0 Members and 47 Guests are viewing this topic.
Quote from: Zeitmaschine on November 17, 2012, 08:05:12 AM
Simple as that: Find the basic physical principle that TK device is based upon.
If one does not know that there is a tape covered with magnetic particles, then he will never figure out how a tape recorder works by just looking at motors, gear wheels, transistors and wires.
Hence TK's basic principle must be a very simple one (similar to an audiotape), because he can play around with it in several completely different setups and it works. Like some tape recorders all looking completely different but they also work.
Therefore what about a transformer which primary and secondary coils do not exist at the same time but rather each of them in a different point in time? Sounds nice. But does it work? ??? ::)
The tape recorder is a nice analogy. But I think the situation is even worse than that.
You aren't being presented with a "singing" tape recorder that works in some mysterious manner, with high-tech tape that has an operational principle hidden from you by your lack of understanding and your lack of fine instrumentation.
No, you are being presented with a "cargo cult" tape recorder, that is made from string and coconut shells, and that woman singing you hear.... isn't coming from the string and coconuts at all, but from someone hiding in the next room.
You will have no success at all trying to build your own string-and-coconut tape recorder, because you are trying to build what you _think_ you see rather than what you really see. I mean, you can build an exact duplicate of the cargo-cult recorder, out of the best string and the authentic coconuts from the right island and everything..... and all you will ever have is a string-and-coconut tape recorder that sits there but doesn't sing.
If on the other hand, you build something that simply does what you SEE, not what you would hope to see, you might have better success.
In my way of thinking, there is a major clue that hasn't been given the attention it deserves. And it is this: At some point inside the apparatus, it is possible to measure the local _mains line voltage_ at the local _mains line frequency_... exactly.
This is the opinion of a cynical, outside observer, true, and I have not had the pleasure of a site visit, but as far as I can tell nobody has actually done the "principle experiment" on this one: go outside and pull the house mains breaker during a demonstration.
ramset
TK
Gathering up the stones now,Or will it be wood [for the fires]?
I forget ...its been a while since we had to deal with such blasphemy!
can't find that stupid pitchfork anywhere...........
Thanks Grandma
a.king21
You should consider that we have made progress:
I have shown the connection between
EV Gray (Gray tube)
Ismael Aviso (coil shorting)
Bedini (radiant energy)
Tesla (Spike - radiant energy king)
Kapanadze. (High frequency generation)
Also if you look at Stanley Meyer's electronics you will see
a short sharp impulse at resonance is the principle used to overcome the Faraday limit.
You can also add the Rotoverter to the list.
I have produced scientific evidence that all used the same principle
of spike generation. This spike is electromagnetic in nature
The emphasis being on the magnetic.
Suddenly we can see the Leedskalnin and Howard Johnson explanation of the 4
vortices emanating from zero point could be what the spike re-creates.
Every single one of the mentioned inventions uses the same principle.
I ask the Nay sayers to produce scientific evidence for their grumblings, or most sensible people
will simply ignore you.
E V Gray uses concentric gauze tubes to collect the spike.
Hector (Rotoverter) also uses a device called the diode plug to collect radiant and also other compicated techniques.
Bedini charges multiple batteries with spike energy.
Aviso uses massive spike generation through coil shorting to drive an electric car
Tesla wanted to power the world with his device.
Kapanadze uses HV insulation and a Lenz limiting coil system to collect his energy.
None of these were/are easy to replicate.
forest
 what is the SPIKE ?  >:( Take a nanosecond oscillator like this from Dally device and measure the output using cheap old oscilloscope with a max 1Mhz resolution. What do you see ? Spikes ? IMHO Spike is nothing more but energy in form of high frequency and high voltage ringing.
did you saw anything else ? I don't believe nature would produce a pure spike without structure of ringing . It's just very high frequency. The secret is much simpler , yet I still have to prove it making a recovery circuit but I'm convinced that energy is not transfered in low frequency oscillators. It leaks in the points of momentary high frequency in form of radio and heat waves (which is the same just different frequency). When you power primary of transformer this energy would not be  transfered to secondary, it sloshes back and forth in primary. Like Don Smith said no electrons from primary will pass to secondary and additionaly no energy also. Law of conservation should be a bit modified. Flyback spike is the energy trying to escape from coil if that energy would be transfered to secondary there should be no flyback.
xenomorphlabs
Quote from: a.king21 on November 17, 2012, 09:44:09 AM
Please be careful mentioning Rotoverters and "Bedini spikes" in one go.
RV's are not as simple as that.
The RV does work with radiant energy, but that is certainly different from the ominous Bedini spikes.
Hector defines Radiant Energy = Radio Frequency.
RV is all about reactive power transformation and the reason for the power gain is not spikes, but a resonant condition in an LC-circuit
with a phase angle of close to 90 degrees. That is the condition to allow radiant energy to enter the circuit.
