0 Members and 346 Guests are viewing this topic.
verpies
Quote from: Zeitmaschine on November 30, 2012, 10:50:39 AM
The simplest way to generate a sawtooth wave would be a capacitor which is connected to a voltage source.
No, voltage across a capacitor charged from a voltage source does not change linearly with time - it changes reciprocally exponentially.
Also, what does this graph represent?
a) Voltage across the capacitor
b) Voltage across the coil
c) Voltage across the switch
d) Current through capacitor
e) Current through the coil
f) Current through the switch
xenomorphlabs
Quote from: verpies on December 01, 2012, 05:58:37 AM
I think he wanted to depict the shape of the waveform created at/by a function generator or anything comparable that would basically
create the original signal to be amplified.
What you say is correct and also the voltage/time and current/time measured at an inductor would have an exponential shape if connected to a voltage source.
In this example it would be a changing AC voltage feeding the coils.
Zeitmaschine
It does not matter how it charges (could be also a curve). The main thing is that it goes off instantaneously. The sharper the switch-off slope the higher the back voltage generated by the coil. Whether this back voltage does anything useful afterwards or not is a different matter.
g) Voltage across the unloaded power source like this graph. Of course a connected coil (b) will distort the graph heavily but that's exactly the general idea of this.
For the same reason a TV's flyback does not work with a sine wave input. It needs sharp declining slopes in order to generate high voltage. But if it generates high voltage then this high voltage will easily spark to ground in contrast to the low voltage at the primary side, even if the high voltage is DC, hence no high frequency is involved.
Ever touched the high voltage connector of a fully charged picture tube of a completely disconnected TV? ;D
A picture tube behaves like a high voltage capacitor. The coating on the outside is negative, the coating on the inside (connector) is positive. Since positive means a lack of electrons and ground (or someone's body) is a source of electrons a current will flow from ground to the positive inside of the charged tube capacitor although there is no closed circuit anywhere.
Therefore the task would be: How to get a (sawtooth) wave with a sharp switch-off slope out of a sine wave by means of a minimum of electronic components in order to create a lack of electrons so a current of electrons can flow through the ground connection towards the positive voltage spike? The less components the better, because we want to keep it simple. :)
xenomorphlabs
Quote from: Zeitmaschine on December 01, 2012, 09:55:23 AM
So you are saying that you attribute the fact that a TV flyback outputs high voltage to the slope of the signal rather than to the high winding ratio ?
QuoteTherefore the task would be: How to get a (sawtooth) wave with a sharp switch-off slope out of a sine wave by means of a minimum of electronic components in order to create a lack of electrons so a current of electrons can flow through the ground connection towards the positive voltage spike? The less components the better, because we want to keep it simple.
A sawtooth could be generated by adding several sinewaves (Fourier) if you really wanna go that way with a sinewave as a start.
There is easier methods.
stivep
MAGNETIC FLUX COMPRESSION
FOR HIGH VOLTAGE PULSE APPLICATIONS
by
JUAN CARLOS HERNANDEZ LLAMBES, B.S.E.E., M.S.E.E.
DOES IT RING THE BELL?
https://doc-00-cc-docsviewer.googleusercontent.com/viewer/
securedownload/b2tlbquve5mnqicsd7f98us40s69j7cm/
3ipivrtv951rbuk9u35b5ib1a4889i7i/1354379400000/ZXhwbG9yZXI=/
AGZ5hq_K2laiUfuLHMOJDvAlcdDA/MEI2eWY5NVdoQ0RmNU1tWml
ZakpoWlRBdFkyRmpNQzAwWWpsaExXRmxOamN0Wm1JNU5qYzNNemcxTlRSbQ==?docid=c35d553bb492be9e6239b02bc590e8cb%7C5aa6ca1b6210c8dfbdff804deef30f03&chan
=EQAAAHsYWQdCE0RLCPouz%2BdYzU35Yb%2Bz3E59gZTrCmdHGKFt&hash
=evkuqji6tldqgogcgrdg1favulkbqm2r&nonce=5jdek6rnvdb6g&sec
=AHSqidZH4AcUEbGB8mfikGH-IIKOLfedrhQyFH0nzr1YkSLmrRdeI-
IWVlFuxrYvFm_gyw7be7fNsliZ5cD_Tc556zrReo_EIihiILQURusVBkYNMn
-wvEBHGoOX-9CpgBcjzMPqVAK5wN_cZzhcKffxyGzwFhym4X-_dso0UEu5kxo-QlME-XA1NMRawbd8KaIWI0RM5oGEscnzP4EROf8Byaj76rQjxdSXZqIw39lChE8Gmn
_1S3M6IXRjXleM9hHzGMuMnMKgZuwMacSI8HAgIrGuVd6hNZa-U-gzOeKvUez10_TxzmYTpJy01f9B29H1r2uFrDtRaAlahptaaRzLFFmhX
_LJ8zPcargM3hyZA08H0MKCTX4&a=gp&filename=mag_flux.pdf&user=AGZ5hq_K2laiUfuLHMOJDvAlcdDA
I was just told that link does not open
next way to find the article is google for
by
A DISSERTATION
IN
ELECTRICAL ENGINEERING
or download it from
http://repositories.tdl.org/ttu-ir/bitstream/handle/2346/11961/31295019801231.pdf?sequence=1
Similarities  with TK coil I have saved this article and did not analyze it till few minutes ago.
OK.................. I know it there was  about 2 years ago  I briefly covered it in scientific group session- they did not pay attention to it at that time.
Have to, to bring it on the table again
got to read it true.
Look at chapter from this article:
IV. COMPACT FCG DRIVEN INDUCTIVE ENERGY STORAGE SYSTEM
WESLEY
PS: click on the picture and  in lower right corner  click on it again  it will bring it to  large size
