0 Members and 107 Guests are viewing this topic.
a.king21
Quote from: xenomorphlabs on October 31, 2012, 07:48:06 AM
Trying to rationally follow your theory, the question arises, if you believe that the HV component you are pointing out
is then also able to jump the gap at the spark gap in for instance the green box device?
Or are you also of the opinion that the sparkgap is a "decoy" and is certainly run with a HV driver, but irrelevant to the overall functionality?
I believe TK has done it both ways. You can  get rid of the spark gap with a circuit, if it is to remove unwanted excess energy. Magnacoaster had to do just this when I spoke to their technical team. It took him 8 months.
As wattsup has just said, it's so simple he is beginning to feel intellectually insulted.
There are many, many ways this can be done as we are beginning to uncover.
If you look at the scope shots from Magnacoaster, you will see it is pure radiant energy, except he only uses the negative component.
There's a common thread appearing with all these OU devices. It is radiant energy.
Now I understand why Kapanadze went ballistic when we turned up with our scopes. They had recording equipment on them and we would have been able to replay the signals in England. It would have taken me half a second to recognise radiant energy and he knew this.
I can understand his reaction now.
verpies
Quote from: a.king21 on October 31, 2012, 09:57:24 AM
It would have taken me half a second to recognize radiant energy
What is "radiant energy" ?
Is it a form of energy that radiates in all directions?
How does it appear on an oscilloscope?
forest
Quote from: wattsup on October 31, 2012, 08:40:31 AM
@all
I have been looking at the IGBT implementation (more finicky then expected) but I think I have found something much better and widely available and more transparent to switching stresses. It is simply done by using two solid state relays (SSR). These generally require a 3vdc to 32vdc pulse signal and can switch 280vac at 70a. They can easily function at 60Hz.
Using a battery fed inverter does not only provide AC voltage/amperage but also the main drive frequency is set in the system. There is no need for frequency control since everything is synced with the inverter.
For 32vdc you take the AC5 line and use a small rheostat set to 32vac, then you half wave rectify with the heat sink components to then feed the DC to both the HV coil for the spark and two SSRs. This is so easy my mind is starting to be insulted.
This type of set-up is very flexible and can be done in many ways. For the HV coil to spark gap, you can use a small AC fed neon ballast and then you do not even need to rectify that part of the power from the AC5 line.
Tonight I will do some easy tests and know for sure.
wattsup
wattsup
Please describe better how you plan impulse to be synced with inverter output. I don't understand....
a.king21
Quote from: verpies on October 31, 2012, 11:33:39 AM
It is a vertical spike. The "crisper" the better. In a radiant energy device you would get a series of them and little else.(ie on the energy creation side of the device). No sine waves, nothing. The spike is the limit of the scope. In practice the spike goes into "infinitely" high electromagnetic bands right into the Dirac sea. I've got a scope shot from Magnacoaster's youtube site http://www.youtube.com/watch?v=f03SdK0PXfk&list=UUXDBjnC4Mma1ohwK9PlxxsQ&index=2&feature=plcp
TK's would have been both positive and negative and much closer together.
It works also with gravity. Those are the type of scope shots you would have seen from Tesla's earthquake machine if you had converted the physical impulses into electrical signals.
verpies
Quote from: a.king21 on October 31, 2012, 03:34:02 PM
In that case this method of generating spikes would produce them.
