0 Members and 112 Guests are viewing this topic.
27Bubba
"Follow Zeitmaschine. He's figured it out. He has understood."
Ok, Zeit.. Where is the schematic? ;) :) :D
Zeitmaschine
Quote from: a.king21 on November 27, 2012, 08:58:55 PM
From your lips to God's ears. Haven't seen any OU on my table yet. :(
Quote from: a.king21 on November 27, 2012, 08:44:39 PM
Remember it is AC, so TK pulses right and then left. The only way he could do that is to use transistors. The transistors are not used as amplifiers but as solid state switches.
Is it sure that these are transistors, not thyristors? Typically a thyristor is used to generate high voltage pulses in stroboscopic lamps in combination with a neon glow lamp (diagram below). Interestingly a thyristor can be replaced by two transistors. A single transistor cannot be triggered by a neon lamp (vague TK rumor).
The reason Willis's patent is unintelligible to the trained EE is because Willis thought outside the box.
So it is. Why rectify a voltage coming from a battery which is already DC by means of a diode bridge? When there is no back (reverse) current allowed to the battery then would not a single diode (or maybe two) in series with the battery be sufficient?
But what about replacing the reverse output diodes with neon glow lamps? Or perhaps with neon glow lamps which fire a thyristor (or two) to get more amps out instead of just milliamps?
Hence what if TK uses two thyristors, one that creates a pulse at the input and one that creates a breakdown voltage level at the output in order to collect the coils answer of the input pulse? The best time to generate an input pulse for the coil would be when the output pulse coming from the coil has just occurred. Hence what if the output pulse triggers the thyristor which generates the input pulse? Wouldn't that fit the »keep resonance« talk of TK?
The puzzling thing however is, how to do this with AC in- and output? ???
x_name41
this is original Kapanadze scheme!
p.s. the generator is a 200-300KHz. (is not 15.625KHz because this is just an example)
a.king21
ZEIT: The point is you are on the right track.
Thyristors: maybe. There are many ways. I'm tempted by Tesla's own method.
Zeit: Where did the rumour about neon bulbs originate?
I also did not expect you to have ou on the table.
I simply think your experiments are the correct ones, and your thinking is correct.
Everyone else wants 30 years of TK experimentation on the table in 5 minutes.
The main thing is that you have proved that TK does not need a HV generator circuit  in order
to get HV. (As I had already stated).That in itself is a major breakthrough on this forum.
It is probably also a major surprise to EEs.
It also tell us the method to get his circuits going.
To get AC you can pulse DC in a flip flop configuration. There are other ways.
Magnacoaster definitely uses radiant energy. You simply cannot apply EE theory to this form of energy.
The only way is to experiment with it and to see how it behaves.
Magnacoaster allows anyone to inspect his devices with meters. He cautions individuals where not to measure.
Most EE inspectors ignore this and end up blowing expensive meters. That's exactly how radiant behaves.
I know this because I have talked to them. This info is direct from their technical team.
Magnacoaster based his device on the Bedini SG. He took advice from Bedini for a while.
You are welcome to ring them up and double check. I would welcome it.
Zeitmaschine
TK first talks about resonance between two coils. Then he talks about a resonator inside the green box. But the term »resonator« means not necessarily two coils in resonance. If the resonator in the green box is the transformer from the 2004 video then it is most likely just a coil/choke. An ordinary 50Hz transformer keeps always resonance between its (two or more) coils, because all coils are on the same 50Hz frequency. So what does TK mean with »keep resonance« and »resonator«?
Diagram below: If the switch is closed a magnetic field builds up in the transformer's (choke's) core. As soon as the magnetic field has reached its maximum (takes some time) the switch should be opened. Then the magnetic field collapses (takes some time) and generates a back voltage. As soon as the magnetic field is gone the switch should be closed again. If this is done automatically then the coil (any arbitrary coil) should oscillate on its own resonance frequency. If this gives free energy? Heaven knows ...
Quote from: a.king21 on November 28, 2012, 09:14:14 PM
Comes from stivep via Russian forum. So this could mean all or nothing.
I don't mind if it takes 10 minutes. 8)
