0 Members and 381 Guests are viewing this topic.
a.king21
Quote from: andrea76 on October 17, 2012, 02:15:57 PM
when Kapanadze discovered the phenomenon (burst of energy )  did not know how to use it. the first thing he tought  was to use it to drive an generator.replacement it with a coil came after (amplifying the alternate current 50 hz).his rotating device is similar to the  Hendershot motor.we have to start  building the "receptor".HOW DO WE KNOW IF WE GOT THE CORRECT IMPULS???  we are in a dark room looking one nail.it s only matter of time....
And how exactly do you know that piece of information? Or is this more pub talk?
andrea76
TK said thatthe first invention that did was a hydrogen car. to produce large volumes of hydrogen must have used a scheme similar to that of meyer or boyce. tuning the device must have discovered the phenomenon of conversion. the easiest thing is to coupling it with a generator.and late.....
a.king21
Quote from: andrea76 on October 18, 2012, 12:55:17 PM
Dave Lawton replicated Stanley Meyer. You can buy the whole kit here: http://www.ebay.co.uk/sch/i.html?_trksid=p5197.m570.l1313&_nkw=dave lawton&_sacat=0&_from=R40
Zeitmaschine
Since I'm still looking for the special component in the tin can which is connected to the orange 25 amps cable ...
»Dave Lawton. A solid-state semiconductor circuit which has proved successful in producing pulses like this is shown as part of Dave Lawton’s replication of Stan Meyer’s Water Fuel Cell. Here, an ordinary NE555 timer chip generates a square wave which feeds a carefully chosen Field-Effect Transistor the BUZ350 which drives a water-splitter cell via a combined pair of choke coils at point “A” in the diagram below.«
»Stan Meyer used a toroidal ferrite ring when he was winding these choke coils while Dave Lawton uses two straight ferrite bars, bridged top and bottom with thick iron strips. Chokes wound on straight ferrite rods have been found to work very well also. The effects are the same in all cases, with the waveform applied to the pipe electrodes being converted into very sharp, very short, high-voltage spikes. These spikes unbalance the local quantum environment causing vast flows of energy, a tiny percentage of which happens to flow into the circuit as additional power. The cell runs cold, and at low input current, quite unlike an ordinary electrolysis cell where the temperature rises noticeably and the input current needed is much higher.«
http://www.free-energy-info.co.uk/Chapter5.pdf
»To test his cell system further, Dave connected an extra load across the electrodes of his cell. As the inductors connected each side of the cell generate very high-value, sharp voltage spikes, Dave connected two large value capacitors (83,000 microfarad, 50-volt) across the cell as well. The load was a 10-watt light bulb which shines brightly, and interestingly, the current draw of the circuit goes down rather than up, in spite of the extra output power. The gas production rate appears undiminished.«
http://www.free-energy-info.co.uk/Chapter10.pdf
... could it be that this component is some kind of a self-made part? Maybe something like a water-splitter cell without water?
jbignes5
 It is funny how the negative says 0 volt. Isn't that what Kapanadze said in the back yard video. He said something to the effect of I have two zero wires here. Hmmm....
I have to check and see if the open bifilar coil capacitor can be stimulated like Itsu did with the rolled caps. Hmmm...
http://www.youtube.com/watch?v=8-cmEmk8BiE&feature=channel&list=UL
Also at 2 minutes in this video I think this is how Kapanadze was biasing the AC signal.
And just for giggles.  http://www.youtube.com/watch?NR=1&v=0Vd7FV_UKCU&feature=endscreen
