0 Members and 222 Guests are viewing this topic.
Hoppy
Quote from: a.king21 on November 16, 2012, 12:35:52 PM
The main thing is that we are on the right track in my opnion. I believe it is a variation of Tesla's radiant energy. I think we all agree that HV can be produced by the pulsing action at mains voltage and that 5 kw can be controlled by two transistors.
And in order to create this effect we need an inductor, or coil of some sort.
TK could have an oil soaked coil in the tin can also. That could probably handle the "radiant" spikes.
I still think that the coils we see  are bifilar, simply because we have verification with Bedini.
Also TK shows a caduceus winding. I know that Boyce uses caduceus and his reason is to minimise Lenz.
So my conclusion is that some form of Lenz minimising coil is necessary.
As for 5 kw being produced from 400 watts. That is no problem. Tesla said he could do that easily.
The pulse duration has to be less than 1 millisecond and the pulse rate I believe has to be greater than about 30 kz. According to my understanding of Tesla, the power output increases with the pulse rate.
If you are talking Bedini tech, then a bifilar wound coil is used by JB as a convenient way of providing a trigger strand and power strand in one wind, much the same as with a Joule Thief.
Yes, output does increase with pulse rate but the pulses / spikes produced by the coil(s) discharging on the cessation of input pulses from a Bedini SG or SSSG have low power, even though the pulse frequency may be in the KHz. The energy transfer efficiency is typically around 50%, thus JB's book reference to <100% efficient. However, for battery charging where JB talks about conditioning with the high voltage 'spikes', this is fine for practical battery charging and conditioning. A conventionally built SG consuming 400W, could not possibly continuously power a 5KW load, such as to give the results shown in TK's videos. If he is using some variant of the SG, then he must have made a fairly radical design departure from the vanilla SG or SSSG, even if he uses a mains voltage for supply. A pulsed coil is a reasonable assumption for starters but beyond that a lot more solid information from TK, or a lot of good luck will be needed to solve this puzzle IMO.
Сергей В.
a.king21 Tell me what are you think about Jean-Louis Naudin replication "Refuge de Sarenne" 2KWatt OU Generator.
Naudin have pulsed his Primary coil L1 which resonance is 742kHz with DC 3kV 20 mA at rate 35,554KHz . Output 2kW 220V 50Hz have taken from Secondary L2 Caduceus winding coil which self resonance is like L1= 742kHz. Modulation coil is bifilar type 2x 19 turns. Modulation signal is pure sinus 50Hz, RMS power 50,75Watts.
One very important detail:  Sarenne reactor use Oxigen Free Copper Pipe cut-off whole lenght to avoid short circuited winding. Lenght is 21,5 cm. He also used Ferrite Toroid Rings 42х26х13 (ODxIDxheight) 3C90 µ=2300 for shielding Radiant spikes.
Ground conductor is also Oxigen Free Copper Braid approximately 10 meter long and earthed with another Oxigen Free Copper Pipe near the water from lake. Lenght of Earth conductor pipe is not less than 1 meter maybe 2-4 meter. This is my estimation.
xenomorphlabs
Zeitmaschine
Quote from: wattsup on November 16, 2012, 08:54:05 AM
Sorry for long post. We are getting to 1000 pages on this thread. I wonder if the forum software will handle it. hehehe.
Either the secret will be disclosed once and for all or this will go to page 10000 and beyond. The page counter counts towards the end of the oil industry, see it this way.
Quote from: idzaza on November 14, 2012, 08:12:04 PM
TK - This is better just this device, god let us all have it, if anyone wants to use it, it is here. He is again about the government - I do not understand what they want, I am offering such things that any normal thinking man wont say not interested.
Simple explanation: They already have it, therefore they are not interested.
Quote from: a.king21 on November 16, 2012, 05:48:01 AM
You have to understand that I am subject to a confidentiality agreement and can only disclose so much.
Then you could register with a new account-name so this new account is not subject to any confidentiality agreement. Just someone new to the forum who discovered the TK secret by accident while experimenting. :D
I have said before that the reason I know about bifilar is because he told me.
And how can you be sure TK told you the truth? Obviously both aquarium devices are crammed full of fakery. But if TK says it is bifilar then it is bifilar?
My gut reaction is that the coils need to have some Lenz minimisation winding.
Yes indeed. But interestingly my post msg344399 regarding coils and diodes is still unanswered.
IN BIG LETTERS:
»If you kill the dipole you loose the energy. The dipole killer is the electron current in the circuit. So therefore the term free electricity only applies to those that have done away with the current or have figured a way to block it from completing its path through the circuit. Their are no meters to measure this radiant current, and when you catch it, it has the power of the universe and beyond.«
Inductive spiking tutorial
Comment quote: »Is there any way to take advantage of the (gigantic) voltage spike to do something with it rather than let it dissipate backing to the inductor?«
Answer: Ask Kapanadze. ::)
A common question regarding transformers is this: How to make it that the primary coil can't see the secondary coil, so the magnetic flux can go only in one direction from the primary to the secondary coil thus the current drawn from the secondary coil can't impact the current in the primary coil negatively?
Possible answer: The primary and secondary coil is one and the same. Just toggle it (at 50Hz). First connect the coil as primary to a supply voltage. As soon as the magnetic field has build up (and before a heavy current starts to flow due to the magnetic saturation of the iron core) disconnect it from the supply voltage and release the energy stored in the magnetic field into a load by means of the generated back voltage.
Since the back voltage (I think the term »back EMF« is not entirely correct here) manifests itself in shape of a gigantic voltage spike and since the energy stored in a capacitor is proportional to the square of the voltage across the capacitor, the idea would be to charge a capacitor with this voltage spike. And since the coil itself generates rather voltage but not amperes there is no need to have thick wires between the capacitor and the coil.
»Energy, though, can be converted into different forms as it passes from a higher to a lower state. He said, "assume that the water, in its passage into the tank, is converted into something else, which may be taken out of it without using any, or by using very little power.«
Tesla's Fuelless Generator (p. 6/7)
Compare page 7 with the page shown here at 10:25, it's interesting.
Now does this perhaps mean electric current is the higher state of energy and the magnetic field is the lower state? Hence the electric energy is here the water and the magnetic field is here the »something else« which can be taken out by using little power?
If one needs a choke/coil suitable for 50Hz then the easiest thing would be to get an ordinary 50Hz transformer, but use it rather as a choke than a transformer. Thus is the primary of the TK transformer really connected to both of the 220V input pins or is it not? If it is connected then this would be nothing more than an ordinary transformer. Hence I'm not sure about that.
What happens if a capacitor rated for 220V (or 400V) is charged by a short high voltage pulse of, let's say, 2000V? The pulse is to short to charge the capacitor to 2000V, hence the capacitor won't get destroyed. But is it charged nevertheless? Maybe with 220V or so? The overload protection would be the alternating current. It changes constantly the polarity of the capacitor so the voltage can't go too high. The principle would be the same like a filter capacitor in a DC power supply but in this case for AC.
In the above video a 6 volt source generates a voltage spike of 40 volts. That's roughly sevenfold. 220V × 7 = 1540V. Since 1000V are needed to jump one millimeter through the air, a spark gap of 1.5 millimeter would be suitable for 1500V. And that's just exactly the wide of the spark gap that can be seen in the green box video.
Here comes more interesting stuff:
Beware of Zero-Crossover Switching of Transformers
It says, a transformer should be switched on at voltage peak rather than at zero crossing because it draws less surge current. If so then how about connecting a coil to the supply voltage at voltage peak (positive), then disconnecting it at zero crossing, connecting it to the load for the next quarter wave (negative), then connecting it at voltage peak (negative) to the supply voltage again, disconnecting it at zero crossing and connecting it to the load for the next quarter wave (positive)?
So far my theories (which no one can follow). Now how about an idea to put these theories into practice?
Edit:
Quote from: xenomorphlabs on November 16, 2012, 03:17:12 PM
Inductive spike explained in layman's terms : Inductive spike
Common Physics ... Inductor
I see that we are not so bad in telepathic thinking. :P
