0 Members and 86 Guests are viewing this topic.
jeanna
Quote from: xenomorphlabs on July 03, 2009, 12:23:56 PM
I have found some information on that ominous word ПЭШЛО (Pelsho) in the coil specifications.
It is a name for enamelled wire in silk threads isolation.
Maybe that is of importance or better said does anyone think the usage of silk for the isolation is important?
I admit to being the one wanting to try the difference between silk and cotton in the Stubblefield effort.
In the research to determine what kind of cloth Stubblefield used, I was led to litz wire.
These days litz wire is enameled wire covered with something else, but at one time it was enameled wire covered with silk. I cannot site references. -- just my own memory.---
BTW
Tesla went into a lot of explanation describing how to keep the high frequency sparks from sparking between the turns of the coils, and spending their energy.
He describes the solution to be:
gutta percha (=latex rubber) coated wire
He also describes that it is best when it is wound under the surface of boiled-out oil, then not disturbed because the oil would probably dissolve the gutta, but if left in one place, it would remain useful for his purposes.
jeanna
HeairBear
When I hear of Shoedinger's Cat, I reach for my gun. - Stephen Hawking
markdansie
@ Bill, hey you are not alone with the electronics going over your head. I am out of depth there as well. My specialty is magnetic motors and hydrogen.
@everyone
Sadly I believe we have another Mylow situation here. I sent the links to the youtube videos to a friend of mine (who has the electronic qualifications) who sent it to some other friends (yes a friend of a friend who we will call mr X)
Mr X pointed out several things in the video which gave a very plausable explanation of where the energy came from. I know seveal of you will dispute this...and good reason to. However it has raised enough doubt in my mind that I would want to see the device in a controlled enviroment.
The theory is they are harvesting EMF from power lines located nearby. I always remeber seeing an artist in England who use to place fluro tubes in the ground under power lines and they use to light up.
I have attached a file worth reading writen by MR x (who I believe is Russian)
Kind Regards
Mark
Shown above is a well-known trick in the whole territory of exUSSR. Power companies know about it and fight with every possible means. To make it work you only need about 10-15 meters of electric wire and some transformator to level it to 220 volts 6 amperes (household standard in this part  of the world).
Since all power-lines are AC (thanks to Nikola Tesla :-) ) any power line in the world can serve as a source of "free" electricity. Georgia (where this movie was taken) is not exeption to this rule.
Now take a look at this
and this
Strangely enough, the inventor tries to keep his "invention" closer to the street, where the power lines are (see the movie #1)
Most part of the electric power wire runs parallel to the street (i.e. parallel to the street power line as the source of AC electro-magnetic field)
In general the picture is clear. The complicated transformators, capacitors etc. do not add much to the picture. Proper earthing is needed to ensure that excessive power will be dumped to the ground and nobody will get killed.
Deliberately or not, he just "re-invented" the well-known method of stealing electricity from industrial power lines without physical connection to the wires. From lawyers point of view, it is a footage of a crime and it is very unwise for this man to distribute and advertize his "invention".
Also in that part of his interview when he speaks Russian, he says that he is an  architect by his education and this invention is his amateur work. He complains that Georgian government just bury his invention. He also said that Minister of Energy of Georgia wanted him to repeat this experiment in the lab but he has no money to go there and he does not want it as it is clearly shown  that it works like everyone just saw.
this is it. There is nothing else much to say.
If you want to learn more on EMF radiation from power lines have a look here
http://www.emfs.info/Sources+of+EMFs/Overhead+power+lines/Calculating/Direction/
HeairBear
Markdansie, thank you very much... Stealing energy from the power company and it's a crime, I love it! I can absolutely agree with you and Mr X, but, it being a crime is another thing. If you fart in my general direction and I smell it, am I stealing it from you?
Pirate88179
Justas just sent me his translation of the first PDF posted by Stefan.  I am sure this is way better and more accurate than the one I did using the translator program.  Here it is from Justas:  (Thank you Justas)
Ok, here is the translation:
The device of extract of energy from environment
Behind authorship of Tariela Kapanadze.
So. The demonstration film in which show of the given device is photographed goes to networks. The author asserts that is based on operations of Nikoly Tesla. And an essence of operation of its installation «on a resonance between первичкой and вÑ,оричкой». All device he names the resonator. Asserts that something has found, but basically it on the basis of operations of Nikoly Tesla.
The author
The author asserts that is the closest to solution Andrey Melnichenko has approached, but to its candidate solution will come yet soon. Капанадзе as the motto repeats «Hold a resonance!». ó«íÚÃ'¼ it is all information carrying though any advantage. The rest should be extracted from the patent and video. Here the author:
Here we will consider video. The patent we will review separately.
What do we see on a film? In the beginning assiduously dig in the heat sink and water. Thus, they have organised grounding, superficial, not especially qualitative, but grounding. After that the platform for demonstrating will be organised, the desktop is taken out, on it some instruments are installed. From which it is possible to conclude complete structure of demonstration installation of Kapanadze.
1. The first and key device is so-called "resonator", a green box with the artful device on пилонаÑ....
2. As far as I understand it is the inverter, DC/AC the converter on power of an order of 4 kw. Most possibly amateur fulfilment. Instead of industrial (modern inverters have other style of fulfilment).
3. The rectifier. Self-made in a box which, probably, charge car battery, in a regular variant of usage.
4. Car battery, 60 AH capacity, not new.
5. Load. Five lamps in ceramic cartridges, presumable power of 1 kw. It is indirectly confirmed, I received a photo of such lamp.
So this is it with structure of installation.
Further there is a following â€" installation is connected to qualitative grounding (a network of cold water supply), include. Lights up the lamps then disconnects car battery, and loading continues to power the device in an independent mode. Contužinous work of installation is not very long, possibly, the inverter works under maximum or overloaded mode. During demonstration measurement are taken by the standard devices, which frequency of work limits to 400 Hz at the best are case.
Lots of wires in the installation and lack of shooting details do not allow to make out wiring (see that have wanted). We can only state the there is no additional obvious power supply is connected to a table. It is possible to hope that this really working device.
During the demonstration the switching from qualitative grounding to poor-quality grounding was made after that the device output has considerably decreased.
On an outer part of the device, except the artful coil on smth (probably paper towel roll), the is also a discharger:
On a rough estimate the gap is calculated for 2-3 kV, not more.
On the top part of the case radiators on which similar two keys (?) are taken out, radiators are cooled by the additional fan (probably an operating mode of transistors not tender).
And actually
And actually there is nothing to add, the rest in patent discussion.
Regards,
Justas
