dllabarre
xenomorphlabs
Quote from: x_name-41 on November 13, 2012, 12:03:49 PM
I used this method because this information is very important, something like a key to the principle of kapanadze generator!  ;)
Ah, so you figured a little slapstick would make you stick out of the crowd of 500 other guys who also claim that they figured out Kapanadze's secret. Thumbs up.
captainkt
@x_name-41, I have tried to read your post in English but impossible, the decript site you said you used does not work properly. I think your Kapanadze explanation will be difficult enough for replicators without the theatrics.
Keith
dllabarre
Quote from: captainkt on November 13, 2012, 02:32:19 PM
Keith
Here is what x-name-41 message says:
radio equipment in order to reduce the frequency of the signal using different methods (demodulators, decoders, heterodyne, etc.) where the output frequency is also different in origin from that input as in heterodyne RF input when it manipulates the signal through intermediate frequency generator and output signal goes completely different from the input frequency as well as the home and perhaps that is the key here is to make the scheme configuration in which the current must be increased at the expense of reducing the output frequency of the signal output has the same origin as the input (without changing the source as in heterodyne). Perhaps the answer lies in the ratios as high-frequency and low power signal turns of the coil are small as in the case when the signal is strong and low-pass (as in Trafo of electric welding) then we require less turns means the issue may be in correlation of the number of turns of the coil to the low-power high-frequency signal and the powerful low frequency signal or a single coil with less turns may correspond to a higher or lower frequency depending on power output of the signal
DonL
