Hoppy
Quote from: a.king21 on October 31, 2012, 04:15:20 PM
Spot on.
http://www.slideshare.net/steepling/20-bedini-bearden-years-free-energy-generation-circuits-schematics-2007
You can read the theory and experiments here, also.
Remember, TK's contribution is that he found out how to control and loop it.
Are you suggesting that TK might be housing a a big schoolgirl - solid state SG - in the fish tank and 'green box'? How does he get the mains power into the fish tank to feed her?
energia9
somebody knows what happens when...
i have a 2.5 kw heater (heating homes)
accidentally the heater was sparking inside its circuit. spark gap occured inside it when i moved it.  it was constant after a few hits.
and the bulbs in the garage from the mains started to shine much brighter.
the bulbs were 10% brighter when the heater was sparking
the heater seemed to consume same power
the bulbs were not getting dimmer when heater got switched on, could tell this easily with my eye.
feeding energy back to the mains?
im no electrical engineer, im sure verpies can explain it and most of you but i cant
Shokac
Quote from: Zeitmaschine on October 28, 2012, 07:20:23 PM
They should cancel all pages with no useful info on it. Then the counter is back to 25. ;)
And now for something serious. This subject has been probably discussed a hundred times before (I presume), so it will surely not matter to discuss it again the one hundred and one time:
Stepanov transformer 1
Stepanov transformer 2
Stepanov transformer 3
Actually I cannot find much discussion on the web about these videos, although Stepanov shows briefly his secret.
The patent:
Arkady A. Stepanov Energy converter
I stumbled over these videos already a few months ago, but failed to associate them with the Kapanadze device, because at this time the wide-spread idea was that the Kapanadze device is based on high voltage and high frequency. But now I think it is rather not.
There are three possibilities regarding this patent: The Stepanov device (transformer) works but,
a) no one is able to replicate it due to unknown values of the components
b) the drawing and/or description of the patent are intentionally wrong/incomplete
c) successful replications are not made public
In the Stepanov patent drawing I can see a transformer and two choke coils, a capacitor and two diodes. In the Kapanadze 2004 video I can see (minus some decoy parts) a transformer, four diodes and a capacitor (and two parts on heat sinks). I can see in the Kapanadze tent presentation a lot of three-phase capacitors. I can see two big three-phase capacitors in the Stepanov video. I can see (although barely) a three-phase transformer in the Kapanadze blue coil presentation. I can see three-phase transformers in the Stepanov video. Is this all pure coincidence?
Hence could there be a connection of the principle of work between the Kapanadze device and the Stepanov transformer?
What puzzles me is that the Stepanov transformer does not require grounding (or does it?). But on the other hand the Stepanov transformer works for sure without high voltage or high frequency (and such fancy things like spark gaps). Therefore, why should the Kapanadze device need this?
What puzzles me also is that I can't see any chokes in any of of the videos, but they are in the patent drawing. Hence could it be that a (ordinary) transformer is being used as a choke? But the two chokes in the Stepanov patent are not magnetically coupled, so this would then require three transformers in total. Or could it be that the (Kapanadze) trick is to accommodate all these coils in one transformer?
If the heavy white cable that goes to the plus pole(!) of the battery is a virtual ground then the 8.2 amps reading of this wire means that the battery provides this (additional?) current with a single-sided connection only. This is even stranger than drawing 25 amps single-sided from real ground. Further this means that 8.2A × 206.8V = 1695.76W is the output power compared to 36.1A × 12V = 433W (if battery has 12 V) which is the input power.
Therefore my enlightenment: Ground is needed apparently, but ground means not necessarily a connection to earth. Maybe it needs plus of the battery, maybe it needs minus of the battery, maybe it does not matter so it needs only a metal object, namely the battery. This gets more and more strange. But (fortunately) there are no signs of gravitational effects. This gravitational babble could be a decoy also to make the device look more sophisticated than it really is.
Further readings:
The resonant power amplifier current of industrial frequency
Here I can see a drawing with transformers, chokes, a capacitor and a diode bridge. Interesting. Could it be that the diode bridge in the Kapanadze 2004 video is not connected to the capacitor in order to get smooth DC like in a ordinary power supply, but both, the capacitor and the diode bridge are connected in a completely different way to the transformer? Is the TK diode bridge really a diode bridge or does it only look that way?
So as it seems the whole TK stuff boils down to the ingredients of transformers, chokes, capacitors and diodes. And maybe the latter one is the missing link. Thus it's high time to figure out how to connect all this junk properly together, because I'm sick to spend time and money over and over for nothing. There is a great chance that members of this forum are soon the last ones on earth who don't know the secret ...
OT: All special characters here on the site are messed up lately, especially the Russian ones. Test: Капанадзе
Zaitmashine,
use this circuit and try stephanov shematic. http://4hv.org/e107_plugins/forum/forum_viewtopic.php?122354
This circuit make automatic resonac circuit between capacitor and inductor. Connect current transformer like Stepanov and try this.
It's very simple!
a.king21
Quote from: Hoppy on November 01, 2012, 04:23:23 AM
Of course he uses his own mains power. It is in his patent. He even shows his use of an inverter. The present thread is seeing the essential similarities with all these OU systems.
We can now add the mysterious coil shorting used by Aviso to out list of solved cases.
The only difference is in the method of obtaining and controlling this radiant energy.
TK can build his own inverter or  uses a proprietary one.
The main problem here is in getting the correct transistors. (the same problem Aviso had).
TK even shows you blowing a transistor in Aquarium 1.
My gut is that solid state relays may not be fast enough, but I hope wattsup succeeds.
We need to find a good igbt driver circuit.
I think we all agree that we are getting there at last.
So I am asking for help from the EEs amongst us.
CAN YOU DESIGN A RELIABLE IGBT DRIVER CIRCUIT PLEASE?
Zeitmaschine
Quote from: Shokac on November 01, 2012, 08:19:16 AM
It's very simple!
And hot!
He melted a brass coin with an input power of 600 watt.
Now question: Is it possible to melt a brass coin with a hairdryer which consumes 1500 watt? Never heard of such a thing. My hot air gun consumes 2000 watt and I'm very sure I can't melt brass or aluminum with it. Not even when the brass would be in direct connection with the heating element of the hot air gun.
Hence where is the energy coming from that melted the brass coin? ::)
Any ideas? ;D
