0 Members and 1889 Guests are viewing this topic.
xenomorphlabs
Quote from: forest on November 06, 2012, 03:53:01 PM
Let's talk theoretically. 13Amps used vs 80amps if you use ordinary inverter. What is this telling us ? First way of OU could be a special transformer with resonance on primary not disturbed by getting out power from secondary and also with resonant minimalized current consumption of primary. This is interesting , he had to match primary capacitor , switching rate and primary inductance to get minimalization from 80 amps down to 13 amps . Perfectly possible for clever man in oscillating circuit IF there is no secondary loaded. That I would do first , to minimize input current via resonance.
The rest is in construction of transformer which very closely resemble what I saw in Vladimir Utkin doc probably - a divertion of magnetic flux. Like many other devices. Look it is even visually close to Gabriel toroid device if you know what I'm talking about...
You have a point. The only difference is in the topology of the transformer. The guy might even use that Radio shack inverter circuit at 60 Hz lol.
From what can be recognized from the footage he stacks 2 toroidal transformers on top of each other and has put something
inbetween them. That could be either simply a separator or an isolator/dielectric. The primary is wound around the WHOLE thing.
The lamp just is connected to the upper toroid.
There is several possibilites why this could hypothetically yield more energy.
One is that an additional capacitive effect is used in addition to the magnetic effect.
Another could be that the two toroids TOGETHER form field lines of such orientation as a combined field that a reflection to the primary
is cancelled somehow (very speculative though).
captainkt
@forest Hi yes interesting could be a very basic inverter that can be overloaded without dropping out. Most people me included try to experiment with conventional inverter which either cuts out or blows up. Add this inverter at 50/60 HZ to a kapanadze type coil with earth grounding and no spark for just show. I will try.
Keith
captainkt
@xenomorphlabs, with two identical toroids is it possible that they resonate with each other without affecting the primary. Load is taken from one toroid which is similar to many other circuits including the stephan circuit with load only from one coil leaving other coil with loose end not connected.
Keith
xenomorphlabs
Quote from: captainkt on November 07, 2012, 06:30:01 AM
Keith
Keith, a lot of things are possible, but i am trying to figure out how exactly.
Magnetic field lines are contained in the toroidal cores, so it can't be magnetic coupling.
EDIT: Now re-thinking that for a second. What if the material between the 2 toroids would be magnetic sort of like a magnetic shunt between the two toroids?
It's a shiny material, so less likelihood for a dielectric there rather than iron etc.
Something to think about.
I still see the option that if he reversed the winding direction of the lower toroid then maybe the electric field lines
of both toroids exert a stronger force on the electrons in the primary circulating in the primary wire around that whole thing
as if 80 amps worth of current are running through there. Trying to figure that out with diagrams.
In the diagram below the electric field lines as a consequence of magnetic flux in the toroids would buck each other.
So should they somehow accelerate any charges at one toroid there would be a braking force at the other one.
This would of course be true for any lenz currents. However i am not knowledgable enough in the area of external electric fields
interacting with charges in a conductor  to be able to make any elaborate statement about the matter.
Nonetheless if that would be a way to tackle lenz currents, then the reflectivity to the primary would be completely neglected.
