://vixra.org/pdf/1108.0010v1.pdf
http://vixra.org/pdf/1110.0004v1.pdf
from viXra.org
An alternative archive of 3553 e-prints in Science and Mathematics serving the whole scientific community
.... and
http://vixra.org/pdf/1104.0052v1.pdf
The last one is quite interesting. What happens if you use flat bifilar coils with built in capacitance? Hmmmm
This also sounds like my reflective mods to the cap coil. Both reflecting and powering the loads from the reflectors.
Strangely this is also how lasers were made earlier on. The intensity of the reflected light was greatly enhanced and would only leave the reflection chamber when it became intense enough to override the semi reflective material on the ends of a jewel rod.
http://avniet.blogspot.com/2011/05/click-here.html
In the case of your example the totally reflective portion is the receiver and the partially reflecting is the source which can be switched on and off(reflecting and absorbing). If timed right it could operate like the old paddle ball toy. Changing the on off timing to the reflected wave could be very very simple and it would be very additive. Using the bifilar pancake coils should enhance that even further like I had suggested a great many pages ago. And I suspect if a bucky ball like design was used it would become very, very powerful. Now extraction could be handled by the absorbing(input), when you increase the amount of reflectors you net both power at the reflector and massive power through the source element. This power would be so immense that we could actually devise a plasma system of power conductor like they foretold in Star trek. And Extremely high potential drives could be made much like it is used in that same show for propulsion systems. We have already tested out the ionic drives. The only thing holding them back now is the power source. Which I think we found out just now.
This would make 10,000 year radioactive sources of energy extremely powerful and ever lasting. Even tiny bits of the source could be used to power huge loads given enough time to ramp up the power levels.
I doubt this will come as a surprise but it will have deathly actions on the human form if the form goes into an active reactor. The amount of energy being bounced around would be immense and will have to be backed up by additional reflectors or sources past those reflectors. This means the internal source initiates the wave then the first reflector bounces a portion back to the main source and lets some past. More sources should be used around the reflectors to absorb the waste waves and reroute them back to the internal source. This will have to be synchronized to the source supply via rectification then dc biasing the source supply.
We might as well be using everything we are discussing now. As long as it doesn't run away we should be alright. Tight control will have to be used and fully adjustable via a computerized control system.
So the internal source radiator should be very heavy material then the reflectors should be medium and around them should be smaller sources. All sources will be scrubbed and reapplied as a bias to the main radiator. This is to get rid of synchronization errors. And of course specially made bifilar caps in oil will be the caps for the dc conversion. In between each source and reflector should be an isolation transformer like the Malinchenko design but with bifilar winds. This way we get amplification and perfect dc decoupling or isolation between each element before dc conversion. This is the scrubbing I was talking about. The next step would be to store it for use later in the cycle to match the Alternating current cycle. I'm not sure if the radiator needs to be a regular solenoid or if it needs to be bifilar wound. I'm betting one is a sender (solenoid)or dedicated single channel and the other is bidirectional as a reflector and receiver at the same exact time (Bifilar solenoid).
Here is something interesting: http://www.jlab.org/FEL/terahertz/nature2.pdf
wings
[size=78%]An Experimental Evidence of Energy Non-Conservation[/size]
We found that the energy transmission through a transformer with unequal mutual inductances is not conserved. The law of conservation of energy is broken.
https://www.msu.edu/~liuxiaod/ENC.pdf
same people:
A Novel Technology of Electric Propulsion
Conclusion
A designing of  electric propulsion is  proposed using a toroidal solenoid and an inner
connected parallel plate capacitor. The net Coulomb force between the solenoid and the
capacitor supplies the propulsion force. This device does not need chemical fuel. It can be
used in satellites, where the electric power is supplied by the solar panel.
http://vixra.org/pdf/1012.0054v1.pdf
a.king21
I'm still experimenting. I think we're all on the right track at last.
Zeitmaschine
Quote from: wattsup on October 08, 2012, 01:16:26 PM
So the TK device could simply be his inverter and everything else is just smoke and mirrors. I mean everything.
If a capacitor is connected with one side to ground (instead of the negative pole of a power source) and with the other side to a positive (high) potential (from an inverter perhaps) which attracts electrons, then the grounded plate of the capacitor will attract electrons from ground as well, so there will be a surplus of electrons on that grounded plate. This means (if I'm not mistaken) that this capacitor should end up charged without the need of a closed circuit.
Maybe this works not with the power grid precisely because the power grid is grounded and therefore it will always work as an ordinary closed circuit when connected to ground.
Since nothing is left but smoke and mirrors (and strange ideas) this could be worth a try ...  ;D
Vito PL
 :) Toroidal solenoid and an inner
used in satellites, where the electric power is supplied by the solar panel .
Or another bifilar coil in resonance. Greetings from Polish :D
