0 Members and 37 Guests are viewing this topic.
xenomorphlabs
Quote from: idzaza on November 19, 2012, 11:16:09 AM
I wish to have one. Still learning things :) watching tons of videos and read plenty materials. I got a question: how does TK gets such a high amperage? Is it possible to get high amp from Tesla coil by winding less but thick wire on it?
If you don't have a method that actually introduces a highly non-linear factor, then just using thick wire won't do anything. If so, then any application using thick wires
like construction-site cables and what not would experience power gains. To make it simple , think of Ohm's law.
The thick wire will just drag more current out of your source as well and you haven't gained anything.
One thing is for sure, TK has found a method that exhibits strong non-linearities and on top of it he is able to extract it without killing the condition in the first place, non-reflective to the source.
idzaza
I've got confused.
I've see his patent on the net. But here I've read, that he has not got one for his device, instead he has made application and did not get it yet. In his video with a green box he is saying that he wants to have proper patent for it, and after he's got there want be a secret.
Is that how it is? has he got or not patent for his device?
Zeitmaschine
Quote from: xenomorphlabs on November 19, 2012, 12:34:54 PM
The second thing for sure is, there is a lot of Tesla stuff around which almost no one seems to be interested in:
Kornelson's Free Energy Transformer
What could happen, if the »supply battery« would be AC and the switch driven by 50Hz?
Quote from: idzaza on November 19, 2012, 02:47:06 PM
I've got confused.
That's the normal state of consciousness in this forum here.
He has got two patents, but only TK himself knows whether these patents have actually anything to do with his device or not.
Quote from: Zeitmaschine on November 19, 2012, 04:10:04 PM
Looking at the Kornelson pdf, I am struck by a certain strong resemblance: if you took his schematic, (the last one in the second part I think, not the Tesla transformers in the third part) , and substituted active components.... a transistor.... for the various switches ... you would have something very much like some Joule Thief variants, and if I am understanding him correctly, would work in the same way. You've got a system of switches, coils and capacitors that produce and channel and store inductive field collapse spikes. The JT circuit does this "automagically" and can produce some pretty amazing results.
frankidel
Hi in the TK can, if it is a toroidal transformer, can it be cut in half like the yoke device of wesley ??? and then fitted into the can.
