0 Members and 60 Guests are viewing this topic.
xenomorphlabs
Quote from: x_name-41 on November 12, 2012, 08:03:13 PM
here is the answer but is encoded:
password:123456
Quote from: x_name-41 on November 13, 2012, 12:03:49 PM
I used this method because this information is very important, something like a key to the principle of kapanadze generator!  ;)
Quote from: dllabarre on November 13, 2012, 05:10:27 PM
Here is what x-name-41 message says:
radio equipment in order to reduce the frequency of the signal using different methods (demodulators, decoders, heterodyne, etc.) where the output frequency is also different in origin from that input as in heterodyne RF input when it manipulates the signal through intermediate frequency generator and output signal goes completely different from the input frequency as well as the home and perhaps that is the key here is to make the scheme configuration in which the current must be increased at the expense of reducing the output frequency of the signal output has the same origin as the input (without changing the source as in heterodyne). Perhaps the answer lies in the ratios as high-frequency and low power signal turns of the coil are small as in the case when the signal is strong and low-pass (as in Trafo of electric welding) then we require less turns means the issue may be in correlation of the number of turns of the coil to the low-power high-frequency signal and the powerful low frequency signal or a single coil with less turns may correspond to a higher or lower frequency depending on power output of the signal
DonL
Khwartz
Quote from: a.king21 on November 09, 2012, 07:09:44 PM
The problem with looping radiant energy is that it leaks all over the place.
TK uses extensive shielding to prevent radiant energy loss.
He uses polystyrene, polythene, plexiglass, epoxy resin,
braid, HV cable and finally a very wet earth.
So if you want to loop a Bedini - start with extensive anti-static shielding as outlined
above.
And I am trying to help wattsup.
Every single solid state TK build contains extensive electrostatic shielding.
And don't forget HV cable in the coils.(Or soak them in oil).
Why do you think TK would cover a solder joint with epoxy resin?
You also can't loop direct, because the circuit sees a direct short.
So you have to go via HV coil to coil induction, as in TK's patents. (impedence matched).
If you think it's pub talk, then maybe I should stop posting.
Have you EVER made, would be only one time, an experiment with OU or close loop? Because if not, how can you pretend to "know" how it's going on?!
Make one by yourself, and if you succeed, just come back to share your effective skills, but not waste the time of other experimenters...
a.king21
Quote from: Khwartz on November 13, 2012, 10:04:23 PM
My team has been to Tbilisi and watched the device for 4 and a half hours. I also posted the aquarium 2 video.
I talked with TK 2 weeks ago.
I've talked with Travis of the Travis effect and received top secret research papers. I've talked with Don from Magnacoaster, I've talked with Dave Lawton and Patrick Kelly.
What's your contribution?
Jack Noskills
Quote from: andrea76 on November 09, 2012, 08:19:17 AM
SM wrote about strange things happened when 2 transformer get slightly out of phase.one of the asimmetrical out of 4047 is slightly out of phase? what's happen in the transformer??
From my experience using interleaved coils you will get new frequencies out of nowhere most likely due to capacitance of coils. If coils are of equal length then you will get a fixed frequency. If not equal the frequency varies with time. If you would feed the system with 50 Hz and it creates 2222 Hz signal, then you would form a tank circuit that blocks this 2222 Hz signal so that tank is also prmary of output trafo. Then 50 Hz signal would go right through it and juice at 50 Hz is not consumed. You would only use power at 2222 Hz and since this was not the driving frequency you would get free energy. Of cource you would need a tank circuit also around the whole thing so that it would block 50 Hz, unless you can do it with enough wire so that idle current is low.
Does this make any sense ?
captainkt
@Jack Noskills, yes it makes some sense as the 2004 vid shows secondary tampered with, make tank circuit with 50 HZ on one secondary to reduce primary load at 50 HZ, then pull off what ever comes from other secondary then use caps and air coils to bring voltage and frequency to a level where its useful.
Keith
