0 Members and 159 Guests are viewing this topic.
a.king21
For Heaven's sake:  TK's cleverness was to conceal that he was using radiant energy.
There are a million ways to get there.
Look at his patent. For "frequency generator" read "spike"  or "radiant energy" generator.
If 2 kw was generated the normal way, he would have needed a 2kw inverter. Imagine the weight.
It is clear that you can capture the power and use radiant energy to freely replenish or even increase  it.
TK's device was very light.
Hoppy
Quote from: a.king21 on November 08, 2012, 02:20:13 PM
Its not clear at all!
I agree with wottsup that a braided cable with insulated strands is unlikely but so is the suggestion that the device runs entirely on the capture of radiant energy from the environment. We appear to be no further forward in solving this mystery.
Hoppy
forest
Imagine what damaged generator in Tesla experiments in Colorado Springs in 1899.
Wireless power ?   :o  [size=78%]highly improbable [/size]
What remain ? Maybe excess current returning via AC neutral ::)
Zeitmaschine
Quote from: Сергей В. on November 08, 2012, 11:33:01 AM
Привет всем !!
Yes wattsup you get a TK secret. Diodes he used were old Russian Rectifier Diffusion Diodes - not in Rectification mode but in DSRD mode or Nano-Pulsing mode !!
Is there something in the last few posts that needs to be buried quickly? ;D ::)
Unfortunately one wire goes from the diode plate to the 50Hz transformer, not to a transformer (Tr1) that could provide high frequency pulses. In addition I can't see a coax cable anywhere near the diodes.
Big silver capacitor besides diodes pcb is not an electrolytic filtering capacitor but HV blocking capacitor. Use special HV Impulse Capacitor about 1-2 nF with working voltage minimum 2KV-DC. More is better. I can suggest you Oxigen free copper coaxial cable and Oxigen free copper pipe for biggest coil and grounding.
No way the big silver cylinder is a 1-2nF capacitor. If so what are the bank of silver capacitors in the tent setup? All 2nF HV?
Quote from: sparks on November 08, 2012, 09:24:06 AM
I like these choke coils.  The voltage from the power scource on completing the circuit doesn't blow-up the air.  But on opening the circuit quite dramatic.  The energy is conserved while the power is gained.  There is no free-energy here.
If the circuit is closed just as long as it needs to get the full BEMF on opening, then could it be that there is more energy in the BEMF than in the current that was needed to create the BEMF?
Quote from: Farmhand on November 07, 2012, 05:46:20 PM
To all, The emf from a coil is not back emf either, it is regular forward emf as it is in the same direction as the applied emf. Back emf is what opposes the charging of the coil. As soon as the applied emf is halted the back emf stops then when the coil discharges it's energy the emf produced is forward emf which in turn faces more back emf due to the inductance of the current path of the discharge from the coil.
The discharge from a coils magnetic field collapse is not Back emf.
But it is energy regardless whether we call it Back EMF or not (see image below). If the energy can be found in the Forward EMF then no problem with that. But the question still is, how to get grip on it?
Black_Bird
Quotecall it Back EMF or not (see image below). If the energy can be found in the Forward EMF then no problem with that. But the question still is, how to get grip on it?
what if you put a capacitor in parallel with the switch. When the switch opens, the current will charge the capacitor. After that you have to figure a way to extract that energy from the capacitor to your load, before closing the switch again.
