0 Members and 81 Guests are viewing this topic.
x_name-41
C'mon stop no more lies, I know that some people are aware of the principle, Please explain in detail all how this thing works!
elementSix
One major advantage to the use of copper is that it is one
element that will spread and electromagnetism and torsion fields in length.
Torsion flows most freely, set at 45 degrees to the magnetic field to
field oscillation between each 90 degree angles will splash through twisting
wire as it crosses 45 degrees. This will cause a physical vibration or
motor effect. Since the magnetic field crosses 90 degrees to the wire,
we obtain NMR pulse train electromagnetic effect.
If it were possible to wind the coils many different angles to the front
coil, one every few degrees, we would see an almost constant output
pulses in time, because the field is only 90 degree swings back and forth between
two pulsating coils.
If we can deal with the rotation of the Copper core back in the right direction, with
correct pulsing configuration may be possible to achieve a 360 degree
helical rotations, which start to resist the natural precession, and
constantly outputting more energy than is required to achieve this rotation.
Observation lasigous characteristics on O-oscilloscope - an example of this in two sizes. We
must deal with three-dimensional however, to achieve a full rotation and mass
transform our core copper mass in the motor armature. If the system is weight restoration
atoms now moves into a closed loop repetition time, the energy can be recovered
of energy recovery, which should far exceed the energy to start the process. It
based on the observation that the copper atoms will always return regardless of
burden that we put into them, they always push back with a stronger
force.
Little web page with this kind of information.>>>>>>>   http://translate.googleusercontent.com/translate_c?depth=1&hl=en&rurl=translate.google.com&sl=auto&tl=en&u=http://www.realstrannik.ru/media/kunena/attachments/3450/.pdf&usg=ALkJrhi1RvJjU-Xnu26nIFJ-vfQDQ4DAWg
Zeitmaschine
Quote from: TheBuzz on October 26, 2012, 01:09:37 PM
@ Zeitswattsup
Also retardo - Tesla did not have thyristors. A little history lesson for you.  ;D
But he would have used them if he had them, the thyristors. :P
Quote from: TheBuzz on October 26, 2012, 12:43:07 PM
Are you fucking with me?
If this is the only way that leads to free energy, then the answer is absolutely yes!
It's a patent retardo, not a schematic.
That means TheBuzz has no idea why Tesla forgot to mention such an important thing like a hollow copper tube which his invention needs because otherwise it will not work.
I already answered that. The wire runs through the tubing to produce displacement capacitor.
But if the wire runs through the tubing then it is not really hollow as suggested right in your next statement.
You are fucking me - it should be as hollow as your head. Question was answered long ago. Are you wattsup in global revolutionary warlord costume?
So it should be hollow after all? And hollow means not filled with anything, not even with a wire that runs through the tubing to create a capacitor.
Sorry, but this discussion is completely nonsense. >:(
Quote from: TheBuzz on October 26, 2012, 01:15:56 PM
Feel free to do your own photo analysis in the future.
No problem with that!
a.king21
Zeitmaschine: Can you post more photos of TK's solid state devices in high definition please? They are very useful. Where did you get them from?
a.king21
