0 Members and 41 Guests are viewing this topic.
Hoppy
Quote from: xenomorphlabs on November 08, 2012, 05:54:21 PM
Have you reached a C.O.P of > 30+ like TK with your SGs then too? ;)
Well joke aside (i have built them too ad nauseum) , i am certain Bedini knows how to build a serious OU device, but he is very wise just manufacturing slightly higher than Unity devices for a healthy long life.
After all him and Bearden had the chance to check the VTA inside out and many others.
If de-sulfating a battery and continuing to improve its condition (lowering internal resistance through charge / discharge cycling) = COP>1, where COP 1 = the condition just prior to the first conditioning cycle, then I have achieved this  :)
As for TK using a SSSG type generator, he would need a mighty big PSU to produce sufficient radiant to run his lights / heater.
Hoppy
a.king21 wrote: -
Hoppy
Good, then you'll understand that Bedini did not loop it. TK did.
You should also see that radiant energy leaks all over the place in the Bedini builds as evidenced by the fact he  can light an ne2 bulb from the battery casings and from the floor. That's the problem TK has tackled and won.
If you look at the way TK deals with radiant energy leakage in his solid state devices you should see how he does it.
It's all there in plain sight.
If you would use the same techniques in your Bedini builds you should increase the efficiency many fold.
Good luck.
@a.king21
With respect, a while ago, you had no more idea than anyone else in this thread as to the working principle of the TK device and was following wottsup's excellent investigation trail in the hope that he might discover how TK did it. Now, all of a sudden you appear to know exactly how the TK device works.  ???   Maybe you could enlighten us with the aid of a circuit schematic as to the techniques Bedini used to increase efficiency many fold by reducing radiant leakage with the SSSG.
andrea76
Quote from: TinselKoala on November 07, 2012, 04:59:56 PM
Huh?
I've looked at the videos, I like the nice inverter packaging... but ... huh?
The schematic diagram linked is an ordinary 4047 multivibrator chip driving a pair of Darlington pairs. If this is done right, the transistors switch at the zero-crossings of the output waveform and hence stay cool. The 4047 allows the user to control the frequency rather than it being self triggering and self-resonating like a Royer oscillator, as used in my wireless power systems and flyback drivers and in inductive heaters ( which I might try building next). Google for "ZVS circuit" and you'll find a lot of information on zero-voltage-switching circuits.
I think it's an either-or: he's using the 4047 based homemade version in his white tube inverter and the commercial unit (very neat) in the other one. But I think his frequency citations aren't right when he talks about the output freqs of that unit.
The transistors in the schematic could be any Darlingtons with the required ratings, or mosfets of low Rdss. The transformers are designed by their designers to work best at a certain input frequency, and the knob on the little multivibrator circuit allows one to find the best input frequency. Coincidence that it happens to be the frequency that the transformers were designed for? They also have large thermal mass and will take quite a while to heat up... the batteries will run down first.
The 4 x 500 W bulb demonstration drew the supply down and did not make anywhere near 2000 Watts of light.
So I have got to ask.... huh? What's the big deal?
SM wrote about strange things happened when 2 transformer get slightly out of phase.one of the asimmetrical out of 4047 is slightly out of phase? what's happen in the transformer??
dllabarre
Quote from: Hoppy on November 09, 2012, 03:48:07 AM
@a.king21
With respect, a while ago, you had no more idea than anyone else in this thread as to the working principle of the TK device and was following wottsup's excellent investigation trail in the hope that he might discover how TK did it. Now, all of a sudden you appear to know exactly how the TK device works.   Maybe you could enlighten us with the aid of a circuit schematic as to the techniques Bedini used to increase efficiency many fold by reducing radiant leakage with the SSSG.
Good Luck Hoppy
I asked a.king for a schematic and parts list just the other week and I haven't received anything yet.
DonL
27Bubba
Because he got a reason not to..  ;)
"Ok - replicate it and pm me. We'll do a deal. We have two factories waiting."
Reply #12822 on: August 11, 2012, 07:37:54 PM »
