0 Members and 82 Guests are viewing this topic.
wattsup
@captainkt
Quote from: captainkt on November 24, 2012, 01:21:42 PM
@wattsup,thanks for lasersaber link, the circuit he has posted looks very promising and with a few tweeks could work for larger output if scaled up using 1:10 transformer and larger cap. Transistors doubled or trebled to withstand load.Lots to try.
ps. If Kapanadze gens work like this it explains a lot, earth required and 50hz input and output.
Keith
I asked @lasersaber is he could measure the frequency going to his bulb. I have not received a response but by the way the bulb reacts I would say it is not really 60Hz but it could be a high frequency riding on the 60Hz. If so, with a scope you should see a nice 60Hz wave form but instead of a single line, the line will be sawtooth like. We have seen this many times when doing one wire lighting of bulbs, or by using the body as ground.
I also suggested that he have a line going to his mains neutral so he can continuously do comparisons between the earth ground and the mains neutral.
@xenomorphlabs
Quote from: xenomorphlabs on November 24, 2012, 01:20:38 PM
I must add that the translator is not from the technical field at all and might due to the lack of knowledge not be able to express technical terms, configurations exact enough.
Hooking a water supply pipe to mains is a real bad idea as you would just either blow fuses or whatever component is delivering the mains.
PLUS, any load connected to that pipe would not see a single micro-ampere, cuz everything is between the supposed mains and the water/earth !
It would be as if you hooked the load directly to ground.
So the argument of setting the water supply under mains voltage is very much flawed.
As long as the words are the right ones, we can do the technical linking ourselves.
About adding mains to the water pipe, most all of such pipes already will have the mains neutral grounded to it, plus adding a 6.4 volts potential that could be in the 100kHz or more range will not effect anything. They could have a remote circuit grabbing from the regular mains and spiking that water pipe and all the other demos could have been done that way.
Once the radiator trial was deemed unsuccessful, Tariel make a gesture with his hand cutting across his neck as if to say, cut the power. But to whom did he gesture that seems very weird unless someone was looking at him at all times. That's when he moved the chairs with the bulbs and gave that bulb wire to the other guy to connect to the water pipe.
It could be very plausible that TK found a novel way to transfer energy through one wire as a trick but the intrigue became so popular that they started to make a demo business and maybe this is why he does not want to disclose this to anyone. Would David Copperfield disclose how he made an airplane disappear. IN Davids case, since we know in advance that it is a trick, so, we accept that we will not know how he did it. But in the case of TK, we could be pounding our heads for another 1000 pages.
I am not saying it is fake or anything like that. Just as usual, checking all sides and having a real timed translation would be of great help, although I am aware that the task is definitely not an easy one.
wattsup
Hoppy
Quote from: wattsup on November 24, 2012, 02:16:21 PM
@xenomorphlabs
wattsup
I think you are thinking along the right lines here.
cheappower2012
To all
I did this experiment a while back,I was interested in
TK not being able
to measure the ac voltage across the light bulbs in the green box video
.The cheap clampmeter I believe is part of the smoke and mirrors,I used a clampmeter
very close to the one TK used.It creates a false reading of current measurement.In my
opinion there is no ground current
at all its an illusion.In the video I posted ,I turn off and on, the ac voltage to the
light bulb it creates an illusion
of current that follows when the ac is turned on and off.On the ac voltage I tried a whole bunch of  different meters they all react the same,in my opinion TK did this to create an illusion that its a Tesla invention.It is not a Tesla invention.I used a dc spark but I believe an ac spark will cause the same effects.
verpies
Yes it could be.
Interference-free power transfer over 1 wire is quite an achievement, too.
Hoppy
Quote from: cheappower2012 on November 24, 2012, 06:33:47 PM
To all
TK not being able
This is a 'so simple' setup and nicely demonstrates how the clamp meter can lie. I think you and Wottsup are now very close to how TK did it. One remaining mystery is how did he get the mains live feed into the fish tank in the Aqua2 video?
