0 Members and 41 Guests are viewing this topic.
andrea76
this is the first video about TK mechanical device probably at the end of '90.at min 0:51 we can see three white coils  under the rotating shaft.lie in here the "burst"???
http://www.youtube.com/watch?v=90W00Yt_PLk
sparks
  Tesla in a thought experiment stated that if a motor was connected to ground and the other end of the motor was connected to a conduit extending into space the motor would run perpectually until the entire Earth was the same temperature as space.   Then we have a p doped semiconductor with the lack of mass moving around randomly within it until said form of mass is subjected to an electric field.   It appears that a positive charge is a) antimatter particle  b) pure vacuum.  Either way space appears to be positively charged relative to Earth.  If we create a cold spot then it would be logical to assume that electrons will flow towards this cold spot.  This is evidenced by various thermoelectric effects.  What if the current flow towards the cold spot results in refridgeration of the cold spot.  Would the current increase or decrease as the cold spot got colder?  At what point would the refridgeration system vaporise from intense current flow towards the cold spot? Why is there so much bullshit surrounding electrostatic cooling effects?  How intense an electric field do you need to cool the collector metal and increase the rate of entropy where you need to do some work?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jbignes5
 Give this series a good long study. Listen to the reality. Everything is possible. Look at where we went wrong.
[size=78%]http://www.youtube.com/watch?v=CSRzw2ORNPY&feature=relmfu[/size]
Zeitmaschine
More stuff presumably leading to nothing:
Method and apparatus for splitting water molecules
An insulation transformer with two secondary coils is used for splitting water molecules. There is a strange coincidence to the transformer in the TK 2004 video. Especially since the secondary insulation of the TK transformer looks like it has been tampered with.
Let's say the two secondary coils of the Kapanadze transformer were originally connected within the transformer so there were only three output pins for the two secondaries. But TK for some reason needed two separated secondaries with four output pins. Then the logical thing to do would have been to remove the insulation and cut off one of the wires of one of the secondary coils in order to handle this wire separately.
Dr. Andrija Puharich
Now, how can a transformer work at all when both secondary coils are only connected with one end? ???
On the other hand ...
Resonance in a Bifilar Coil (thanks to jbignes5)
... both secondary (half connected) coils acting like a capacitor if supplied with high frequency.
In the »Puharich Improvement« drawing I think C2 and L2 might be omitted and the load can be connected directly to the diode bridge so only C1 and L1 is left. Hence what could be the capacity of C1? A large capacitor like seen in the 2004 video perhaps?
Question: When the gap between the two secondary coils is bridged with high frequency (capacitor feature) then what about a low 50Hz frequency? Can a 50Hz current flow between the two secondary coils although they are not galvanically connected with each other at the time a high frequency is connected? High frequency can pass an ordinary capacitor rather than low frequency. But this is not an ordinary capacitor.
Hence that's another »Hmmm ...« ???
And maybe this drawing could need one more revision: TK - 2004 Device Diagram
wattsup
@all
During the OU black out I had prepared some posts. Some perplexing because of my simple ground tests and observations that I will post after this post.
Today I decided to cut my house main water pipe at its entrance point and just reconnect it to the home with a non-conductive pipe length to be 200% sure that the main pipe coming in from the underground is not touching anything but my ground wire going to my bench.
With ground going to a four bulb load and the other side going to;
Primary
AC hot and bulbs light
AC neutral and bulbs do not light
Rectified + and bulbs light half bright
Rectified - and bulbs light half bright
Secondary
AC hot and bulbs do not light
Rectified + and bulbs do not light
Rectified - and bulbs do not light
Damn it. I was hoping the primary did not light. This may mean my ground piping coming from the city may be grounded to other homes as well so I may be drawing off my neighbors' neutral. WTF. I will have to put a dedicated ground rod in my back yard in order to continue my tests. I have to see it or its only guessing.
I found the following document on grounding rods.
I will find a 1/2" or 3/4" solid copper 8 or 10 foot length.
wattsup
