Zeitmaschine
Quote from: magneto_DC on November 23, 2012, 06:53:52 AM
Someone has posted a patent (application) not more then 2 month ago. I suppose it was here, and it was Zeitmaschine.
Content was, a array of Tesla-HV-Secondary with INSIDE (third) low voltage current coil.
Two months ago? Can't remember what I have written two days ago. :(
Quote from: verpies on November 22, 2012, 07:46:56 PM
Regarding the the Kornelson's transformer which is a series LC circuit in the first stage, it is important to note that when the current in the inductor reaches 100% of its maximum, then:
1) The voltage in the capacitor reaches 50% of its maximum.
2) Because E=0.5Li2 and E=0.5CV2 then, respectively, the energy stored in the inductor as magnetic field is also at its maximum (100%) and the energy stored in the capacitor as electric field is at 25% of its maximum.
3) The charge that flowed through the inductor up to this point is the same as the charge that is now stored in the capacitor. (I*t = V*C)
And that means?
Quote from: wattsup on November 25, 2012, 04:41:10 PM
The 2004 device - We never saw him playing around with the ground or showing its origin.
The Green Box device - The water pipe could be spiked from any point where that pipe is coming from.
The Wesley Georgian device - The ground wire going to that pit could have been spiked at any other point on the metal L-Bracket trim.
The Aq2 device - That bolt on the cement slab is surely going somewhere else from under the slab. At the start of the video you can see two guys coming out of the far room where the ground bolt could have a wire leading into that other room.
How can the blue coil setup be a one wire energy transfer? Three-phase (and ground) goes in and three-phase comes out:
Kapanadze 100 KW free energy unit test in Turkey
220V at almost zero amps in (0:26) and 220V at 3 × 10 amps out (1:44) situated on a glass table in an magnetically (radio frequency) shielded room with a lot of people around taking measurements. I'm sure there are many fakes involved in this device, excluded the output of high current itself. That current seems to be (the only thing?) real according to all what we know so far.
Now further basic testing, because square one is my favorite square. :D
Basic research #4: 12V in 650V out due to pulsing with a simple switch. This kind of configuration with two coils gives the highest voltage. Basic research #4a: With 12V sine wave the output voltage is only 36V. Basic research #4b: With 12V sine half wave the voltage output stays at 36V. Basic research #4c: With 220V sine wave the voltage output is 620V, but still lower than with 12V pulsing.
That implies that in order to generate high voltage (and energy?) by means of the back voltage of a choke, the disconnection of the choke has to take place abruptly, so it generates sharp pulses. Furthermore when there is no capacitor connected which can accumulate the generated current then this energy is lost and vanishes into nothing, because the current taken from the battery stays apparently the same whether the capacitor is connected or not.
If 12V in gives 650V out, then what would be the out-voltage if the in-voltage is 220V? It calculates to approx. 12.000V to 16.000V, hmmm ... I have never tried this, I don't want to burn out my equipment. But anyway this is proof one can generate 650V out of 12V with an ordinary 50Hz transformer, hence there is no need for a flyback (or the like) in order to have high voltage and some sparks. Means the TK spark is almost for sure a by-product of the device's function.
Now some theory: If one generates a sharp start-up pulse (or a few *) then the out-voltage will increase. When the voltage has reached a certain level then a spark could provide the next sharp pulse by itself, so the voltage can increase even more. That means, if the back voltage generated by a choke contains indeed some additional energy then the spark could be self-sustaining at some point (if connected the right way). If, on the other hand, the back voltage generated by a choke contains no additional energy then the question arises where is the additional energy coming from in the TK device? Because the NMR theory is even more far-fetched than the BEMF theory. But some kind of physical basis should apply nevertheless.
* At 20:20 of the tin can video the spark gap does not fire (not visible), at 20:45 the assistant toggles the switch a few times till the light goes on. Question: If the switch simply connects the lamps, then why is it that they are not brightly lit at the first attempt? So what does this switch actually do? Does the switch perhaps start the spark manually in case the build-in auto-start has failed?
BTW: If we assume (just for fun :) ) that three of the diodes on the diode plate are fake (non-functioning, because of the strange wiring) then we are left with a transformer, a diode and a capacitor right next to each other in the 2004 video.
xenomorphlabs
This is not to say there are no other effects to be had and we have all seen thus far from so many builds, trials, experiments showing effects. This is normal when you are working with such mixtures of energy. Everything will create an effect. What we have not seen is low watts in and high watts out. Why? ??? ?? When after so many months (hmmm say years since the thread started in 2009) nothing is panning out, then at some point we have to go back to the drawing board and see where is there room for added energy into the system.
Very much agreed. All the replication efforts have missed out on something essential obviously.
QuoteThere a several other points in the Green Box video that do not make sense. One main concern is this........
The first time they lit the bulbs at 13:54 the fat guy measured voltage directly at the green box output wires and it showed it was jumping from a low of 322 to a high of 425 vac, then, right away he went to measure the voltage across one same bulb and it showed 595, 490, 845, 748, 561, overload, 861, overload, 642, 738, 619, 405, 685, 180, 1180, overload. So why is there such a big difference in voltage jumps when it is the same output line measured at two distances. This really bugs me. Right when TK removed the volt meter probes from the bulb his face turned somewhat pale as if to say "Phew, I hope fat guy did not understand what he just saw".
wattsup
An explanation could be that he is actually having a standing wave condition in the load circuit.
Two measurements in the same circuit being totally different depending if he hit an antinode or node with the multimeter probes.
frankidel
Zeitmaschine:  like a king said earlier maybe we are in front of a bedini sort of replication, in free energy bearden book, it is said, to have a 1:1 transformer, rapid closing opening switch, capacitor.  i really like your explanation and basic experiment that are not so basic, because i dont understand all that is involved in it.  My guess is make, break the faster you can.  keep up the good work man..
Cap-Z-ro
I don't know nearly as much as most here, but I get the feeling a make-break in a rhythmic pulse, utilizing back emf, a secondary, and cap would oscillate.
Regards...
