0 Members and 233 Guests are viewing this topic.
a.king21
Quote from: Cap-Z-ro on November 01, 2012, 10:12:37 AM
I'm getting a little confused with the logic being applied here.
If TK is not an EE then why is one needed to build a driver circuit...if the working principle is "so simple you will laugh" ?
Regards...
1 Because IGBT's do a better job than junk transistors
2 Because I don't want to waste bucketfulls of transistors figuring it out.
Once we have the schematic, you can build the device in a weekend.
That, to my mind,  is simple.
Now when you look at his videos, especially the green box and the 2004 videos, you can understand the concerns. They put the device  on, prove their point, then switch off as quickly as they can.
Later on TK obviously fixed the problem by finding correct transistors.
We have the record eyewitness accounts of 4 and a half hours continuous into a 2 KW load.
That is PRECISELY the reason I asked for a long demo with no switching complications.
ie I wanted to be sure that he had fixed the transistor overheating problem.
Cap-Z-ro
I am getting the feeling transistors may have been used in earlier versions, but now are a decoy, and that the pulse rate is more like that of ocean waves hitting the shore...similar to the electric fence pulsers we had on the farm.
Regards...
verpies
Quote from: energia9 on November 01, 2012, 05:42:36 AM
somebody knows what happens when...
i have a 2.5 kw heater (heating homes)
accidentally the heater was sparking inside its circuit. spark gap occured inside it when i moved it.  it was constant after a few hits.
and the bulbs in the garage from the mains started to shine much brighter.
the bulbs were 10% brighter when the heater was sparking
the heater seemed to consume same power
the bulbs were not getting dimmer when heater got switched on, could tell this easily with my eye.
feeding energy back to the mains?
im no electrical engineer, im sure verpies can explain it and most of you but i cant
I cannot explain it without further experiments.
If your light bulbs are of the incandescent type and there are no errors in your house wiring (e.g. ground loops or incomplete grounding) then this effect seems anomalous.
a.king21
Zeitmaschine: I have already published the link where radiant energy is discussed.
Wattsup understands the principle also.
I don't understand your confusion.
Zeitmaschine
Quote from: a.king21 on November 01, 2012, 05:26:47 PM
As it seems he has fixed this overheating problem very well, because on the plastic boxes of the 2KW device I can't see not even the slightest hint of a ventilating slot or something like a heat sink. The other possibility would be that there never was an overheating problem with transistors, because no one cares about heated transistors in the 2004 Video.
Quote from: a.king21 on November 01, 2012, 06:08:01 PM
Confusion is the still missing working replica of the TK device.
