0 Members and 142 Guests are viewing this topic.
forest
Quote from: Сергей Ð'. on October 23, 2012, 12:01:51 AM
LIE and FICTION !!
In Patent 512,340 Nikola Tesla said:
“... Minimal work is done in my radiant energy system due to the absence of wasted displacement currents. As small heat losses occur, oscillations are maintained by surplus charge generated by atomic  catalytic reactions, energy is siphoned from the kinetic moments of these charges. Very low energy expenditure allows power delivery to an electrical load over an extended time period without an external fuel supply. After an initial input of energy from an outside source, the radiant energy electrical generator will operate as a very efficient device. ...”.
"absence of wasted displacement currents".
ps. Fantasies are very bad for your essence BUZZ !! It's like cockroaches play the games in your brain with your brain cells!!
Free advice from РУСЬ: Stay away with your loving Einstein..... forever in darkness .... GAME OVER BUZZ !!
This patent has no word about displacement current ! Be sue you use the correct source of information! Anyway this is a very large step forward , I realized that the cancellation of self-induction , the same effect which makes transformer underunity is the second key. We want electrons free from lag, moving on surface of conductor with light speed like in vacuum tube, then apply the knowledge about vacuum tubes and Steven Mark notes...
wings
27Bubba
"None of this has anything to do with Kapanadze or the posts I made telling people how Kapanadze worked. It just serves to bury it under useless chatter. That is why this thread has gone on for 1000 pages. That information was disclosed a few times in this thread by others."
@TheBuzz
Soooo, Judging by your posts.. You we're able to replicate the Kapanadze device successfully?
@All
It amazes me that so far nobody was able to replicate Kapanadze device, quite few toss scientific theories that all it does, it confuses/detracts from task at hand.. Kapanadze is a smart man but not a nuclear scientist... JUST LOOK AT HIS DEVICES PEOPLE!!
Frankly, it is getting old to see the pissing contest and dick waving..
I'm OUT! >:(
jbignes5
 Lets not do the national bashing in here ok? We are of the human race everyone is related in one way or another.
Displacement current is another thing I wanted to chat about. Lets look at the Bad first.... By the way I said displacement current like and that was mainly dealing with solid matters.
" When it came to deriving the electromagnetic wave equation from displacement current in his 1865 paper A Dynamical Theory of the Electromagnetic Field, he got around the problem of the non-zero divergence associated with Gauss's law and dielectric displacement by eliminating the Gauss term and deriving the wave equation exclusively for the solenoidal magnetic field vector. Maxwell's emphasis on polarization diverted attention towards the electric capacitor circuit, and led to the common belief that Maxwell conceived of displacement current so as to maintain conservation of charge in an electric capacitor circuit. There are a variety of debatable notions about Maxwell's thinking, ranging from his supposed desire to perfect the symmetry of the field equations to the desire to achieve compatibility with the continuity equation."
This also means that this displacement current is only in the mathematics. It only is used via a fudging of the math. This was done on the mistaken thought that charges were not free in the environment around the "closed" system they were designing. Since then we are seeing fields as a way to organize these charges and have designed some pretty cool devices like the exciters and polarized translators for the receivers.
Displacement current is not real it is a mind thought or a rationalization of an idea to explain what we couldn't see and to reinforce errors of other portions of this unified theory.
A magnetic version which is not what I am talking about. Tesla's new power source was actually a collection of charges induced in to movement by Voltage that are then organized into a polarized stream. This stream is like poking a hole in a vessel like a sub and generating from the stream and have it evaporate before it hits the floor. The charges seem to be in a fluid like suspension and are linked very strongly in one direction but weakly in another.
Weather you want to admit it or not we live in a very pressurized environment. First we need to create a container (solenoid coil) then we need a separator of the polarities (+,-)(Bifilar coil) or in the bifilar case it inverts one half of one of the fields and combines the two into a uni-polarity. Then we can use any body as a ground or reference voltage to draw from that unipolarity. This does two things. It changes the capacity of the bifilar and raises the voltage potential. Now any charges that gets attracted or sucked into the process get amplified greatly. In value and speed. These free charges, heat could be considered as a charge as well as light(charge in motion), would flow twords the mass we established as the ground. In Tesla's version he used a CAP as the pump. So the Bifilar does three things. It is a capacitance, and greatly overtakes the self induction by that capacitance. There is two. Oh and it is a strengthener and accelerator of charges caught up in the Bifilar winds.
Tesla designed this coil to replace capacitors that were costly and impossible to keep healthy. The coil did way more then we ever knew if designed and built it correctly. We have not built it correctly in my opinion and if we just took the time we could see that we could do way more with a properly built , multilayer coil. We need to use the coil with a pulsed AC Signal just like Tesla told us. The spark gap is this device to pulse an AC signal. At the peek of the positive it will short and I suspect at the lower peek of the signal it will again short. The bifilar would be accelerating both ways. So we have a sea of charges both bound(in matter) and free(environmental) to accelerate. Nothing is being consumed and you net more out because of the free acceleration you get of those charges when they go through the bifilar coil. This is the 250,000 times difference he was talking about. Yeah it came out as voltage but we can always transform that down and get what we need. You can also change the shorting to a directional one by including magnets. This filtering through the stream of the magnets flow only allows one spin to make it through the cross flow.
