0 Members and 45 Guests are viewing this topic.
Cap-Z-ro
I'm getting a little confused with the logic being applied here.
If TK is not an EE then why is one needed to build a driver circuit...if the working principle is "so simple you will laugh" ?
Regards...
Hoppy
Quote from: a.king21 on November 01, 2012, 09:53:54 AM
Of course he uses his own mains power. It is in his patent. He even shows his use of an inverter. The present thread is seeing the essential similarities with all these OU systems.
We can now add the mysterious coil shorting used by Aviso to out list of solved cases.
The only difference is in the method of obtaining and controlling this radiant energy.
TK can build his own inverter or  uses a proprietary one.
The main problem here is in getting the correct transistors. (the same problem Aviso had).
TK even shows you blowing a transistor in Aquarium 1.
My gut is that solid state relays may not be fast enough, but I hope wattsup succeeds.
We need to find a good igbt driver circuit.
I think we all agree that we are getting there at last.
So I am asking for help from the EEs amongst us.
CAN YOU DESIGN A RELIABLE IGBT DRIVER CIRCUIT PLEASE?
Yes, but how does he get the mains into the aquarium2?
See attached design PDF.
ariovaldo
Guys, it looks like crazy, but I'll try this weekend to fit a katcher coil inside of aluminum tube with transformer oil. It will be something close to the Tesla "device"......
Did somebody try that?
http://www.teslasgenerator.net/nikola-tesla-high-frequency-electricity/
Zeitmaschine
Quote from: Cap-Z-ro on November 01, 2012, 10:12:37 AM
Perhaps we should play dumb and start again at square one. :)
What is an LC circuit? Wikipedia says:
»An LC circuit, also called a resonant circuit, tank circuit, or tuned circuit, consists of an inductor, represented by the letter L, and a capacitor, represented by the letter C. When connected together, they can act as an electrical resonator, an electrical analogue of a tuning fork, storing energy oscillating at the circuit's resonant frequency.«
What can we do with an LC circuit? Wikipedia says:
»The resonance effect of the LC circuit has many important applications in signal processing and communications systems.
1. The most common application of tank circuits is tuning radio transmitters and receivers. For example, when we tune a radio to a particular station, the LC circuits are set at resonance for that particular carrier frequency.
2. A series resonant circuit provides voltage magnification.
3. A parallel resonant circuit provides current magnification.
4. A parallel resonant circuit can be used as load impedance in output circuits of RF amplifiers. Due to high impedance, the gain of amplifier is maximum at resonant frequency.
5. Both parallel and series resonant circuits are used in induction heating.«
This leads to the following considerations:
We take a look at the first example regarding the tuning of a radio. A transmitter sends out radio waves with a certain frequency, then a receiver is tuned in on exactly that frequency by means of a resonating LC circuit in order to receive only this single station. All other waves coming form other transmitters with different wavelengths are getting blocked.
But are they really getting blocked by the LC circuit? If an LC circuit in a radio blocks all frequencies which are not in resonance then consequently a radio without an LC circuit (maybe because the LC circuit in the radio is broken) should receive all frequencies of all stations at once because no frequency is blocked. But I can't remember having ever seen a broken radio that receives all stations in range simultaneously. Why is that so?
Is that so because the LC circuit does not block all non-resonant frequencies but it rather amplifies the resonant frequency? If so then where is the energy coming from which is needed to amplify the resonant frequency? Is the energy coming from a battery or power supply (as generally accepted)? If so then how can a Crystal Radio (notice the grounding) without any power source receive a resonant radio station?
Is that so because the energy which amplifies the resonant frequency is coming rather from the aether than a battery? And here the aether means literally the aether, not the remote radio transmitter. The transmitter (the radio station) provides only the resonant frequency but not the power.
Now, could it be that this fundamental principle works independently of the frequency range? Hence could it further be that Kapanadze's inverter is the »radio station« (directly connected not via antenna) that provides the resonant frequency (of 50Hz) but it does not provide the power? The power is actually provided by the aether by means of a resonant LC circuit the same way like in a Cristal Radio? ::)
Thus any Cristal Radio would be an »Over Unity« device per se (just as a side note).
Therefore could someone please do quick experiments on that basis so I can save my own equipment ... 8)
Quote from: a.king21 on October 31, 2012, 09:57:24 AM
As wattsup has just said, it's so simple he is beginning to feel intellectually insulted.
Yes, indeed. :(
Shokac
Quote from: Zeitmaschine on November 01, 2012, 10:10:03 AM
And hot!
He melted a brass coin with an input power of 600 watt.
Now question: Is it possible to melt a brass coin with a hairdryer which consumes 1500 watt? Never heard of such a thing. My hot air gun consumes 2000 watt and I'm very sure I can't melt brass or aluminum with it. Not even when the brass would be in direct connection with the heating element of the hot air gun.
Hence where is the energy coming from that melted the brass coin? ::)
Any ideas? ;D
Try!
Not hot if connect biger coil and current transformet with diods. :-) :-). Like Stepanov
Current in this paralel resonance is very HI, about 100Amps, and voltage is cca 30V.
Circuit consumes 7-8 Amps on the 12V battery :-)
