a.king21
Quote from: Hoppy on November 08, 2012, 03:27:29 PM
Its not clear at all!
I agree with wottsup that a braided cable with insulated strands is unlikely but so is the suggestion that the device runs entirely on the capture of radiant energy from the environment. We appear to be no further forward in solving this mystery.
Hoppy
Have you even read "Free energy generation" by Bedini/Bearden?????
Do you understand cold electricity?
Do you understand conditioning of capacitors?
Do you understand the Dirac sea?
I would not dare post such a statement without facts like you do.
This is not a place for beer talk.
Hoppy
Quote from: a.king21 on November 08, 2012, 05:15:25 PM
Have you even read "Free energy generation" by Bedini/Bearden? ??? ?
I have the book and have read it cover to cover many times. I have built many versions of SG and SSSG, and Window Motor, 'G' Field etc., over the last four years. I know how the SG works in-depth because I've charged / discharged batteries a multitude of times using the SG and variants, taking data and studied every aspect of the device. I've also built the electro- mechanical 'FEG'.
Hoppy
xenomorphlabs
Quote from: Hoppy on November 08, 2012, 05:43:49 PM
I have the book and have read it cover to cover many times. I have built many versions of SG and SSSG, and Window Motor, 'G' Field etc., over the last four years. I know how the SG works in-depth because I've charged batteries a multitude of times, taking data and studied every aspect of the device. I've also built the electro- mechanical 'FEG'.
Hoppy
Have you reached a C.O.P of > 30+ like TK with your SGs then too? ;)
Well joke aside (i have built them too ad nauseum) , i am certain Bedini knows how to build a serious OU device, but he is very wise just manufacturing slightly higher than Unity devices for a healthy long life.
After all him and Bearden had the chance to check the VTA inside out and many others.
a.king21
Hoppy
[/quote
Good, then you'll understand that Bedini did not loop it. TK did.
You should also see that radiant energy leaks all over the place in the Bedini builds as evidenced by the fact he  can light an ne2 bulb from the battery casings and from the floor. That's the problem TK has tackled and won.
If you look at the way TK deals with radiant energy leakage in his solid state devices you should see how he does it.
It's all there in plain sight.
If you would use the same techniques in your Bedini builds you should increase the efficiency many fold.
Good luck.
a.king21
Bedini SG. Also the one thing Bedini does is use a lightweight wheel in the SG.
It should be as heavy as possible.
Bedini is  being forced to turn his device down by the NWO.
