0 Members and 70 Guests are viewing this topic.
wattsup
@TheBuzz
The question is not so simple and cannot be answered by "the answer is in my last four posts".
If you have an idea, then please put it where it counts. Please use your theory and provide a specific method where the TK components are specifically described. Otherwise you are just giving us another layer to get lost in and that is not productive.
Just to say, man has been using electricity for the last 150 years without really knowing what electricity is. I would not mind using OU for the next 150 years without knowing what it is that drives it. That is the least of my concerns right now and many have their own developed ideas on that question but again none will help in this endeavor of OU.
As far as I am concerned, even if 1000 of the worlds best scientists get together for one year and hatch The New Relativity, chances are 99.999% that they will be wrong again. We should not push this question because no one will have the real answer until a good few generations more. But meanwhile, back in our caves we need some light regardless of where the hell it came from.
We need to give this world a rest. A rest on pillaging its resources and energy so it can just recover from our present mess we have made. So if we can simply get some OU, this will buy us the time and the quietude required to then calmly ponder the other universal secrets. But to try and fix in with this thread seems rather unrealistic.
So, if I can just suggest that yes, you may have something in mind that is pertinent but it has to fit the device. We need to see the theory applied to the nuts and bolts of the device.
wattsup
jbignes5
Wattsup this guy is a sham. He pours through previous posts and uses them to make himself look in the know. He does this all over in fact he has a self made organization that is only a troll collective. They sit around a main guy like TheBuzz and collectively yank his.. Well you know...
He is not gonna be any help here. In fact I think I'll be going into my own world and stopping all communication with everyone. I have given enough I guess and was only here to bounce ideas off other like minded individuals. Thanks for sharing your side Wattsup.. Hope you find the real device eventually. I think I am close... We will see...
a.king21
Wattsup...... unless we're talking radiant energy......hmmmm
a.king21
A radiant energy spike has every frequency in it. But it is generated by ..... not a hv source......  think..
Zeitmaschine
Quote from: TheBuzz on October 24, 2012, 06:46:33 PM
Zeitmaschine - Saint Buzz would add to that the reason why you need the spark gap:
The voltage across the spark gap pulls a void in the heliospere of a greater vacuum potential then what exists naturally. The heliosphere slams that hole closed again. This slamming of the void closed is equal to the vacuum of gravity which exists within the heliospere. Hence, the displacement current of the "stout" mass is changed.
Then we have a slight problem: The visible spark gap in the 2004 video does not work properly, hence there has to be a hidden spark gap within the tin can.
Furthermore the spark gap in the aquarium II device fires at approx. 10Hz only, hence is this enough to keep the energy flowing continuously?
In addition, this is like a Tesla style spark gap sounds: Tesla "Hairpin Circuit" lighting 100 watt halogen bulb, under water as well
I can't remember hearing such a noise in any of the TK videos. This could only mean either the TK spark gap works somehow completely different than a classical Tesla spark gap, or TK does not use a spark gap at all (except for showcase).
Moreover in the Hempel demonstration (1 Farad cap) there is neither a spark gap nor high voltage involved. Hence how does this work with 20 volts only?
