0 Members and 138 Guests are viewing this topic.
xenomorphlabs
@cheappower2012
You forgot to mention if the 24 amps were a stable reading or if you just picked one of the erratically jumping display values ?
In the green box demo, the clamp-meter measurement did not exhibit signs of HV/EM interference, it was nearly stable and that over a couple of seconds. This is important to state.
A lot of meters will show such readings under interference : http://www.youtube.com/watch?v=qBYdqSrJssU
Quote from: wattsup on November 24, 2012, 02:16:21 PM
@xenomorphlabs
As long as the words are the right ones, we can do the technical linking ourselves.
About adding mains to the water pipe, most all of such pipes already will have the mains neutral grounded to it, plus adding a 6.4 volts potential that could be in the 100kHz or more range will not effect anything. They could have a remote circuit grabbing from the regular mains and spiking that water pipe and all the other demos could have been done that way.
Not sure if i got you right. You think that it is possible to add a 6.4 volts potential to a grounded water pipe thus being able to tap that potential from the pipe to do work?
Or by saying "will not effect anything" you conclude that the potential will be "dragged to ground" ?
What do you mean then by spiking the water pipe?
Anything like spikes (impulse waveforms), ac, stable dc will not leave a grounded water pipe to form a usable potential outside of it. If so
i would stay away from touching any water tap, cuz i could get shocked from stray currents being on their way to ground. The effort/concept of grounding would be obsolete then. But pretty sure i misunderstood you.
cheappower2012
@xenomorphlabs
only the cheap clampmeter shows this effect,yes the reading
is stable,also unless you clamp the wire you get no effect,the clampmeter
is made by the same company that makes TK's clampmeter.I have never seen an effect like this effect before,
I have seen effects due to
hv/em fields ,this is stable and does not change ,the same as the greenbox video.
In the video you posted that guy is pumping enormous em fields not the same as the experiment I did.
Pulses are induced and mixed with the ac,I looked at this thru a scope,the purpose of the experiment was to determine
why TK could not get a ac voltage reading across the lamps,I just happen to check current from the ground wire.
In my opinion TK has a real device that generates a high current at 220 vac 60 hz,he feeds this thru a Tesla interface(the fake part),
the Tesla interface consists of the coils,the spark gap,ground and the high voltage,the spark discharge induces  pulses,onto the 220vac
60hz that passes thru the coil,the mixture of 220 vac 60hz and induced pulses creates stange effects in digital meters.
I didn't show a video of the ac voltmeter reading across the light bulb,it jumps around like in the greenbox video,all
the meters I have responded the same to the ac voltage.On the ground connection only the cheap clampmeter showed a current,the other two clampmeters showed zero.
Khwartz
Quote from: a.king21 on November 13, 2012, 10:12:02 PM
My team has been to Tbilisi and watched the device for 4 and a half hours. I also posted the aquarium 2 video.
I talked with TK 2 weeks ago.
I've talked with Travis of the Travis effect and received top secret research papers. I've talked with Don from Magnacoaster, I've talked with Dave Lawton and Patrick Kelly.
What's your contribution?
I understand very well what you mean: you were there, you talk to people, but the fact is even you had all these very advantages, it's obvious you were not able to produce any workable O.U. device or you would have immediately stated and showed it.
My immediate contribution here is to spot lies where there are here, or at lest could be. And yes, I was myself in direct communication with a AIDA teem member to help to have a maximum of rigour in the experiments.
The difference between you and me is that I'M OT PRETENDING TO KNOW HOW ACHIEVE O.U. MYSELF WHILE YOU DO CLAIM TO KNOW, AND YOU DO NOT DEMONSTRATE IT. That is the very out-point I'm spotting about you.
there is nothing bad to give ideas, but would be good to realize that if been so close of the KT and so on, it's there is a big lie somewhere. could be NOT basically form you, indeed, but for sure from KT while it's not logical to claim to provide help other to replicate his system but nobody could really replicate it with good workability.
As a great writer said: "one who know but not do, doesn't know".
So, I'm not saying you could not have good and important points, I will just say that: HOW CAN YOU KNOW THEY ARE id you don't have try this ideas yourself? Because this is the very difference between been just "PR" and been really SKILL.
For my own, I help many guys on web in there experiments and have indeed had their thanks for this help. But I only do with my viewpoint of a professional in energetic and electricity engineering who he very aware of many other possibilities than the academics teachings. And most important, when I make an extrapolation, an hypothesis, I'm not stating it like "The Ultimate Truth"... Just I want to say, is if we can really differentiate at least WHAT IS REALLY DEMONSTRATED and TRUE, form what is still probabilities, it could win much much time to any body, ans this is my really main point here, and sure you can understand it.
Cap-Z-ro
" One remaining mystery is how did he get the mains live feed into the fish tank in the Aqua2 video? "
Maybe he used monofiliment fishing line ?
After all, it is a fish aquarium.
Khwartz
Quote from: cheappower2012 on November 24, 2012, 06:33:47 PM
To all
I did this experiment a while back,I was interested in
TK not being able
to measure the ac voltage across the light bulbs in the green box video
.The cheap clampmeter I believe is part of the smoke and mirrors,I used a clampmeter
very close to the one TK used.It creates a false reading of current measurement.In my
opinion there is no ground current
at all its an illusion.In the video I posted ,I turn off and on, the ac voltage to the
light bulb it creates an illusion
of current that follows when the ac is turned on and off.On the ac voltage I tried a whole bunch of  different meters they all react the same,in my opinion TK did this to create an illusion that its a Tesla invention.It is not a Tesla invention.I used a dc spark but I believe an ac spark will cause the same effects.
WOW! Great presentation of your schematics and experiment, this get very understandable, cheappower2012 :bd :)
