0 Members and 47 Guests are viewing this topic.
frankidel
Quote from: a.king21 on November 15, 2012, 01:34:40 PM
The basis of the device has been open sourced by Bedini. It is the SG oscillator.
If you put the Bedini oscilator in place of the frequency generator in TK's patent
you will understand the process. However remember that TK uses AC so you need to double up on the SG circuit pulsing alternatively one way then the other.
I thought for a long while that the TK device generates HV. After speaking with him recently
I realised my mistake. His device generates radiant energy and HV is a byproduct of the
process. But radiant energy is lethal to electronic devices, so look at TK's HV shielding.
This link will help :http://www.energyscienceforum.com/sg-radiant-oscillator/125-sg-radiant-oscillator-8.html
I would advise you to go to Bedini's homepage and learn from the great man.
You generate radiant energy by switching a DC circuit on and off at speed.
It's so simple you gotta laugh.
thanks aking for the infos, 12 V switching with bedini, tesla impulse tech, and you've got little rise fall time.  thanks again.
idzaza
Quote from: a.king21 on November 15, 2012, 02:39:16 PM
Idzaza: Thank you very much, you have cleared some  things up for me which confirms
the way the device works.
YOu are wellcome.
What can I say? TK looks very honest in that 2004 video. I can feel when some one lies, but he is not. It is very hard to convince someone in Georgia that you have something unusual invented. These theoretics most of them they are junk in my country, they are out of touch from practice and reality. I now understand that Tariel is not stupid, he has theoretical knowledge too.
Ok, so what now? should I get rid of my petrol engine car until it has some value left? and start looking for the electric car? :D
I could translate any video you think is useful, but you all know pretty much.
The most  informative video is 2004 and the one with green box, in the video with the green box he is not saying as much important things about the device as in the 2004 video. In the can might be the toroidal step up transformer. I used to use in the inverter as this kind of transformer was not making any noise while watching tv and having one bulb on. It was available in my country ready just plug transistors in it and that's it. I think it was from speaker amp I think it had -16 and +16 32 in total output, but I used these two as an input and had 220 volts 150 watts. I mean using it in the inverter set up.
Сергей В.
@all
In attached slow motion video it is very noticeably when transformator was moved up together with "Diode's bridge", White-Conductor which going from capacitor was fixed (not moved at all).
Some capacitor variants:
Capacitor has no connection on "diode bridge". Diode bridge powering up "High-Frequency or Low-Frequency 50Hz" generator on transistors.
Capacitor which is not electrolytic but HV blocking capacitor, is a part of some oscillatory contour including him and some "hidden" inductance. Maybe thin wire 0,25mm-0,35mm is secondary Tesla Transformer layer which had been winded first. Capacitor is not connected to Power-Transformer which was moved, so maybe was connected on some Inductance inside the Tin-Can.
Also important.
In Tin-Can enter 220v White-Conductor and Orange-Conductor, while Green-Conductor from Tin-Can, make one wind around the coil, and enter in Copper-Tube making Coaxial. How Deep ?? Green-Conductor enetr in Cooper-Tube is unknown !!
Some Green-Conductor variants:
Green-Conductor eneter with own isolation on whole lenght (full lenght of copper-tube) in Copper-Tube. On this way he is Inner-Conductor of Coaxial-Cable made from him and Cooper-Tube. There exist Capacitive-Coupling between Green-Conductor(inner) and Coper-Tube(outer). This mean High-Voltage DC pulses, better word Nano-Pulses use Capacitive-Transition for moving charges. At the end (till the Spark-Gap) exist connection between Green-Conductor (inner) and Copper-Tune (outer). On this way we have shorted conductors in fact Shorted-Coaxial which is exactly like in Dally 2012 OU generator. Shorted-Coaxial make one of two variants of Bifilar Coil.
Green-Conductor eneter partially in Coper-Tube with two variants:
Green-Conductor has no isolation in interior of Tube so make a contact with interior of Copper-Tube. On this way we have Variable Inductance.  We can vary Copper-Tube Inductance, because one end of tube is Green-conductor which can freely move in or out coper tube interior. This mean Copper-Tube present Variable-Inductance.
Other variant is the same but with no direct (electrical) connection between Green-Conductor-end and Interior of Copper-Tube. In this case we have Capacitive-Variance. Taking in account that reactance of Capacitor is negative in sign and Inductance positive and including fact that the real parts of both reactences are Real (in other words Pure ohmic resistance), we have subtraction of Capacitor Reactance with Inductor Reactance. Because Capacitor Reactance is far lower Inductor reactance (absolute sign of reactance) this mean that Inductor-Reactance will absorb Capacitor Reactance (negative transformation). As result we wil have changed Electrical-lenght of Copper-Tube. This is a second way which we can vary electriacl-lenaght of coil (in our case Primary of Tesla Transformer).
I have attached some schematics for those who love to experiment with High Voltages! :) :)
ps:
Below is Realstrannik member Red's schematic of 2004 Generator. What is Very-Very interesting about Red schematic i was watched short Red video on YouTube where he was Lightened-Up 1kWatt Light Bulb at Full-Brightness and have melted Spark-Gap electrodes. How ?? I have no idea!! But video has very soon disappeared from YouTube !!
ps2. We are Very-Very-Close to 1001....Light Day !! :) :) :) :) Keep it up boys !!
Сергей В.
HE-HE-HE-HE  :D now some little Off-Top from me !! Just a little !!
Biggest question in the world is: HOW TO CHANGE WATER IN VINE ?? Just kidding !!  HE-HE- :D  :D
AS WE ALL KNOW AS VINE IS OLDER (THAN WATER) IT'S BETTER AND VERY GOOD FOR MAN HEALTH AND SPIRIT BUT IN SMALL QUANTITIES!!
Especially Dry Red Vine Right ?? Right !!
Little experiment with Scalar Waves or as my Great teacher Akimov said once long time ago Neitrino Particles. Magnetic Monopole Particles or Particles which can travel Billions times faster than light and transfer not only energy but informations also. You can modulate them not electrically but in fact spatially adjusting Structural Modulation Index. This kind of modulation was knowm as Structural Modulation or Geometric Form Factor Modulation !!  :)
One more thing Neutrino-Detector was not discovered yet !!  ;)
Does it work ? Yes of course! Anybody which have visited Great Giza Pyramids and have been in them, i mean spared some time in some of their inner structures have got some feelings at some states of awareness. But don't belive me hust check yourself on own skin :) You don't need to go to Giza, it's enough to make some correct Pyramid structure keep in mind Golden Aspect ratio of height and base and make precise placement East-West , North-South like originals made by our Ancestors and you will shoot right in Target !!
On similar way Great Russian astrophysicist Nikola Kozirev made his Famous Mirrors AKA KOZIREV'S MIRRORS which with their possibilities you can transcendenting your conscience and your essence (spirit-soul or as you like call yourself) in Very Deep Past - Very Deep Future through many dimensions of Reality. If somebody ask me what is a purpose of the man or woman i will say this: The purpose is very simple: BECOME CONSCIENCE ON ALL TRANSCENDENTAL LEVELS OF REALITY. BECOME ALL UNIVERSES ENVELOPED MIND.  AND MOST IMPORTANT BE OWN !! BE A PERSON - BE A SINGLE MAN OR WOMAN IN THE SAME TIME !! (HUMAN EVOLUTION IS NEVER ENDING STORY !!)
Here is simple schematic. Make and try on your own will.
Execuse me for little Off-Top !! Удачи всем !!
Zeitmaschine
Quote from: a.king21 on November 15, 2012, 11:52:17 AM
You might also look at Tesla's patent of the magnifying transmitter. TK is using the same principle just using 21st century components.
OK now. Maybe today is not my brightest day but essentially you are saying that the TK device works on the same principle as the Bedini oscillator as well as the Tesla's magnifying transmitter.
Then how can it be that TK and Bedini could file a patent based on an already patented work of Tesla, respectively that TK could file a patent on an already patented work of Bedini?
Just asking to avoid unnecessary confusion.
