verpies
Quote from: Zeitmaschine on November 21, 2012, 08:40:21 PM
A battery can provide voltage. This is the empty tank under water. The battery is not under water but under aether. The tank can do work by means of a current of water which flows into the tank. A battery can do work by means of an electric current of electrons which flows into the battery's positive terminal. When the tank is filled up with water then it can't do any further work. When the battery's positive terminal is filled up with electrons then it can't do any further work.
It is important to remember that the amount of water is an analogy of electric charge.
It is true that electric charge is conserved in electric circuits such as the Kornelson's transformer.
However, electric charge is not energy, the same way as a given amount of water is not energy.
Notice that the amount of work (energy) is largely independent from the amount of water that flows into the tank (charge).
Work also depends on how the water flows into the tank.
Regarding the the Kornelson's transformer which is a series LC circuit in the first stage, it is important to note that when the current in the inductor reaches 100% of its maximum, then:
1) The voltage in the capacitor reaches 50% of its maximum.
2) Because E=0.5Li2 and E=0.5CV2 then, respectively, the energy stored in the inductor as magnetic field is also at its maximum (100%) and the energy stored in the capacitor as electric field is at 25% of its maximum.
3) The charge that flowed through the inductor up to this point is the same as the charge that is now stored in the capacitor. (I*t = V*C)
Сергей В.
Привет всем !!
OBTAINING FREE ENERGY FROM NIKOLA TESLA TRANSFORMER BY TIGER2007
On the Internet exist a lot of documents which saying that the Tesla transformer or T.T is a power source, but nowhere did not told about how to correct adjust it. Let's try!! T.T (Tesla Transformer) is the simple device which the ordinary school boys can make, but for adjusting and trimming T.T at least an 2 channel oscillograph and signal-generator are necessary equipment, for example self-made PWM generator on TL494. The description of schemes on TL494 can be found easy on Internet. This generator is good because it has a possibility of separate adjustments of dutycycle and frequency.
And so we will begin!! Everything what is necessary is a plastic PVC pipe and 40 meters of a Magnet or enamelled wire, also some high-voltage impulse capacitors. For example there is a plastic PVC pipe 40 cm in length and 11см in diameter and 40м Magnit wire - 0.3mm diameter. Winded on a pipe we got a winding 34.5см in length from 115 turns. Now we need an inductor (primary winding). We will follow Nikola Tesla recommendations and we will measure for the pur primary a piece of the same Magnit wire four times more shortly, than for the secondary winding – 10m. Diameter of  primary coil should be at least 1,5-2 times or even more bigger than diameter of secondary.
Let's say for example we have found a piece of plastic pipe 14 cm in diameter, we winded the primary on it. The primary winding is 70 mm in length from 22,75 turns. Everything we got, so now we will fix our design, fastening the primary. It's desirable for making so that it could be moved on both sides several cm. ATTENTION - WE DO NOT SPARKING ANYWHERE.  Let's collect the elementary scheme (1), we will connect an oscillograph through a sensing loop on secondary,  also signal generator on the primary and we will play with frequency and duty cycles of impulses. Done !! What did we seen? We have seen distinct impulses followed with a dumped ringing oscilations of tested coil. Let's now adjust frequency and duty cycle of generator so that distinctly we can see 2-3 starting impulses and 5-8  dumped ringing.
Now we will do a little count. We will search for exactly one frequency, ONLY ONE FOR RESONANCE, among thousand others, namely that frequency on which wave-length is 4 times more than a length of the wire which has been winded in coil. For example  40m multiplied on 4 – we receive 160m – which was required wave-length and there corresponds exactly frequency 1,875MHz. Here I intentionally didn't considered shortening factor of a wire, as a rule, wires comes from unknown brands and this velocity factor many times isn't known. We will see everything on oscillograph.
Further we will connect on secondary coil, variable HV capacitor and do adjust-ments, or fine tunings by soldering additional capacitors in parallel to main HV variable  capacitor (2). Capacitors will be in units of pF or maybe – in tens of pF. It is possible to take variable capacitor from the old receivers, the truth is, we need to measure his capacity and to find appropriate high voltage capacitor closest measured value, or to make one. Working voltage of the capacitor should be not less than 10KV.
At some instant time we will see on oscillograph increase in amplitude of free oscillations and what is the most interesting – damping of waves will be very very slow-ly. It is a mode of a standing waves in T.T – on the ends of our coil now exist two antinodes and a signal almost without loss have reflected from the ends of secondary contour. There is a free energy and we have got something at last.
Now we have taken a little free energy. We will connect one channel oscillograph  probe on terminals of primary and observe carefully (3.). We will  see – start impulses of generator and dumped oscillations of the inductor at very high frequency. Here is very usefull two beams oscillograph, with one beam we will supervise oscillations in the primary coil, with other oscillations in the secondary of T.T. Trimming primary coil frequency by adding additional capacitors, we will get summing capacity about 100 – 200pF. At some instant time we will see increase in amplitude of oscillations, as we  approaching the resonant frequency of a primary contour, we will try to move primary coil along his axis. At the moment of coincidence of frequencies and phases of oscillations between primary and secondary coil we will observe the following .... In the primary coil dumped oscillations will be clearly visible. In a secondary winding .... We do not trust our eyes!!!! Dumped  oscillations were turned into the increasing oscillations!!! And the amplitude in the secondary considerably grew up. On two beam oscillograph it is clearly visible ... Appear like primary dumped oscillations pushing oscillations into secondary and their amplitude in secondary grows during some time,as a rule 3-5 oscillations, then starts to fall very slowly. Now we have everything, we have free energy. 
Well now is possible to disconnect signal generator and to connect spark-gap on our primary.
Notes:
Primary coil should have good Q-factor (quality factor), and it's not necessary to seek to big factor of transformation.
The question about output of energy is a separate subject.
It is necessary to tell you that everything that here was written – was repeated.
EVERYTHING WAS CHECKED BY TIGER2007 - 14. 11. 2010.
Сергей В.
FEL OU GENERATOR
This was first OU device built by Fel and independent from him Tiger2007.
Technical characteristics:
Input power 40-50 Watt RMS
Output Power 7 KWatt
Work from Accumulator on 12V
Give strong interference on Radio and TV bands.
Device consist from Spark-Gap (SG) and modified Tesla Transformer TT.
From top to bottom see picture:
Top of TT:
Whisk ruffled from bundle of bare wires 30-35 см in lenght
Whick need to be joined with ВВ (HV) secondary of TT with thick welding lead (conductor for 300A) in lenght 6-7m. Upper 2 meters of welding lead put in big plastic tube and set-up the tube vertically.
Secondary TT:
The lenght of ВВ - TT secondary equal = 4 times (x) diameter of TT framework. Diameter of TT framework is 20 см, secondary TT coil lenght is 80 см, winded with Enamelled Magnet wire diameter 1мм.
Primary TT:
Primary coil winded on mandrel 30-35 см in diameter with heavy cooper tie. High Q factor !!
TT Current Amplifier or TT Compensator coil:
This coil is unique. All secret of TT is in this coil. Inside ВВ - TT secondary must be putted Current Amplifier or ¼ Compensator coil. This coil playing key role in transformation of High Potential on seconday side to High Current on the load side so must be winded in counter-side against ВВ or Secondary TT. The lenght of "Compensator coil" must be exactly  ¼ lenght of ВВ - TT secondary. "Compensator coil or Current transformer" is necessary for exact trimming of TT Resonance and maximum power output. (If secondary has right-hand windings compensator coil must have left-hand windings and vice-versa).
TT Grounding:
Ground lead choose individually, in original there is a hank of cable 25m thick copper conductor. In the earth puth thik copper pipe 1-2m in depth.(or better more).
TT Spark-Gap:
Spark-gap work on 300Hz and contains together push-pull oscillator on КТ838 transistors and TVC or TDKS (Flyback TV transformer), HV mica impulse capacitor about 100pF 10KVolts. The capacitor need to be chosen manually until maximum amplitude in TT primary coil was reached. About trimming TT coils read the Tiger2007 post above.
Trimming TT:
Than carefully sliding сompensator coil or current transformer inside ВВ - ТТ secondary, adjusting 2 times increasing in amplitude of secondary.  Ground conductor also need to be adjusted in lenght for maximum amplitude on ВВ - TT secondary !!
TT Push-Pull Oscillator:
For push-pull stage any transistors from КТ838 or similar will be excellent. Resistors in bases 500-1K ohms/2Watts. Filtering capacitor better than 1uF and any power choke will be suited. Transistors must be on radiator !!
The load: Resistive loads such as Water-heaters, Electricity-heaters will be fine up to 7 KWatts.
THIS DEVICE WAS CHECKED BY TIGER2007 ДД.11.2012 !!
ps (from me):
If any of you have built BIG TESLA TRANSFORMER now is time to pull Power out of him. As bigger Tesla Transformer as is, it's better. More energy at output.
For anybody who want to replicate this generator for the fisrt time they can make small TT and check or use from example Brovin Katcher as Secondary of TT or whole Katcher only making new Current Transformer coil or Compensator coil and putting in inside secondary. On the same way Tesla Scalar Wireless System can be tested by puting newly made Tesla bifilar or Tesla pancake coil on the receiver side Tesla pancake (on it or under it) but taking care about winding directions whcih muct be exactly on two opposite sides (winding in quadrature or 180 degree out of phase) of original Tesla receiving pancake coil.
For more info READ NIKOLA TESLA PATENT. THANKS HIM WE HAVE IT !!
GLORY TO NIKOLA TESLA !!
Удачи всех благ!! Сергей В.
xenomorphlabs
Quote from: Сергей В. on November 22, 2012, 09:38:43 PM
Yeah, but that is where it gets interesting! All that Tesla primary stuff is known.
Simply hanging a load on the output without extraction concept of some sort will kill the resonance and just load the source down and that's what everybody mindlessly does.
captainkt
Yes but I for one must admit have never tried opposite wind 1/4 wave current transformer inside secondary. Lots to play with.
Keith
