0 Members and 136 Guests are viewing this topic.
Magluvin
Quote from: Zeitmaschine on November 28, 2012, 10:30:07 PM
Diagram below: If the switch is closed a magnetic field builds up in the transformer's (choke's) core. As soon as the magnetic field has reached its maximum (takes some time) the switch should be opened. Then the magnetic field collapses (takes some time) and generates a back voltage. As soon as the magnetic field is gone the switch should be closed again. If this is done automatically then the coil (any arbitrary coil) should oscillate on its own resonance frequency. If this gives free energy? Heaven knows ...
Comes from stivep via Russian forum. So this could mean all or nothing.
I don't mind if it takes 10 minutes. 8)
Here is a way to send some back to the battery.  The orange rectangle could be a resistor or possibly a choke coil to try, if just the diode alone adversely affects the circuit, by only sending 'some' back to the battery.   ;)
Mags
Magluvin
Posted wrong pic in post above, is now corrected  ;]
Mags
xenomorphlabs
Quote from: a.king21 on November 28, 2012, 09:14:14 PM
The main thing is that you have proved that TK does not need a HV generator circuit  in order
to get HV. (As I had already stated).That in itself is a major breakthrough on this forum.
It is probably also a major surprise to EEs.
Not so fast here. Nothing was proven at all. That is merely a theory until experimental proof is provided with a specific experiment and not just pointing to TK's experiment where the parameters are unknown.
That's how science is done, but looks like not too many people care.
a.king21
Quote from: xenomorphlabs on November 29, 2012, 03:04:33 AM
I pointed to Zeitmaschine's own experiment(s).
I believe that is the correct way and will provide encouraging results.
Even if we prove it people will still deny it. TK showed a government official his device
and the guy said it is impossible, because it violates the laws of physics.
Well it doesn't. Vacuum energy has been proved and recognised by the Nobel committee since 1957.
EE is still using 19th century theory.
a.king21
Quote from: a.king21 on November 29, 2012, 07:33:17 AM
Magluvin and now stivep have also understood.
