0 Members and 63 Guests are viewing this topic.
sparks
  I think resonance is a means to an end.  It forms a dynamic energy storage system.  Over a period of time your system acquires volt amps circulation that are magnitudes higher than the capacity of the line.  I look at it this way.  A kid on a swing gets input power from the scource until she is swinging to and fro with just enough input to maintain the oscillation. At each reversal in direction the child is momentarily motionless at the highest point over ground.  She is able to simply breath in some air from up there or pluck an apple from a nearby tree.  When she is at ground state she breaths out or drops the apple.  Now she no longer needs the input to maintain her to and fro swinging as long as she is able to pluck some apples or breath in some air and let them go when at or near the ground.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Zeitmaschine
Quote from: xenomorphlabs on November 30, 2012, 01:51:14 AM
By using a sawtooth generator or Arduino-waveshaped signal etc. to feed the amplifying transistors.
Yes that's it. TK has an open-source single-board microcontroller hidden in the tin can. :D
Joke aside. The simplest way to generate a sawtooth wave would be a capacitor which is connected to a voltage source. Then the capacitor is short-circuited (by means of a spark perhaps). This will drop the voltage immediately to zero as soon as it exceeds a certain level. Then the capacitor is slowly charged again (negatively) till the next short-circuit occurs.
So what if the sine wave coming from the inverter or insulation transformer is rectified to DC (+/- split) voltage. Then this DC voltage is transformed into a symmetrical sawtooth wave by means of transistors or thyristors which are driven by the AC sine wave input, thus the sawtooth output stays synchronized at 50Hz.
But don't know if this is simple enough to laugh.
If the TK device outputs non-sine wave AC then this would explain why TK does not allow any measurements taken with an oscilloscope. Because it would reveal his secret.
elementSix
I know that on the Don Smith Tesla Symposium tape from 96' he said that after the energy comes out of the L2 coil he used a diode that changed the saw tooth DC current into pulsed DC that was used to charge the capacitors.  You guys sound different today, remember you have to forget everything that schools teach, because they are told what they can teach, by the same people.   Because of the use of the diode they stopped making them in 92' so you had to order a large amount for the factors to run them off and you couldn't get them anywhere else except from him.
I know that the guy from the Turkish web blog from 2009 who said he was there, he either thought or said that TK was using Thyristors during his 100 KW showing.
Who made the comment that TK used a lack of something from the wave when he sent it throught the coils??
elementSix
So this back volagte spike, would it suck energy from the ground.  Would this be the low current coil under the higher volatge coil that the  saw tooth would be pulsed thru?  or is that what the unshielded coax is used for.  The back voltage comes off the center wire?
Magluvin
If Teslas Peirce Arrow story was true, how did he do it without an earth ground?
That is 'if'. ;)
Maybe some simple experiments should be delved into to investigate the properties of adding a 'GND' and/or 'ANT' to a circuit.  Once it is really understood if these have advantages, then the next step would be on how to simulate those advantages without actually using them.  ;)
As of late, I think any circuitry, above ground is possibly an ANT, when the circuit has an earth GND.
Having an ANT, doesnt necessarily mean that the circuit is just receiving power from it. It may be just used as a tuned(to the circuit operation) and a connection to the big capacitor in the sky. And the other end of that capacitor is GND.
Mags
