0 Members and 125 Guests are viewing this topic.
wattsup
@all
@stefan mentioned that the forum will be transferred to a new hoster. I already see the difference with my Firefox now has all the post options available like bold, etc. Great move.
@Zeitmaschine
While this buzz affair was going on I did not post much more to not get lost again.
OK, I now have placed my 8' copper grounding rod and ran my ground wire to my work bench. This is my isolated Earth ground. The main reason I did this was to test the Green Box video and TK using the water pipe (as I have also) and then he used the buried radiator. Of course the other reason is this gives me an isolated ground that I can then work with my regular HF pulsing schemes using my FGs and so many coils.
I this case though, what I wanted to see is the difference using standard AC mains Hot on one side of load and then with each of the grounds. I already know that with my water pipe ground being connected to the AC neutral, my bulbs light up full. But with my new isolated ground, the bulbs did not light but the filaments reddened slightly. This is fantastic news because this conforms to the TK use of the radiator. This now confirms to me that TK was using the mains neutral all the time which is a disappointment, but I had to prove it to myself to then continue.
This confirms that regardless of his neutral usage disappointment TK still has found a way to make an "isolated system" that works off of a mains AC neutral and not off of an isolated ground or in other words a ground that is not connected to the mains neutral.
The only way I have seen this work is at higher frequencies but in the mA range with my FG and so many different coils type. It remains to be seen if it will work as TK device when all is in place.
Oh, regarding your last post and pictures, yes there could be a link between them. I will have to look at your post again and see that device but right away from the pictures, why is the further triple transformer on a white cloth and the front one is not? Probably to hide something under that cloth. Also in the patent drawing, the two diodes make me think about my original observation that the 2004 heat sinks hold diodes and not transistors and he is using them as a half-bridge to the AC5 line.
So to better explain this I have modified my original diagram as enclosed below to give you guys more of the actual workings I propose. Of course this diagram will miss some of the more finer components such as resistors to make it work in this manner.
So let's go back to the 2004 diagram with AC5 coming in then through goes through a half-bridge (11 & 12), what happens to the half cycle that is not bridged? Hmmm. (lol)
The half bridge (11/12) can go to the Tin Can (14) and energize a small HV coil primary (24a) where the secondary HV- (26) goes to the 6 turns fat coil on the spark gap left side (18). The HV+ goes through a 9 foot coax center conductor (25a) to the 6 turns coil side closest to the tin can (17).  Also parallel the half-bridge of the HV primary you can have two wires going to two IGBT (28a/28b) gates connected in parallel where one passes the rectified AC to become DC (10) positive (T8) to the orange wire (15) of the TK coil to load (20) and the other passes the DC (10) negative (T9) to the Tin Can as ground (T13).
It could be as simple as that. Maybe switch the HV+ to the -. But I know feeding to the IGBT gates will require some other resistor/diode mix that the greater EEers can work out as a formal circuit.
Now this leaves the shielding (25b) of the 9 foot cable that can also go to the Tin Can ground or elsewhere.
Also, physically speaking a small HV coil + a rolled 9 foot (I think its 9 feet but its the length TK needed) coax + two IBGTs + a few other components = can all fit inside the tin can.
This type of set-up agrees with why the AC5 and two transistor wires are so thin hence are not suitable for switching high amperage conditions.
So in the 2004 if the two heat sinked components (HSC) are diodes, we can consider the above.
But, if the HSC are transistors, then those two transistors can still be used to pulse the HV primary and the two IGBT gates instead. The point is, it is sure that those HSCs could never be inline to the load at the power levels shown. But they could be used to drive two IGBTs that short the TKc/Load/Ground over the heavy bridge rectifier that has higher amperage DC10.
We need some help here guys.
@Magluvin
I wholeheartedly agree but our sanity should not be negotiable. Any man who can think deep enough and read and write should know better. I am sure this is not his first exile, not because of any trolls or MIBs or bad guys or anything else but his own self-destructive manner. It's not his fault if he was born or bred that way, but again, it is just tooooooooo much for normal OUers to handle every day on a forum.
Look, I want over unity just like the next guy. I want it in the world right now. Not even tomorrow, so anytime guys come in to waste our time with insults, they will get booted out. Simple. No more fooling around with OUers that have enough on our hands then to play babysitter to creeps.
wattsup
elementSix
I found this interview that was made while TK was in TURKEY making his 100KW version for testing.  Its has good INFO and says that TESLA'a WIRELESS invention was part of the secret and that a SPARK is also used in the process and is necessary for resonance.   DO NOT WRITE THIS OFF.  IT IS IMPORTANT INFORMATION.................
Strikan wrote / by:
I do not think their positions to attack anybody, but the main thing about Tesla's wireless energy transfer is that he succeeded with a small reception strength (at receiver) to get great strength, necessary for the household.
Tesla has not passed a large amount of energy, but a small amount and the small amount of energy into a usable amount .
1. Primary circuit is a high - over 100kHz.
2. Primary circuit is a capacitor, inductor and HF SPARK
3. Tarry Kapanadze accidentally discovered the effect of increasing the energy output when repeating the experiments of Nikola Tesla energy transport in a conductor (and wireless).
4. The secondary output coil is bifilar coil Teslova from which one part is used as a closed magnetic circuit (most likely a resonant capacitor) and the other is loading. It is also grounded at one end of the load.
5. Do not use magnetic. Magnetic prevent the receipt of free energy.
6. When the generator with the green box above the high-voltage spark 100KHts (discharge) takes place inside the green box. Nanshnata spark (discharge) is 50Hts and is set for output frequency of the generator. 50Hts. spark fight over the primary coil thick (5-6 turns).
7. Bifilar secondary winding must have a length of wire 1 / 4 wavelength to RF and high voltage input is more than 100KHts.
In fact, his set was nothing but OU device. Tesla at the input of the receiver using a parallel resonant circuit (high resistance and low power source with the maximum high-frequency) and the energy with large q-TV was able to switch to the secondary, and that is his secret.  Almost a year trying resonate primary and secondary, I burned several multimeters, oscilloscope, function generator, and now I'm so close to a solution. I miss the one part, and I hope that I will one of you guys (and you Delija AS) or perhaps somebody else to help.   I need to find a way to automatically resonate primary and secondary to the basic rate (eg, Tesla transmitters) or other sources. AS, all replicas of energy transfer that can be  seen in the world, whether it's a single wire or wireless always have losses.  He would like to help you and I try to find a way to get automatically resonance secondary windings of transformers and to apply to AS transmitter.  Kapanadze is managed: Hope Delija perhaps understand what the Kapanadze says.
Now Tariel judged against Turks because they have electronical version contract, but
Turks tried to break it (tried to steal the technology?). After the trials, he will have the opportunity to enter into business contracts for this electronical version of the device. Also at that meeting he said further details of their installation. This is two Tesla transformers. They are connected through a wire from the top. Between them must be a resonance. First transformer works via spark on 100 kHz and higher. Second - is a power transformer. In the first transformer we have small capacitor on primary coil for the high-frequency discharge. On secondary coil (power transformer) we have large capacitor for decrease our high frequency. In the output of the Turk device are powerful diodes. They fix output energy. Next step - it passes through a capacitor and then formed 50 Hz.
Spark is used for resonance self tunning. According to Tariel - many people achieve in their experiments Free Energy, but they don't understand how to reduce frequency and voltage.
This method and some another moments (which while hiding) - have a very simple solution. Those who want to succeed it - must think simple and do it simple too.
Tariel also said that he already has sparkless version of kapagen. It is a fully electronic solution. I think that Kapanadze use thyristor for this purpose.
  We talked about vacuum tubes too. He said that this is a best solution! But sadly vacuum tubes can live in such device not more than ~1000 hrs.
Giya (Kapa's assistant) suggest that the best way for replicators - begin from high voltage as the input power (against 12V akkum. or battery) for start process. It must be 220V or even more.
Tariel said that the resonance between two transformers "shakes" the aether and it give more energy. Ferrite core prevents the process and therefore does not apply at his device.  That's all what I know right now about it.
NOW THERE IS PLENTY OF INFORMATION TO GO AROUND AND IF YOU CAN'T FIGURE IT OUT WITH THE INFORMATION PROVIDED, WITH GOOD OLD AMERICAN KNOW HOW, THEN WE SHOULD JUST GO ALOUNG WITH OUR OWN DESTRUCTION AND ENJOY THE RIDE....   COME ON GUYS, ITS ALL THERE WE JUST HAVE TO MAKE IT WORK......
Zeitmaschine
Quote from: sparks on October 29, 2012, 12:12:11 PM
A spark gap is hard to beat.  The plasma formed is of very low resistance and can pass the high current short duration pulse exactly when the output tank energy is all stored in the magnetic field of the inductor.  I imagine a circuit with triggers and highpower semiconductors could be and has been designed but a spark gap is a cheap way out.
Not needing a spark gap would be a cheaper way out. If both, the electric field in a capacitor and the magnetic field in a coil is an attribute of the aether and the aether is the place to look for the wanted energy, then the simplest thing to do would be to shake the aether by means of a coil and a capacitor in resonance. :)
Quote from: wattsup on October 29, 2012, 02:43:11 PM
Transistor 12 half-wave short-circuits AC5 (ACin), so either this will destroy transistor 12 or blow the fuse of the inverter. And I don't think TK had some IGBTs at hand. This is all much to over-complicated. How should the coils 24a/b generate high voltage with high frequency without an oscillator circuit but only two diodes (not even transistors)? And why bother with high voltage at all when it is obviously clear that this feature was only build-in to mislead people?
The call for »greater EEers« is »as simple as that«? Since TK was not a great EEer how could he ever have worked out this circuit? ???
ROFL ... The following is just my personal point of view:
Kapanadze laughs himself silly! His copper coil was (and still is) a blockbuster par excellence. A big helical copper coil in series with a tiny spark gap. Replicated a few hundred times I guess. Endless photos, videos, drawings, discussions all over the web. This all because of a coil that never had any true function and never worked and never will. A coil that was solely invented by Kapanadze (Tesla never had such a coil) in order to distract people from the real thing hidden in plain view! Congratulations!
The Kapanadze patents are also completely nonsense. In order to produce the device commercially Kapanadze looks for an investor. Investor demands a patent. Kapanadze has no other choice but to fabricate a patent drawing (with high frequency feature because he had it presented that way to the investor). That patent has almost nothing in common with his real device. Investor takes measurements during the presentations of the 100KW devices, at that point not knowing how the device really works. At a later time the investor finds out. Now he jumps off because he knows with just connecting together ordinary transformers, capacitors and diodes he will never make any money out of it. Since then tmzenerji.com is down. Also TK can never reveal his secret because this will equally reveal that he fooled half of the world in respect to the principle of work of his device.
So, as of October 29th 2012 we do know what parts are needed to get free electric energy. These are mainly transformers/chokes, capacitors and diodes (all rated 50Hz). The only remaining puzzle to solve is: how to connect these parts with each other the right way? There is surely no need of high voltage, high frequency, spark gaps and highly sophisticated electronics etc. This is all bare nonsense.
Hence I'm going to dismantle my breadboard that generates high voltage and frequency, because either this is going to work with the above-mentioned components only (transformers, capacitors, diodes) or it will never work at all. :( :o
a.king21
Wattsup: TK uses high frequency switching of rectified smoothed mains (DC). He went through many transistors before he got stability. We're lucky. We can use IGBTs.
We are essentially building a solid state Tesla switch. Bedini publicly admits that he dare not turn his Tesla switch device up.
The Tesla switch produces radiant energy. Now we have decoded TK's device.
Radiant energy is OU  - confirmed in Bedini/Bearden's book Free energy generation.
The energy comes from the Dirac sea.(zero point energy).
I cannot say any more.
Keep going.
a.king21
Wattsup: Now we understand the principle, TK patents make complete sense.
He has one "secret component".
I suspect, but do not know, that it is an enamel wire, bifilar wound 20:1 step down transformer soaked in oil in order to handle the radiant energy.
The coils we see have a different purpose but can still be used if filled with ferrite as SR 193 did. The ferrite would saturate the radiant energy at a more useable voltage. But remember electrostatic shielding.
