0 Members and 125 Guests are viewing this topic.
a.king21
TK does not generate HV. High frequency switching of rectified smoothed mains (DC) produces radiant energy.
Radiant energy is also HV as well as (I suspect) every possible voltage.
Try switching a mains switch on and off very fast. You'll get a spark.- Radiant energy. Certainly not HV.
Sometimes you plug something in and it flashes. - Radiant energy. It's been looking at us all our lives.
wattsup
@Zeitmaschine (sorry again for long post)
The latest diagram I am showing is to justify the visible components and extrapolate on the internal of the Tin Can.
Here is how I can see it at this point in time. Using the two heat sink components (HSC) as diodes produces half-wave DC at 60Hz but you are only using half the energy of the AC5 line because the negative AC wave is not passed. That 60Hz DC runs the HV coil to produce the spark decoy. I don't really care if it is a decoy or not but just to justify the usage in the 2004. The DC pulse also goes to the manual switch then to the IGBTs (or other type switcher does not matter but as long as it can handle more amperage coming from the main FWBR). This conforms with the fact that the device can work when the manual switch is turned on even though the spark does not work. His HV coil could have had an internal spiking between its dielectric. Would not be the first time I see that happen to a HV coil.
So the IGBTs are only pulsing at 60Hz. But the big FWBR is producing at DC 10 a 120Hz so with each 60Hz pulse of the IGBT gate, you are passing two 120Hz pulses to the TKc and Load.
Also, I know the TKc could also be a decoy putting something between the output of the Tin Can and to the Load as without it this would be too obvious.
So yes, the HV is not required and I think the TKc may not be required as well if only to act as a slight dual attenuation of the received spike from the IGBT shorts as well as providing an unintended landing point for any attracted additional energy from without. If this is the case, the TKc coil topology is not important and this would explain the many different TKc builds. As long as you have enough length on each side of the pulse spikes to attract maximum "I call it ether impress" (hehehe). But that is not important either.
If we took all the extras out of the equation, your are basically left with a battery, a transformer and a load on the secondary of lower volts but higher amperage. The primary having a higher inductance in this case, if you just shorted the primary on the battery even manually you will see how the bulb will light up and the battery energy will not really not go down. He is just doing this in a fancier package.
This is like when TK pointed to that ray gun in the Green Box video. A ray gun would work like so. Charge up, discharge, charge up, discharge. I don't think it is any more complicated then this. It has nothing to do with the ray itself but the method to produce the discharge. Instead of producing a ray, he is discharging into load. A steady discharge into load at 60Hz will produce an RMS value as he had measured. I doubt the ammeter reading of 24 amps is precise.
There is another pulse method I tried in the Tesla Ozone Patent trials and that is using a simple auto-releasing latching relay. At 60 Hz it would be fast enough to make the contacts ride smooth so the sound would be low. If he was using the spark gap as a decoy, it could be to mask any internal relay noises. Look at how loud he made the gap on the Aq2 unit. It was wide and load. Maybe to mask the sound of bigger pulsing relays. If the gap makes noise, then we should see it in an audio trace when the spark was working and he turned the light on, and when the spark was not working and he turned the light on. Those two evens should have two different audio signatures. Maybe our resident sound tracers can look at that.
So my question to the better EEers is this.
Using my diagram, can you please add in where I would have to add a few resistors (values and ratings) here and there or other components well identified and all will be located in the tin can to make this diagram work. I need this to attempt a build otherwise I know I will spend more time blowing things up. Any help with this would be appreciated.
Interviewer: So TK, please tell us, how do you do it?
TK: "Duhhhhh. I just pulse a coil on a battery and shit happens." lol
Interviewer: Hmmmmmm.
The AC5 side low amps is the drive side, the DC10 side is the canon shooting two shots to load. If the AC neutral ground plays into this remains to be seen by trying it on and off. It may be that during the spike off the neutral reloads more negative bias into the TKc which could then be considered a cannon barrel.
Consider that the neutral first has loaded the cannon barrel with full negative bias.
ON: AC5 pulses the Gate, DC10 shoots two spikes in to the negative biased cannon then into load. hehehe
OFF: Neutral reloads the cannon barrel with more negative bias. hohoho
So something can now happen at the on and at the off position. Hmmmm.
The negative bias fills the barrel so if you use a good negative bias like a mains neutral, you will get more powder in the barrel, use a poorly grounded radiator and you will bias less negative powder in the barrel. Imagine beating the oil barrel with an Earth barrel. Hmmmmm That would be nice.
wattsup
PS: I will use Wesleys' (@stivep) disclaimer as I do not know if this will work or not. It is only a theory that points to the specific parts of the devices. It's basically a new base to work from and tweak, but as far as I can tell it is the closest match at being a well dressed simple function. TK made himself a nice ray gun. lol
Pirate88179
Quote from: Сергей В. on October 29, 2012, 08:32:12 AM
Another good news is Kapanadze device has been successfully replicated in France. The man name is Fabrice ANDREI and he is electronic engineer.
Refuge de Sarenne
http://www.youtube.com/watch?v=sNveUeEuV2o
His channel is http://www.youtube.com/user/777bergerac. He has mantioned that he used Caduceus coil in his 2KWatts successfull replication. I think it will be good that Stefan ask him to join us on this forum even he don't speak English. He can post on Franch. It's no problem at all!! So Kapanadze device secret (question is Does it really belong to Kapanadze or Academy of Science СССP) was finnaly revealed.
ps: Personally i have good feeling about soon Rising of Free Energy Devices in the near future all over the world if some uninvited things don't happened !! I hope mankind can have a lucky !!
Is there an English translation of what he is saying in this video?  If not, can someone translate?
Thanks,
Hoppy
Quote from: a.king21 on October 29, 2012, 08:58:28 PM
Wattsup: TK uses high frequency switching of rectified smoothed mains (DC). He went through many transistors before he got stability. We're lucky. We can use IGBTs.
We are essentially building a solid state Tesla switch.
So does any switched-mode power supply. Don't need IGBT's.
How does he get the AC mains into the fish tank?
tagor
Quote from: Pirate88179 on October 30, 2012, 02:06:56 AM
Thanks,
i am very sorry pirate
but it is a con man
look at this thread :
http://www.overunity.com/12770/le-refuge-de-fabrice-andre-et-ses-projets-surunitaires-ou-surnumeraires/
