0 Members and 126 Guests are viewing this topic.
a.king21
OK. I have pointed out in previous posts how TK did it.
I figured out how because I have contact with the guy.
I am not going to do a schematic. Just go over my posts.
You might also look at the spike generator hidden in plain sight in
Tesla's patents.
We don't have to get to 220v 50hz in one go.
Funny how TK's got a mechanical version - just like Bedini.
The difference is TK camouflages his builds. Uses smoke and mirrors.
Wattsup is going to get there with a bit of luck.
You don't need a massive Bedini board. Just start working with mains.
And take care. It kills.
Tesla worked with mains.
xenomorphlabs
Quote from: a.king21 on November 09, 2012, 11:22:50 AM
Tesla's patents.
So just to be sure you are understood right.
You are saying that the reason Bedini has not seen massive C.O.P.s with his SG
is due to the fact that he did not loop it, is that correct?
So according to this, the sheer action of looping it, is creating the energy gain and without doing so there is nothing to notice.
Thing is, there are many people, including myself, that did in fact attempt to loop
SGs and there are also people who did in fact use heavy flywheels like you also say
is critical to reach OU with an SG. With no success. In fact some people have dedicated more than a decade to
reach that goal with no success and all imaginable variations to do so. With many thousands of Bedini motors built worldwide.
Why has no-one involved with Bedini stuff ever stumbled across a massive (COP>30+) energy gain
spiking his batteries? This is a question that requires a serious answer.
sparks
  How could the efficiency of the below demonstration be improved?  Inductance is the result of a current passing through space and altering the magnetic permeability of that space.  The conductor providing the path of the current finds itself lying in a changing magnetic field.  It produces counteremf. Current flow is impeded so lets get rid of the resistors and replace them with very large capacitors.  Now the voltage of the scource appears on one plate of the capacitor bank appears on the other capacitor plate and onto the solenoid through the solenoid and back to the other side of the scource.  Electrons begin to flow from cathode to anode but can't "kill the dipole" without dielectric failure of the capacitor bank.  At first this current is impeded due to the inductance of the solenoid.  Upon core saturation the impedance drops to just the resistance of the solenoid wire and the capacitor charges depending on rc curve which is almost linear.  Now we have energy stored in the magnetic field of the inductor and the electric field inside the capacitor.  Now open the switch.  The magnetic field surrounding the solenoid is RETURNED to some chatoic state by some power from somewhere.  If the core just stayed at the same magnetic flux density things would be different.  That is why ferrite is out of the question.  They use ferrite for it's retaintance properties not it's ability to respond to ambient field conditions.  The magnetic field flux surrounding the inductor (in this case solenoid) collapses.  Conductors lieing in a changing magnetic field induce voltage.  This induces a voltage that opposes the collapse of the magnetic field.  This counteremf is such that it is the same polarity that charged the capacitor to begin with.  The problem now is that the capacitor has an open leg.  In the demo there was no capacitor so the mag collapse induced an extremely high voltage that overcame the resistors and the resistance of the switch and ionized the air and passed current that further discharged the input scource.  So why not switch your capacitor in parallel with the collapsing magnetic field.  This capacitor now charges up to a higher voltage and q than was supplied by the scource. Simply because of Faraday's law of induction.  The faster the magnetic field change the higher the electro-motive force.  The higher the electomotive force the larger the current through a known resistance.
http://www.youtube.com/watch?v=aSmMFog10D0
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Hoppy
Tesla's patents.
If you know how TK's devices operate, then why not help Wottsup and others and not just leave them to "get there with a bit of luck" as you put it?
I've been over all your posts and there is nothing in detail that helps anyone to replicate any of TK's devices in terms of circuitry and components used.
If you really do have that much inside information about Bedini tech and want to talk technical about how Bedini's SG devices work and can be looped and run at high COP to work in TK's devices , there are a few of us here that are all ears and have had considerable experience in building and testing SG's etc. Otherwise its all pub talk.
a.king21
The problem with looping radiant energy is that it leaks all over the place.
TK uses extensive shielding to prevent radiant energy loss.
He uses polystyrene, polythene, plexiglass, epoxy resin,
braid, HV cable and finally a very wet earth.
So if you want to loop a Bedini - start with extensive anti-static shielding as outlined
above.
And I am trying to help wattsup.
Every single solid state TK build contains extensive electrostatic shielding.
And don't forget HV cable in the coils.(Or soak them in oil).
Why do you think TK would cover a solder joint with epoxy resin?
You also can't loop direct, because the circuit sees a direct short.
So you have to go via HV coil to coil induction, as in TK's patents. (impedence matched).
If you think it's pub talk, then maybe I should stop posting.
