xenomorphlabs
Quote from: Zeitmaschine on November 04, 2012, 01:15:41 PM
So at first it is a simple circuit that consists only of an AC power source a 500 watt light bulb and an ammeter. Then he connects an additional element to that circuit. This element is a tuned amplifier with a resonance phenomenon. It is connected in series (in the chain) with the other elements (two pins, one in and one out, as I understand this). Now, what element could this be that reduces the power consumption of the light bulb from 500 watt to 42 watt with two pins? ::)
No matter what it is, what it does is that it exhibits significant negative resistance or inductance (if you just look at it as a black box (or carton like in his vid))
The fact that it self-tunes on top of it, is the one that makes it work, without accurate tuning of such circuits you will not see the effect.
All assuming that the power measurements were done correctly. Only self-looping is the true proof anyway, power measuring is always prone to errors.
Stepanov sais in the video that under the box there are simply diodes, condensators, an induction coil and an accumulator.
All you need to build a resonant extraction circuit a la Hector :D
Zeitmaschine
Quote from: xenomorphlabs on November 04, 2012, 03:04:06 PM
Then why are we looking (instead of simple diodes, induction coils and capacitors) at such things:
xenomorphlabs
Quote from: Zeitmaschine on November 04, 2012, 03:54:39 PM
Well since the diodes don't switch themselves around, you need quite a complex control circuit if you wanna go down the
reactive power transformation road. But that requires sophisticated engineering.
Personally i think the power measurements Stepanov made were inadequate in regards to the errors that can occur while power metering in general as Albert pointed out on his channel.
Question: Did Stepanov present anything self-looped? (To my knowledge not)
TK being an architect and not a rocket scientist makes it likely, he discovered a simple but effective method that does
not require complicated circuits.
frankidel
So does everybody think that the Fabrice Andre replication is BS.
Zeitmaschine
Quote from: xenomorphlabs on November 04, 2012, 04:14:03 PM
If Stepanov system is equal to Kapanadze system then Kapanadze did this for him.
Quote from: frankidel on November 04, 2012, 05:05:12 PM
99% of all replications are BS. Now we have to find the 1% that is not.
And page counter goes higher and higher and higher and ...
