0 Members and 124 Guests are viewing this topic.
verpies
Here is a video of near-field wireless power transfer for those of you who wonder whether the aquarium frame of Mr. Kapanadze's devices, contains 3 mutually perpendicular pickup coils.
http://youtu.be/SAbgpMNteCw
P.S.
The power transmitting coil ideally would be located inside of the floor/ceiling or inside walls of the room - that's why it is important to take any extraordinary DUTs outdoors, in order to eliminate this method of power transfer.
energia9
i have a question for all of you
is the depalma generator fake?  i have seen documentary that some scientists in hungary confirmed the generator to give way more power then was going in it.
very small voltage but very high amperage.
I think this generator could be made Solid state,  the question is..How??
And wheter this is the moving version of kapanadze.
If motor works on a similar principle than a transformer,
Then this wierd motor could be made into a transformer too
How??
also You guys have ignored my post about this gentleman...
up to 900% efficiency claimed:
http://www.rexresearch.com/imris/imris.htm
So simple you will laugh....   1 secret component of kapanadze..?
A highly pressurized spark gap? is that all?
The spark gap might be hidden anywhere you know...  inside those little boxes or even inside the coil in some demos.
The spark gap this guy was using is pressurized with xenon at 6.6 bar of pressure.
I have seen patents on other gases which show excess energy output too in the same fashion with high voltage.
XENON, OZONE, NITROGEN, ARGON, etc.
i dont think this is a trickery. it is documented all around.
put your hands up who tried this at all..  dont think so :)
No head scratching.  Just need to make the component thats all.
Anyone is experienced in working with gases pressurizing vessels, melting glass etc..?
dont ignore this or i will know you are ignoring it or hiding it by intention.
it is a fact that it is the simplest experiment.
verpies
Quote from: energia9 on November 02, 2012, 05:30:42 AM
Is the depalma generator fake?
This generator really produces electric current.  It's a very old design that has been invented by Faraday. Read about it here.
I have seen documentary that some scientists in hungary confirmed the generator to give way more power then was going in it.
I have never seen those claims validated, and there were many replication attempts over many decades.
I don't think so. The motion between the disk and the external circuit with load on it, is essential to the operation of the device.
However I have never seen a version of this motor, that has multiple radial load circuits that are stationary but switched by mechanical means (or by transistors).
It works on the principle of charge separation by Lorentz deflection.
Most likely your post will be ignored because it is off-topic in this thread.
This thread is not for discussion of all OU devices.
There are other threads about rexresearch and the N-machine on overunity.com
I am replying only because there is so little traffic here lately.
Zeitmaschine
Quote from: TinselKoala on November 01, 2012, 11:09:15 PM
If you just remember that energy, not power, is the conserved quantity, you won't go wrong. Energy in = energy out, minus losses. Peak power in can be much less than peak power out, if the power is converted to pulses of short duration. But average power, measured correctly, should show the same kind of equality as total energy.
So does this mean every radio station is a »Over Unity« device? Still unclear, therefore I will calculate this stuff vice versa:
The input of a medium wave transmitter shall be 85 kilowatt at 50Hz coming from the power station. That's all we have. The output of the headphone (earphone) shall be 50Hz audio sine wave, so the output has the same frequency and waveform as the input.
The transmitter covers an area of 100 square kilometer. That means if the covered area is (most likely) circular then the farthest receiver would be at a distance of just 6 kilometer (rounded up). 85,000 watt ÷ 100 square kilometer = 850 watt. Each square kilometer receives therefore 850 watt. One square kilometer has 1,000,000 square meters. Hence 1 square meter receives 0.00085 watt of the initial input power (or energy, however named). The ferrite rod of the Crystal Radio has a size of 10 × 1 centimeter. That is 1 one-thousandth of 1 square meter (one square meter can hold 1,000 ferrite rods). Hence 0.00085 watt ÷ 1,000 = 0.00000085 watt for each ferrite rod and earphone. Now 0.850 watt equals 850 milliwatt, 0.000850 watt equals 850 microwatt, 0.000000850 watt equals therefore 850 nanowatt.
Hence is it possible that a headphone of a Crystal Radio can produce any audible noise with an input of just 850 nanowatt? If not then where is the additional energy coming from? For comparison, a hifi headphone runs with approx. 0.1 watt (and higher) that's 100 milliwatt.
Therefore the conclusion from this could be that »Over Unity« in electric equipment is an everyday phenomenon but usually so small in size or hidden in some way that no one will notice it.
Quote from: verpies on November 02, 2012, 08:20:09 AM
Maybe some people here have already figured out how the device works, so they just quietly disappear from the forum ...
