0 Members and 71 Guests are viewing this topic.
andrea76
Quote from: idzaza on November 14, 2012, 08:40:34 AM
Hi all.
I am writing first time here and in the forum I registered first time, I've seen some other forums too. I am Georgian, I heard about Tariel and his inventions I think it was year 2000. Let me tell you something. It was 90s when there are was serious energy problems in the country. Many of us had generators and car or some other types of battery powered inverter 12v  getting 220 volts AC from 12v DC. I myself have done many of these for my home and for others too. That was the period of darkness which continued till about 2004.
I've seen most of his video's and basically know as much as you about him. I heard about Tesla was about 1996-97, I think that should be the period Tariel started experimenting Tesla's devices. This is my opinion.
What I think is that he uses Tesla's coil, if you see his coil setup there is just a primary and secondary coil. the primary is the same as Tesla's device has but he uses as a secondary less wind and thick wire so he gets 220 volts.
The transistors he uses in 2004 video clip seems to me to be the same I used in my basic invert I think KT827a Soviet/Russian. Basically what this inverter had was microchip I think K561 which was giving from DC 12 volt ac -12v and +12 then had kt315 for each channel + resistor and going to the Transistors. Then two independent winds giving power of 24 volt in total to the step up transformer.
I do not think he is using many thousands of volts in the spark gap, it does not look like that, but he might be using high frequency. (Note: I do not know). I have not got all these theoretical knowledge you have, but from my little practice his device is not something very complicated I think. I have not done Tesla's coil or anything like that, but now I think he uses the power source for the HV transformer I used to use for the inverter.
For me Georgian is a first language, thus I know Russsian and English up to the level I can communicate.
The question I have is how much volts are in the spark gap and what frequency does he use? I guess I have a lot to read before I understand what is going on.
I understand what they are discussing in Georgian and Russian and can tell you that his devices are real. I heard and convinced that his devices are not fake, they are real and I think is simple to make. What he does is in some videos he just adds some othe components like inverter to power the the transformer which then powers the HV transformer I think. Also just to say If some one wants to complicate scheme would do so by adding lots of junk.
all these water generators, solar panels, diesel/petrol/gas - electricity generators are well known in my country at least to me and I am not an electrician, HHO too we heard about it and made but was not any efficient or convenient at that time.
I think Tariel just changed something in Tesla's coil set up and got result, mainly I think he uses less wind and thick wire as a secondary in Tesla's coil.
Hi idzaza can you translate how TK said in the video below?? thanks
http://www.youtube.com/watch?v=r99g4mjEvTEhttp://
Zeitmaschine
Hi! Are you sure the period of darkness for mankind has ended in 2004? ::)
I don't think Tesla ever had a stout copper coil connected to a tiny noiseless spark. That's the puzzling thing with this TK coil which makes it look like a fake.
Quote from: verpies on November 13, 2012, 06:56:28 AM
They are rarely used in commercial power supplies because such high breakdown voltages are rarely needed in voltage regulators and input protectors of transistors and ICs.
But if needed - the high breakdown voltages - then two or more Zener diodes in series would be also sufficient, I think.
Now question: If a diode with a certain breakdown voltage is needed in order to get Free Energy, then how could Tesla ever build an early Free Energy device? The Tesla electric car ran on 12 radio vacuum tubes - allegedly. So can a vacuum tube have the same breakdown effect like a silicon diode?
Quote from: wattsup on November 14, 2012, 08:35:36 AM
The regular ways of testing are producing regular results. It's time to try some out of the box thinking but I need some guidance on the zener thing because everything blows at one point and its always hard for me to stay below that point. lol
OK, a little bit out of the box thinking: There is a coil (see last image with fireball), maybe part of a transformer. This coil is suitable to withstand, say, 100V 1A when connected. As soon as the switch is opened the supply current stops, the magnetic field collapses and thus the coil generates a high voltage pulse. This high voltage then creates an electric arc. Question: At how many amperes? The coil can withstand 1A, that's the input amps when connected to 100V, hence could it be that the high voltage output can also provide 1A? The wire of the coil surely can and the number of turns stay obviously the same. Thus instead of having 100V 1A input, can we have, say, 500V 1A output (or something like that)?
If I have an isolation (matching) transformer and I connect the primary coil to 100V 1A, then the output of the secondary coil will be also 100V (at approx. 1A). That means the secondary coil will never see 500V except the primary coil is connected to 500V in the first place. If I want 500V output from 100V input then I need a step-up transformer, means the secondary coil has to have five times more turns than the primary coil. But five times more turns means five times less amperes. So, as it seems, a transformer which steps up a voltage behaves completely different from a single coil which steps up a voltage. A single coil which steps up a voltage is quasi a transformer with only one coil, if I'm correct.
Further readings (to add a bit more confusion):
In the case of a transformer, why does increasing the voltage decrease the current
Transformer
Just looking for the very basic principle of electric power amplification ...
a.king21
I am not going to answer any more questions, or post any more suggestions.
27Bubba
Quote from: a.king21 on November 14, 2012, 12:52:43 PM
Whatever man! Whatever blows your skirt up..  I was just curious how you guys communicated that's all..  >:(
Zeitmaschine
Quote from: 27Bubba on November 14, 2012, 01:24:07 PM
Currently TK attends English school so he can present his device to the world shortly in perfect English language. 8)
