0 Members and 151 Guests are viewing this topic.
sparks
     I like these choke coils.  The voltage from the power scource on completing the circuit doesn't blow-up the air.  But on opening the circuit quite dramatic.  The energy is conserved while the power is gained.  There is no free-energy here.  It just gets the job done or punches through.  Electrical equivalent of an archer.  The archer can put just as much effort into throwing an arrow as he can cocking the bow.  Which gets the job done?  A carpenter can drive a nail through a board with a hammer or he can use the hammer to try to push the nail through the wood.
http://www.youtube.com/watch?v=aSmMFog10D0
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Hoppy
Quote from: verpies on November 08, 2012, 08:03:31 AM
No - the braid can carry both ("live" and "neutral"). The braid is composed of many wires (conductors). Those wires can be enameled and isolated from each other. Like this.
The enamel is transparent and hard to notice and it can withstand 3000V on a standard magnet wire.
So, the two faces of the braid could be used as seperate and electrically isolated conductors. Do you think that the 1KW-2KW heater could conceivably run on the braid shown in the video connected to an external 440V / 480V single phase supply?
Hoppy
Quote from: wattsup on November 08, 2012, 09:17:17 AM
@Happy
Thanks for your response. You see that logic does not hold up when you put it beside the Green Box device where TK removed the wire to the ground pipe and connected the wire going to the radiator. With the rad the device still started but the output was very low. This confirms he needs a constant neutral or very well grounded source by having tried that myself, I would confirm more the requirement of a real neutral connected to the AC mains and not a grounded rod or object.
Also if you consider the Aq2 device ground was only a damn bolt in a block of cement that would have been a worst ground source then having the buried radiator, that bolt must have a wire connected on the other side under the cement block and going somewhere to a real AC neutral, so this confirm more the choice A above. I am not saying this takes away from the novelty but it puts the effect to be more dependent on an outside influence then they are showing.
wattsup
@ wattsup
If I understand verpies correctly, he is saying that the braid does not need to be physically split where it is on show to form two conductors because each copper strand is individually insulated. Therefore, the braid could pass under the bolt and down into the ground under the manhole cover, without damaging the insulation. The two sides of the braid could then have been cut in half and each half stripped of insulation to provide two separate conductors. The same could be done in the aquarium.
Happy
leo48
QuoteAnd in the Aq2 there is only one braiding that is bolted to the cement block
The bolt could be the projecting portion of a rod grounding
iron copper 2 meter long and 16mm in diameter
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
Jon_sparky
Full respect to wattsup, aking and good folks here keeping this ship on course despite the occasional tsunamis.
Im an intuitive engineer not an EE. From my research, the following theory may be useful here for reverse engineering TK´s tech.
Paul Dirac´s 1928 proof of the ether – "Dirac´s Equation and the Sea of Electrical Energy" parts I and II here.
http://openseti.org/Docs/HotsonPart1.pdf
http://openseti.org/Docs/HotsonPart2.pdf
1.   What is Electricity?
Ether is an electrical fluid, the "Dirac Sea" or Tesla´s "Radiant Energy" - The electrical plasma of the universe is like the plasma of our blood, it flows throughout the body of the universe to an intelligent design. Walter Russell, philosopher and free energy scientist, described it as a thought driven electrical universe. Science cant understand where the power is coming from until it reinstates the ether as part of or similar to Lovelock´s Gaia Hypothesis, i.e. the universe is a living being and we are its mind cells... ?
2.   The Earth as a Capacitor in an electro-magnetic solar system
The Earth is a capacitor in the solar system circuit receiving its energy via electro-magnetic induction. The Earth is like one battery plate, the electrical circuit can supply the other "plate". Can also be an antenna. What is needed, we know,  is a dipole, to disturb the radiant sea.
3.   Disturbing the Sea – the radiant surge
Tesla observed the surge of electrical radiant energy on closing the switch of the early DC generators. That surge is created by shorting the battery plates between the radiant source (earth plate) and the circuit, in rapid succession, to discharge to the load. The plasma, or air, acts as the electrolyte. The DC switching is established by the frequency generator and or spark-gap.
This is also the reason for the quarter wavelength frequency 1:4 ratio between L1 and L2 coils in an LC circuit because the quarter wave rise establishes the potential difference (+ve component) and nature supplied the other (-ve) component wave half.
4.   Load as environmental imbalance
Nature abhors a vaccum and seeks to cancel out or balance the potential difference. With TK the load is seen by the (radiant) source as a dipole difference or vaccum to be filled.  Bedini´s monopoles can charge 4 batteries from 1 primary because the 4 bats are seen as the load, charged with higher voltage pulses than the charge battery. The primary only serves to drive the "switch". Same with TK, he starts his device with just enough juice to discharge a cap and establish the quarter wave.  From my tests it is clear that Bedini´s voltage spike has to be a radiant spike not an electron spike otherwise it simply takes the juice from the primary.  Did Bedini actually earth his charge batteries (led to ground hint?)
A lot more to figure out before applying this to circuit building but this perspective helped my progress so far.
Practical criticism anyone?
